Question about Baumatic Ovens
MANUAL FOR BAUMATIC COOKTOP
NEED THE OPERATING MANUAL FOR MODEL GECE6002
Baumatic ovens manual
A google search shows that Baumatic has downloadable manuals for several models. Since you didn't include a model number I don't know which one you need. I am attaching a link to the first one that I found.
http://www.baumatic.com.au/slimline/media/custom/upload/File-1347509999.pdf
Aug 13, 2014 | Ovens
Operating Instructions
Check the breaker. Owner may have shut it off.
May 14, 2013 | Ovens
Baumatic built in oven (B600) product manual
I have a Baumatic P650SS oven. To adjust the timer volume, wait until it is beeping and then press the minus button and it will adjust through 3 sound levels. Release the minus button and the sound level of the audio signal will be set.
Dec 07, 2008 | Baumatic Ovens
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
Baumatic b180 oven
The oven cabinet is likely built for several different models, which means that the case could have been built with an extra hole or two that aren't used on your model. This a normal manufacturing technique for mass-product factories. I see from the Baumatic website that several of their models do use a meat thermometer probe, but even if you bought a probe you couldn't use it your oven. Your model doesn't have the correct circuit board and control panel that the oven needs to use the probe. In any case, if you need to order parts from the manufacturer or would like a downloadable Owners Manual for your model, they are available at this website link: http://www.baumatic.co.uk/products/discontinued-models/builtinovens/B185SS-B Hope that helps! ;)
Aug 05, 2007 | Baumatic B180SS And B60SS (Bundle)...
What do I do now that the temperature markers have been scrubbed off??
Go to www.baumatic.co.uk then go to their online catalogue. Find your oven model & download the user manual. You will find 2 very clear pictures of the facia. Regards
Jul 16, 2007 | Baumatic B180 Electric Single Oven
Ovens Logo
29 people viewed this question
Top Baumatic Ovens Experts
ashburton
Andy Fraser
Andy Fraser
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
