Question about Specialized S-Works Enduro SL Carbon
Change the headset bearing on S-works Enduro SL Carbon
How do I change the headset bearings on a Specialized S-works Enduro SL Carbon?
    Master:
  • 388 Answers
Here's a link to the process of servicing the headset: Park Tool Co ParkTool Blog Threadless Headset Service
Make sure you have the correct bearings to replace. Your local bike shop can help you find them.
Posted on Apr 06, 2014
How to fix differential of astro van 1999
these bearing are adjusted with shim packs if you have never worked on a differential before you really need to bring it to a experienced shop due to factory specialized service tools needed for proper repair you will need a bearing press, a micrometer , a dial indicator , and a pinion depth gauge and specialized knowledge on the usage of these tools
Aug 29, 2014 | 1998 Chevrolet Astro Van
Need sprocket gaurd
Then go buy one at a bike shop.
Oct 23, 2013 | Specialized Enduro SL Pro
Change carrier bearing on Pontiac Torrent
You must rebuild the entire rear end, all the bearings, you can't just installed the new bearing on the ring gear carrier. This bearing replacement job requires many specialized skills and many special tools to complete the adjustments required so the rear differential won't be noisy in operation.
Oct 30, 2012 | Cars & Trucks
My Specialized Hard Rock Cross Country has now broken its second
The rough turning sounds like it may be grinding against the frame or possible a bushing. If there is a place where a bearing could mount on the other side then that may be the problem, that it needs one. If it is not centered that may also indicate that it isn't fitting correctly possible due to missing bearing. If you can feel it slightly wobbling when riding it or even shaking a little when picking up speed then it may not be mounted correctly. The extra wear from an incorrect mount or a missing bearing would greatly increase the wear and cause for a replacement needed.
Jan 03, 2010 | Specialized Bicycle Components Specialized...
We have loud whining noise in the front end that goes away when we steer right
You may have failed hub bearings on the right side.When you steer ,you change the load on the bearings which makes the noise change or dis-appear.These bearings support the outside axle shaft.
Aug 09, 2009 | 1998 Saturn SL
How do i remove the chain stay bearings from a stumpy fsr 120
Have a look at the pdf atwww.mountainbikecomponents.co.uk/ftp/product/LTS bearing kit fitting instructions I'm not sure if the parts are the same but the method used should give you some good ideas. I'm sorry I can't be more help with this one.
Apr 07, 2009 | Specialized Bicycle Components Specialized...
1996 saturn sl front wheel bearing assembly
you got to press it in and out,and if u dont do it right with the proper tools you will wreck the hub
Apr 05, 2009 | 1986 Ford Escort 4-Door
Changed brake pads and rotors on the front still have a roaring noise coming from drivers side front tire
if its like a humming noise its the wheel bearing if you ga straith and move the stering to one side noise there move to the other side noise is less wheel bearing gone lift the car in the front ans spin the wheel manualy listen to see whisht bearing make the noise change that bearing hope its a fix for you and rate a fixya for me if any other question feel free im here thank you pierre
Aug 06, 2008 | 1994 Saturn Sl
Hotpoint wm80 bearing replacement!!
The drum will have to be removed.
Bearing replacement on ANY Hoover can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Hoover washers require at least 2 specialized tools for removing certain components of the machine.
Jun 26, 2008 | Hotpoint Washing Machines
Specialized S-Works Enduro SL Carbon Logo
104 people viewed this question
Top Specialized Cycling Experts
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
richie46
dante
Are you a Specialized Cycling Expert? Answer questions, earn points and help others
