Question about Technics SA-DX940
Speakers distort when connecting to a laptop. is connecting via phono the correct way?
    Master:
  • 400 Answers
No, the phono (phonograph) input is only for record players. Use any other input.
Posted on Jan 23, 2016
Connect my BA7800 to my laptop that only has a headphone jack
As you stated in your question there are 3 3.5mm headphone jacks connected to the speakers. Green is for headphones, red is for microphone, and black is probably just a line in connector.
plug the green connector from the speakers into your headphone port on your laptop and it should work.
because the speakers are self powered and have a few adjustment knobs on them, you will have to tinker with the volume coming from the laptop and from the speakers, so you don't have distorted, scratchy sound from the speakers when playing music at loud levels.
my suggestions is turn the laptop volume down to a quater of the volume and then turn the speakers up, let the speakers do the hard work and not the laptop..
Jan 04, 2015 | Boston Acoustics Audio Players & Recorders
Why won't my a102 speakers from jamo witch came
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Sep 01, 2014 | Audio Players & Recorders
My a102jamo surround sound speakers and working
Aug 31, 2014 | Audio Players & Recorders
I brourt a jamo sub 200 and five a102speakers but
I have connected Pioneer PL-990 turntable to SX-255R receiver through PHONO but get static and distortion through speakers. Manual says to connect to AUX not PHONO but cannot see AUX on receiver. Any...
You need to hook it up to another analog input other than the phono input. The record player has a built in preamp, and the receiver's phono input has a separate preamp for non-amplified players. You cannot have the two hooked to each other.
Jan 28, 2013 | Pioneer SX-255R Receiver
Marantz nr1402 how to connect turntable
Connect turntable out to phono preamp In
Conect Phono preamp out to your Marantz NR1402 vacant analog input.
On your TV , if audio out is available connect it also on the Marantz
vacant analog input 2
Aug 01, 2012 | Marantz Nr1402 Av Receiver
I just bought a receiver, Turntable, and bookshelf speakers. Everything got hooked up but I have serious distortion coming from the speakers. Did I hook it up wrong? What could cause this and how should I...
Distortion using which source(s)? Keep in mind a turntable is basically a microphone for room-born vibrations and loud sounds so it may create feedback. And a TT without an onboard Phono preamp will require connect to one in your electronics. It will be labeled explicitly "PHONO" and only a TT should use it.
Fill in all the make and model details and how you have it connected.
Jan 17, 2011 | Klipsch B2 Synergy Main Stereo Speaker
I am using an Onkyo TX-8255 receiver with the ION Profile Pro USB Turntable and I'm hearing distortion through my speakers at all volumes. The speakers and the receiver work fine with the radio and the...
The TT should be connected properly for the way it's configured (Line Level Out to any Line Level In OR Phono Out to Phono In) and NOT any other way.
Some background reading:
http://en.wikipedia.org/wiki/RIAA_equalization
Jan 15, 2011 | Onkyo TX-DS474 Receiver
Hi, i have the Lexicon Alpha Personal Recording Studio connected to my mac via USB. im running two powered speakers via phono to phone lead. When i try play music through the speakers it doesnt play...
Make sure you have NO antivirus/antispyware/antiadware or other resource hogging background programs running while processing the audio. These programs hog resources to the point that the buffering within the audio devices is overrun causing gaps.
Nov 22, 2010 | Lexicon Alpha Personal Recording Studio
Using a tube pre amp with my CA Azur 640A?
There are many answers to your questions but Ill have a go with the basics...
Audio connections should be matched.... its called Frequency impedance,.... to get a signal along wires or cables (or Fibre) the Impedance of the cables and wires must be matched to the device they are connected to transfer the signal along the cables without distortion...
Manufacturers provide many sockets on the input side of amplifiers and preamplifiers to allow the consumer to connect various devices of different impedance.
They label these inputs like CD, or Tuner, or PHONO etc etc,
That means if you have a CD player it must be plugged into the CD input socket then the impedance will be correct and the sound will transfer along the CD cables correctly, without distortion..same with the Phono input etc...
You will find on the sound output to the speakers terminals are also labelled 4-6ohm, or 8-10ohm, these are the impedance expected for the coil ratings of the speakers them selves and its important to get the correct speakers to the correct out put terminals...
In your case all you have to do is follow these simple rules and all will be well....you say you have a squeeze box well there probably isnt a port labelled squeeze box so you need to experiment and try out each input port for the squeeze box to see what input gives you the correct sound output...Watch the Phono inputs as these are very sensative to input sound levels and must be treated very carefully as they have a double stage of sound amplification and as such you need to have the volume right down when connecting up the Phono inputs then increase the volume carefully after the cable connections are completed.
If you follow these rules then all will be well,,,,there is no difference if the Pre amp or Power amp is valve or transistor or FET or has IC outputs to the speaker the same impedance rules apply..just treat it as a box with input and output terminals and all the impedance will be taken care of for you...if you read the lables...
You need to connect you signal source to the Preamp inputs the out put from the Preamp connects to the power amp input then the power amp output goes to the speakers. this is a basic configuration for sound systems, there are other variations but are outside this discussion.
Cheers From YUBEUT
Nov 12, 2007 | Cambridge Audio Azur 640A Amplifier
Technics SA-DX940 Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
