Question about Troy-Bilt® Briggs and Stratton Chipper
10 hp Troy Built chipper pull start frozen
My chipper was running fine. Ran out of gas and now the pull start won't turn. It appears to locked up. Is there a safety switch.
  • 47 Answers
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Posted on Jun 22, 2009
How can I make my old 5 hp Craftsman chipper-shredder Model #247.795940 run?
The pilot jet is probably clogged. Take the fuel bowl off the carburetor and look for the hole that passes from the top of the bowl into the main venturi of the carburetor. Try spraying carburetor cleaner spray into the hole; if it doesn't come out in the venturi, it's clogged. Take a really fine wire (a single wire pulled from a wire brush will usually work), and slide it up until you see it protrude into the main venturi. Once you open the orifice, spray carb cleaner throught it. The thing should run after you put it all back together.
Jul 09, 2014 | Heavy Machinery
Sears eager 1 5 5 hp
If its been a while since you used it, most likely bad gas. Ethanol can pull water out of air, so there may be a little in the tank, also. Siphon it out & dispose of it properly. Get as much as you can out. There should be a little drain valve at the bottom of the carb. Drain it into a container. Put in fresh gas, make multiple attempts to start. This pulls fresh gas into carburetor. Also buy a new spark plug. Check for mouse nests around air intake (happened to me with a garden tractor). Check air filter, replace if it looks dirty. Buy a can of carburetor cleaner, follow directions. That covers all the possibilities, I think. BTW, to prevent future bad gas problems, don't just turn off the engine unless you plan to use the machine again soon. Turn off the fuel valve and let engine run out of gas. That keeps old gas from leaving gum in the carb over a long period. I do this with my snow blower every time I use it. Any snow can be the last snow of the season. This applies to every small engine, of course, not just chippers.
May 26, 2014 | Heavy Machinery
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I PICK UP A 3250 TROY-BILT GEN AND RAN IT 1 FULL TANK OF GAS OK. THAN WE GOT A SECOND STORM FILLED TANK AGAIN LET RUN FOR ABOUT 6 HOURS AND IT STOPRD. WHAN I THAUT IT RAN OUT OF GAS I REFILLED AND TRYED TO...
pull plug and try to pull start if moves than it was vapor locked clean plug and try to start if no movement with plug out than internal engine or pull cord jammed
Mar 03, 2010 | Troy-Bilt® Briggs and Stratton Chipper
I was using the pressure washer with no problems and then ran out of gas. I added gas and now it won't start. Any suggestions? There isn't a choke on the unit either.
If it is a gas powered system it will have a choke. It could be some sort of automatic configuration without a lever for the end user to adjust however so we'll start with the basics. All engines need fuel, air, and spark to run. Since you know that you ran out of fuel try cycling the engine without starting to get some fuel into the system. You can do this a couple ways but the easiest would be to disconnect the spark plug pull the string start or turn the key a couple times. While your at it you may want to pull out the spark plug and see if the point is fouled. A little WD-40 and some fine grit sandpaper will clean it up pretty easily.
You can also check the air filter / exhaust. the usually have some foam type insert in or around. if it looks melted and not spongy you'll wnat to replace it.
I have had a similar problem with my lawnmower and although they are not the same machine, the principals behind the engine operation are.
Let me know if you are able to get it running.
Feb 21, 2010 | Troy-Bilt Heavy Machinery
Troy Bilt Chipper/Vac 47282
There is a blockage in the outlet from the fuel tank, there is a filter in the tank and it is dirty. Try it anyway. Stephen.
Sep 21, 2009 | Troy-Bilt Chipper Shredder
Briggs engine/ genreator
change spark plug and add small amount of starting fluid to breather pull with all settings in proper place if it is going to start it will or you have other problems
Nov 04, 2008 | Coleman Propane Forced Air Heater...
Wood Chipper how to
Great input tina783. I have just one thing to add. Try to shred the branches within a reasonable amount of time. I found out that with my shredder, if I put older, dried up branches in, it tends to take a lot more time, as well as tosses chips back out at you. With newly cut branches, this wasn't nearly as much as an issue.
Aug 27, 2008 | AMANA TOOL 658060 PRESTIGE FINE DADO SET...
Troy-Bilt® Briggs and Stratton Chipper  Logo
599 people viewed this question
Top Troy Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
donald boissonneault
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
