Ricoh priport jp1010 master not being enrolled on the drum
Drum not rolling. Master not rolling round drum
3 Suggested Answers
goodgold
  • 389 Answers
SOURCE: Paper Sticking to the drum
Check in what condition separators drum.
Posted on Sep 20, 2009
SOURCE: ricoh drum digital duplicator
There is a company that repairs duplicator drums. They specialize in "rebuilding" duplicator drums. Our duplicator dealer uses them for drum repair.
Their website it www.arico1.com.
Posted on Oct 23, 2009
Ricoh VT6000 lcd is on but no commands will respond. Have tried everything in the manuals. What's next ?
Ricoh VT6000 and postscript controller cpif-26 ' Adobe Community ...
https://forums.adobe.com/thread/1718082?start=0...0
Adobe Systems
Feb 27, 2015 - 2 posts - ‎1 author
Have printer Ricoh VT6000 - very old but good and still working, have ... But there isno drivers for CPIF controller and also for printer for new windosw 7 for example. ... Canyou advice what to do to install those printer and controller on win xp? ... Dov Isaacs Feb 27, 2015 9:23 AM (in response to witer30).
[PDF]UC5Operators 1-5.PM6
rfg-esource.ricoh-usa.com/stellent/groups/public/.../rfg000936.pdf
or transmitted in any form, including but not limited to electronic, photocopying, mechanical ... holders. Ricoh and PriPort are registered trademarks of Ricoh Japan. ....VT6000/5390/1295/CP390/3400DNP/SD600. ZipRIP Pro A ... Once the UC5 has been installed, you will need to install a GDI printer driver. Please follow the
Jan 18, 2016 | Ricoh Priport VT6000 Copier
We have a Ricoh Priport HQ9000 which keeps jamming at the paper entry and we are getting a small mark in the middle of the paper
check the rollers well. sometimes they get grime an dust into them and stick or roll rough an hard or not at all. just a touch of spray cleaner works.
Jan 30, 2015 | Ricoh Office Equipment & Supplies
What does error code E-06 mean on a ricoh priport duplicator mean?
It's a main motor error. Check the sensors at the back when you remove the drum. Check to see if the sensors are in place.
Jan 21, 2015 | Ricoh Office Equipment & Supplies
I just got the Ricoh VT6000 and I can not figure out how to properly load the master
as far as i remember press the green button on the right side of the machine while pushing toslide the scanner. move the green lever to up to insert the master between the two roller the rubber and the foam rollers then down the lever to lock. press the green buttom located on the right side to load the master. while loding move the green lever up down up down to balance the weight on the master to avoid skewing then down to lock. hope i help, good luck
Sep 01, 2011 | Ricoh Priport VT6000 Copier
Ricoh DX4640PD priport machine with SC556 code - what is this, I can't get past it to open the drum unit or anything? Thanks
And how about error code SC553?i try log in test mode and use program clear mermory.the machine still code SC553
Apr 04, 2011 | Ricoh Priport VT6000 Copier
I can not open the master roll unit. I push the button and do not hear the beep or get a green light. Unit will not pull out
if you look on the front cover of the master roll unit you will see a small round hole take a screw driver and push it in the hole when it wont go in further pull on the lever and the drum should come out
Mar 22, 2011 | Riso RZ220 Duplicator
I have the d17 error message. I did try to reset it but it still shows the error.
D17
236 - incorect master roll
237 - master roll undetected
238 - master roll communication error
239 - wrong master roll detect
241 - detected a mismatch in master roll information
you must stop the machine and remove the cable from the print drum PCB and check that there is no ink on the connector or the PCB.
If there is no ink try to enter in test mode and activate 0890 test.
If it dose not work call for tech from Riso.
Dec 01, 2010 | Riso RZ220 Duplicator
Sep 06, 2009 | Riso RZ220 Duplicator
Ricoh drum digital duplicator
Apr 20, 2009 | Office Equipment & Supplies
I had a Master jam while making a new master. Code A-04-303
Under the drum and master unit is there a round openning .Take a sckrew driver and push it in there to unlock the master and drum.Remove the jam and switch riso off and on.
Jan 16, 2009 | Riso RZ220 Duplicator
18 people viewed this question
k24674
