Question about Dynex 32 in. LCD Flat-Panel HDTV
Dynex tv, want to use VGA input to use as the monitor. Get blank screen. On TV, selecting VGA it states "not support". What am I doing wrong?
3 Suggested Answers
jamielwright
  • 75 Answers
SOURCE: Dynex 19Inch Vga no signal
You may need to set up the video card to see the TV so you can display the computer on it.Somewhere in the setting for your video card should be settings for that.
Posted on Jun 01, 2009
  • 89 Answers
SOURCE: Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
Posted on May 09, 2011
I am trying to connect a Toshiba flat screen television to a gateway laptop but am unable to get a picture on the TV once connected.
Do your tv have vga input if yes connect to it asn connect the other end to u\your laptop vga out and then go to the display setting it will be detected in the setting tab one detected just check the checkbox stating extend my desk to to this monitor by selecting the monitor 2 thats it.
cheers
May 16, 2011 | Computers & Internet
How do I see VGA in put on screen
First, is the TV the only connected monitor? Second was the TV on and set to VGA (press the Input button and then up/down arrows) before the computer was turned on.
If you are seeing an invalid mode message and the TV is the only monitor attached, you need to shut down the computer and leave the TV on the VGA input. (Turn off the computer or press CTRL-ALT-DEL twice.) If this doesn't work, you may need to use another monitor and adjust the resolution output for the computer's video and then connect to the TV.
If you have another monitor, you may need to make sure that the VGA port is enabled. (Some laptops will have this disabled in the BIOS. Depending on the brand of computer, you can access the BIOS by pressing Esc, F1, F2 or F10 repeatedly just as you turn on the computer.) Next you may need to adjust the active display. In Windows 7, right click on the desktop where there are no program icons or windows. Then select Graphic Properties. Set the computer for monitor 1 or 2, extended display or both (at least on my HP laptop). Click Apply and then confirm your . (alternatively: Start > Control Panel > Appearance and Personalization > Display) For my desktop, this is set under Screen Resolution in the same manner.
I hope this helps.
(at least on all of my computers, if the TV is on first, Windows 7 will autoset to the best resolution that the graphics and monitor can handle.)
Apr 19, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
My TV signal source is a cable/satellite digital box. The setup screen correctly takes me as far as "Select correct input source for set top box." At this point - instead of leaving the...
I would suggest using dedicated input button on remote, not the menu on the tv. If you can skip setup screen that would be best. I have just looked at the manual for that tv, it tells you all you need to know, depending upon which input you used for your box. As I stated use the direct input button on the remote if you have it.
Oct 12, 2017 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
What settings do I make to connect my laptop to my DYNEX Tv
Please select the PC input on the dynex remote using the input key,then try shutting down the computer and restarting it .
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Laptop to TV connection problem
When your laptop boots up, Windows treats the second monitor (your TV) as a mirror of the primary monitor (your laptop screen). When Windows loads up and finishes initializing the more advanced features, it goes back to it's default setting of a single primary screen, and the secondary screen is in standby, waiting for you to do something with it. The fastest way to get the TV working would be to find the Function key on your keyboard (normally a purple-ish blue key labeled Fn) and the monitor switch key. The video switch key is normally in the Function key row (F1, F2, F3, etc...) and has the picture of a rectangle or TV-looking shape. Hold the Fn key down and then press the video-switch key once and see what happens. Lenovo laptops normally bring up a little on-screen program that allows you to pick which configuration you want. Good luck!
Jan 14, 2010 | IBM Computers & Internet
Jun 01, 2009 | Dynex DX-LCD32-09 LCD TV
Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
May 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Acer notebook hook-up to T.V
You can! But you need a modern HDTV. If you have one, simply buy a VGA monitor cable. Hook it up to the laptop, (you can't get it wrong). Then put your TV on the VGA input. Hook up the cable.
If you have a Windows Operating System, right click your Desk Top in a blank area and select "Properties."
Then choose the settings tab. Click the 2 monitor and check box will appear asking to "Extend to this monitor." (paraphrased ... I don't recall exactly what it says).
Check the check box then click "OK" and BINGO ... There it is!
Apr 07, 2009 | Acer Extensa 5420-5687 Notebook
19'' Dynex TV does not come up as a Computer Monitor.
Follow these steps on the remote :
Press Input,
scroll down and select VGA.
Nov 17, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
498 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
