Question about D-Link DIR-600 Router
Connection for pppoe
I have internal atenna
  • 30 Answers
Be more explicit...
But I can answer, in generally.
connect a cable from one LAN port to your PC , open a browser and access http://192.168.0.1 with username "admin" and no password. Go to "setup" > "internet" > "manual internet connection setup", there you must select "PPPoE (username / password)" and put your username and password from your ISP, or from where you connect.
That-s all.
Posted on Sep 21, 2014
What type of adapter do i need to connect my two stock cb atennas to my cb on my 2008 peterbilt
Without seeing the ends I cant help you here but I can steer you towards Allied Electronics. Give them a call and tell them what you have. They should be able to cross reference for them or have converters available.
Mar 02, 2014 | Uniden Radio Communications
What to insert for PPPoE Service name to connect to internet
PPPoE stands for Point-to-Point Protocol over Ethernet, it's basically authentication for ISPs that use Usernames and Passwords to get you connected to the internet. If your ISP uses PPPoE you'll have to change the 360's settings to connect to the Xbox Live service.
Your PPPoE info should have been given to you when you signed up for your internet service(some ISPs even print the info somewhere on your hub/modem), otherwise you'll have to call them up and get the info from them. It's also important to know that if you're ISP doesn't use PPPoE you should leave these settings blank on your 360 or it won't connect.
Since you haven't connected to the live yet I'll assume you're still on the older dashboard so it should go like this:
1. Move to the System area of the Xbox dashboard.
2. Select Network Settings.
3. Select Edit Settings.
4. On the Additional Settings tab, select PPPoE Settings.
5. Use the on-screen keyboard to enter the PPPoE information that was provided to you by your ISP.
6. Select Done.
7. Select Apply and Test when you are prompted to do this.
Sep 03, 2012 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Wat is my PPPoE user name and passeord?
Hi It is the connection type of your internet service provider. If your internet depends on user and password then it needs pppoe . for that you need to configure router in pppoe mode but you can also create pppoe connection on your computer so just need to enter user and password of ppoe on computer then you can use internet on that computer. Let me know if you need further assistance.Thanks for using FixYa.
Nov 17, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
New dir 625 with DSL-cat5 connection and NO internet on status.
If it keeps on trying to connect to PPPoE, try not to use PPPoE setting. Use Automatic Configuration or DHCP connection type.
Jun 10, 2009 | D-Link DIR-625 (790069292637) Wireless...
Radio does not work
put a wire in the antenna hole while radio is on if you get some reception then you know its your antenna do you have sirius if you do it sometimes it runs through your antenna if you dont then check your antenna wire where it connects to the antenna good luck.....
Dec 28, 2008 | Pyramid PDVD79 CD Player
Hacker tried to get into my computer
192.168.X.X is an internal network address...your "hacker" is either in the same room, or at least on your network, the other is an IP in San Francisco, CA, and PPPoE is a very unlikely method for a "hacker" to use, it's actually a very secure method of connecting 2 computers over the internet.
Mar 14, 2008 | Computers & Internet
Can't connect to 3Com Office connect wireless from Apple Mac Pro
PPPoE connection is set up
1. Control Panel, double-click Network Connections. 2. Click the PPPoE connection under the Broadband group that you want to share, and then click Change settings of this connection under Network Tasks. 3. On the Advanced tab, click to select the Allow other network users to connect through this computer's Internet connection check box. 4. PPPoE connections behave in a similar way as do dial-up networking (DUN) connections, and you may want the connection to be automatically dialed when another computer on your network attempts to connect to the Internet. To do this, click to select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box. 5. If you want to allow other network users to enable or disable the shared Internet connection, click to select the Allow other network users to control or disable the shared Internet connection check box. 6. Under Internet Connection Sharing, in Home networking connection, click the LAN (Local Area Network) connection that connects the computer that is sharing its PPPoE Internet connection to the other computers on your network.
Feb 07, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
How do I get rid of the router using an automatic private address which keeps disconnecting?
the router will give you a private address , that is the functionality of the router, the problem is not with your connection, try to upgrade the latest firmware inthe router and reconfig the router in a pppoe mode that will fix your problem..
Dec 20, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
Can not connect to PPPOE DSL
Is there a reason why the Sonicwall needs to do the PPPOE auth? You should be able to let the modem do the PPPOE connection and have the Sonicwall behind it. The Sonic wall will get a private IP address. Andy
Jun 21, 2007 | SonicWALL TELE2 Firewall
D-Link DIR-600 Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
