Question about Coleman Heating & Cooling
Squirell cage blower motor runs all the time
I have a Coleman Suncutter packaged air conditioner model number 7436-901. The band mount that holds the blower motor for the condenser broke I replaced the band. Took several days to find one for it but I accidently wired it back up backwards and the unit would not run so I reversed the red and black wires and it runs now but I think I fried the relay or start capaciter not sure what you call it but the unit runs and cools but when the thermostat cuts off the unit the blower motor continues to run. Did I blow the capcitor or relay. Thanks
  • 614 Answers
Relay. You may just have it wires wrong but relays are easy to replace. Rus
Posted on Jun 14, 2009
I have a blower fan rattling my house in the attic. I am looking for the set screw to see if maybe it rattled loose, does anyone know where that might be.
the set screw is on the squirel cage you need an adjustable wrench but as check all mounting brackets and possibly a belly band that goes around it held by a nut/bolt but that motor may not have that feature
Sep 14, 2010 | Heating & Cooling
Does not blow hot air on heat
tURN THE THERMOSTAT TO FAN ON TO SEE IF IT,LL START, IF IT DOES, THE SPIN THE SQUIRELL CAGE BLOWER WHEEL WITH A STICK TO SEE IF IT,L TAKE OFF, IF DO THEN ITS THE CAPICATOR. TRY TO SEND 120V TO THE FAN MOTOR TO SEE IF IT,LL START IF DOES THEN THE C. BOARD IS THE PROBLEM.
Dec 02, 2009 | Ruud UBHC Air Conditioner
There is not an air filter in the unit and we have just purchased the home with the unit in it. I need to know where the filter goes, Tjis a coleman evcon central air unit
You should be able to open the lower panel on the Central Furnance unit and the filter would go against the side where the main cold air return plenum is located. There is usually either a slot/edge for the filter to slide into, or a set of clips or a wire spring that holds the filter in place, preventing it from getting sucked into the squirel cage blower.
If you want to give Coleman a call at 1-877-726-5362, I'm sure they'd send you a owners manual for your unit so you can see what periodic cleaning and such is needed to keep it working properly.
Hope you found this info helpful. Best Regards!
Aug 05, 2009 | Coleman Heating & Cooling
My squirel cage blower motor fails to start
Hi there the main problem is the run capacitor on the side of the blower cage has gone bad.
But you have replaced that..
The Next Problem is that one of the magnets inside the motor had demagnetized and is not allowing the cage to freely start But makes since that you can hand start the motion of the motor
Need A New motor Sadly to say
But sometimes you can have them rebuilt for less than a new motor
Any other questions just ask
Bryan
Jul 08, 2009 | Goodman CKL42AR42 Air Conditioner
Compressor and outdoor fan runs indoor fan does not. Has 230vac can't find capasitor has GE ECM motor carrier package unit 2 ton
cap usually mounted to blower housing with power off turn blower wheel if rough bad brown wires from motor should lead to cap if replacing motor get new mount belly band also and make sure rotation is correct reversable motor hope this helps
Jul 06, 2009 | Heating & Cooling
Replaced blower motor on coleman ac
You MUST always replace a capacitor when you replace a capacitor start/run device.
Replace the cap.
May 24, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
194 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
