Question about Canon imageRUNNER 5000 Copier
How to clean my canon ir5000 and how to keep it save from dust.
If any paper stucked in the middle , why and how to change the part that it makes it sticks . i need a trick that keeps my copier good all the time by safekeeping or clean it or anything and what tools i need if in case my troubleshooter is not available, thx alot and plz i need aquick ANSWER.thx again
    Sergeant:
  • 199 Answers
If paper jam before fixing check fixing gears, if paper jam in the middle of copier then check sepration carona and drum finger.
Posted on Jun 15, 2009
  • Sunil Rathod Jun 16, 2009
    use vaccum cleaner
How to change A4 display to LTR display
Go to Printers and Faxes, right click on the printer icon and select Printer Properties.
then select the paper type as LTR.
If in case you do not get the option, re-install the printer drivers.
Sep 08, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
Why is canon ir5000 caset do not stand up?
Verify the cassette /paper tray sensor actuator and paper tray motors.
Jan 23, 2012 | Office Equipment & Supplies
CannonMP495- paper jam when there isn't
Because there might be small dust/paper part would be stucked at the roller sensor just make sure and make it clean you can find some dust or small paper piece stucked with your roller so its showing paper jam error when theres no paper inside.
Aug 12, 2011 | Canon PIXMA MP495 InkJet Printer
Jam 0205 in ir5000 canon machine. Please give me
there could be a small piece of paper stuck wehre the vertical path sensor is. it is showing a stationary jam at the vertical path 3 paper sensor. there is more than likely a sensor that has become wedged or has a piece of paper holding the sensor closed instead of open in or around drawer #3
Jun 11, 2010 | Canon imageRUNNER 5000 Copier
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Canon IR5000 not running 20 lb. will run 60lb. and cover. 20 gets stuck in middle
If it's getting stuck in the Middle , I am assuming it's getting stuck right a the fusing section, Ok if it is running 60 lbs of paper greatly but, jams in the Middle , this tells me your fuser needs to be adjusted, This is something you don't want to do if your NOT a Service Technician most likely if your fuser was adjusted for 60lb paper the temperture was also adjusted so the paper won't be too too hot, I am certain your fusing unit will need to be adjusted or the Upper fuser/Lower Fusers are worn. Yea, you'll have to call a indiepent or an authorized dealer for this, unless you know how to rebuild the fuser yourself- be careful- this is exteremely hot unit.
Mar 04, 2009 | Canon imageRUNNER 5000 Copier
Canon iR5000 Tray 3 problem
look behind the tray and see if there is paper stuck behind the tray. Good luck
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
I need help.
If your priter is showing a 241 paper jam and the paper stops in the paper tray or lower front, then you can replace the pick rollers to fix this problem. If the paper stops in the middle, then check to make sure the sensor flag in the middle left of the printer is clean and in place. If the jam is in the back of the printer then check the fuser rollers to make sure that they are rolling when the printer starts to print, check the exit sensors on the fuser, there are usually two flags, one on each side of the fuser. If there is no paper stuck in the printer, then make sure that all sensor flags are up and not stuck halfway down. Or check for dust in the sensors.
Apr 04, 2007 | Lexmark Optra T614 Laser Printer
Canon imageRUNNER 5000 Copier Logo
155 people viewed this question
old marine
old marine
