Question about Food Mixers
Age of a Hobart Stand Mixer by Serial No.
Locate age & value by of mixer by serial no.
    Scholar:
  • 109 Answers
The ML or spec number would be trackable from the resource site.
Enter the model number and check the date of the corresponding build number.
https://my.hobartcorp.com/resourcecenter/Pages/FilterByModel.aspx
If it does not have a safety cage fitted, there are some areas of the countyr where it can not be used commercially, untill one is fitted. Depending on the model, that would be a thousand dollars or more.
Posted on Mar 23, 2014
Trying to find the age of a Hobart Mixer serial number 1569386
Contact hobart directly, they tend to keep a record of machines, and would probably be able to as sit you
Feb 15, 2018 | Hobart Food Mixers
Age of mixer Serial # 11-064-362 A-200
Id contact Hobart. the serial # doesnt use a date code. Hobart Contact Us
Sep 02, 2015 | Hobart Food Mixers
Age of my a-200 mixer
if it has a spec.# instead of a ml.#it would have to be at least 25-30 yrs. old
Jul 04, 2009 | Hobart A200 Stand Mixer
Hobart A200 age and lubrication
No, do not use Shell or Chevron grease or oil.
It will damage the gears and the interior of the machine. You must use food grade grease.
If you use industrial heavy duty grease you might have trouble with the local Code Enforcement ( if this machine is used in a restaurant or bakery )
depending on your state's rules, laws.
Here is a website for the grease:
http://www.foodprocessing.com/vendors/products/2008/039.html
You might want to check out my website too:
http://www.jgbakeryequipmentrepair.com/
About the age, hmm.. sorry but no i don't know anything.
Jun 17, 2009 | Hobart A200 Stand Mixer
How to find the age of a Hobart N50
Hi Anne. Call your nearest Hobart parts place. The parts guys will be able to tell you the age and which plant it was manufactured in in the USA. Another source is the hobartservice.com website, look for discontinued products under the food machines group, then select mixers and browse until you find the file that dates machines. One thing to watch for when buying is oil leakage that appears to come from the bottom of the stand. This indicates that the transmission grease is partially separating the oil out of it and it's leaking out of the rear bearing and dripping down. If the leak seems excessive, pass on the purchase. This drip could also indicate excessive wear on the bearings. Also run the mixer in all speeds, if is sounds like a tank approaching, it probably needs a rebuild.
Aug 17, 2008 | Food Mixers
Age of a-200
There is a two letter code that translates to the month and year. You would need to call Hobart to translate. 1-937-332-3000
There are hints to the age, first two digit of the S/N is the factory. "11" are the older ones, spec vs ml on plate, type of power switch, bowl gaurd....
May 16, 2008 | Hobart A200 Stand Mixer
Hobart A-200 serial # ?
Hi. Your mixer was manufactured in 1967. If you plan on keeping it, take the outer cover off, gently remove the two metal dust caps with a small screwdriver and look into each opening with a good flashlight to determine the quality and amount of grease in the trans. case.
Ideally the grease should almost fill the space with no oil visible. If you need to look further, I suggest that you open up the transmission cover, to determine the condition of the grease that lubricates the transmission. If you find that oil is seperating from the grease. you would do well to remove all of the oil and old grease and replace it with either Shell Darina EP-2, or Chevron FM ALC EP-2 grease. It's a messy job, but it will add years of life to your mixer.
Check the planetary seal, remove, clean and regrease the planetary gearing. With a mixer of this age, you never know if it has ever been serviced since it's manufacture or not. The grease must totaly encapsulate the trans. gears. As the grease breaks down it's level lowers and it leaves some of the upper gears without lubrication, and will result in preventable wear.
Good luck! If you found this solution helpful, please rate it. ricardok45
Mar 02, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
1,158 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
