Question about Simrad 000-10345-002 - NSE12 Navigation Pack w/ 3G Radar
Simrad nss12 depth issues
Depth shows on sonar page. does not show up in data bar. data bar depth field on chart overlay shows "---". simrad nss 12 display with nep-2 network switch, bsm-1 sounder module and airmar ss60 transducer. Please help!
5 Suggested Answers
  • 13 Answers
SOURCE: Simrad Autopilot won't turn on
Try and turn on the unit at the J300-40 pcb by using a test light one end to gnd and going to the ap35 interconnect and touch the test light to each pin or until you hear the unit start up.
Posted on Feb 10, 2009
SOURCE: i need a wiring diagram for a simrad qx44 sounder
simrad nse 12 with bsm 1 sounder does it need its own power or does it get it from the starter pack thanks richard
Posted on Feb 13, 2011
davidalfredw
  • 37 Answers
SOURCE: my Simrad GPS/sounder won't turn on.
assuming you have checked fuses etc you may have to use it as a lunch hook for your dingy...seriuosly..don't know ow old t is but a replacement is order methinks ...just like laptops they have improved greatly now and features abound screens are bigger and better...price has also dropped?
Posted on May 27, 2012
  • 1216 Answers
SOURCE: I went out to the continental shelf fishing in depth of 250 meters . My echo sounder is a simrad nss evo 16. I had problems while drifting the sounder would freeze how can I fix this
I did a search and found this as I don't own one not sure if this forum will help or not but thought I'd pass it on anyway.
Best to you.
https://www.thehulltruth.com/marine-electronics-forum/645739-problems-simrad-nss-evo2-chirp-structure-scanner.html
Posted on Jan 11, 2018
Simrad forward scan sonar will not show up on MFD. I have sonar hub and HD radar. Radar and mfd work fine just not seeing the forward scan
http://www.illumelashes.com/factory-3d-silk-lashes-manufacturer/3D Silk Lashes Factory 3D Silk Lashes Manufacturer China 3D Mink Eyelashes Factory 3D Silk Lashes Manufacturer China 3d silk lashes, fast delivery and wholesale mink lashes is directly from factory. OEM 3d silk lashes, black/clear band lashes is Available. Our 3d silk lashes is Super light, easy wear Private label 3d silk lashes and custom box bulk order with discount is available.
May 09, 2018 | Vehicle Parts & Accessories
Best to you.
Jan 11, 2018 | Simrad Boating
I want the screen split showing chart/sonar with trails on the chart. How do I do that?
I don't know what unit you have, but here goes.. go to "pages" scroll to map, scroll to "map with sonar"..hit enter..
Jun 13, 2017 | Boating
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Just purchased and Eagle Fishmark 320 used. Will not display depth reading - just shows 0'0"? I have reset to factory settings. We have had in lake,same thing. Right now in 5 gallon bucket of...
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/seafinder320df_0143-661_101602.pdf
Let me know how you make out....Guru....Saailer
Sep 11, 2011 | Eagle Fishmark 320 Portable Fishfinder
My lowrance sturcture scan shows the bottom and depth but doesn't show structure
don't quite understand what your saying far as the question..when you click the page button on your unit does it show structure scan on the page and if so you go into structure scan and its not showing structure on the screen ?? maybe you need to (fine tune ) your unit or check your transducer to see if its working
May 28, 2011 | Lowrance LSS1 StructureScan Sonar (Lss1...
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
Hello- My 332c will not show speed. It worked before.The spinner wheel is not damaged.Speed just flashes 0.00 mph Thanks, Jeff
Try setting up the speed in the overlay data menu again:
1. Press MENU, arrow down to OVERLAY DATA and press ENT
2. Highlight the option for speed (WATER SPEED or GROUND SPEED) and press ENT
3. Highlight the REMOVE button and press ENT
4. Highlight (PRESS ENT TO ADD) and press ENT
5. Arrow down to SONAR DATA and press ENT
6. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box
7. Press EXIT twice
If the speed is still flashing, the data is still invalid. Try resetting the unit completely:
1. Turn unit off
2. Press and hold the PAGES and POWER key until the "DO NOT RELY..." alarm appears
3. Set up the overlay data for speed again: 1. Press MENU, arrow down to OVERLAY DATA and press ENT; 2. Highlight (PRESS ENT TO ADD) and press ENT; 3. Arrow down to SONAR DATA and press ENT; 4. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box; 5. Press EXIT twice
If the speed is still flashing, good chance the speed sensor is bad even though the wheel still spins. Install the latest LMS-332 updates from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/ and set up the overlay data again.
If it turns out that the speed sensor is bad, just use speed from the GPS. This can be set up from the overlay data menu as GROUND SPEED.
(note: the overlay data must be set up for each page individually. So if you set up speed to be displayed on the map screen, it will not also be set up on the sonar page)
Jul 12, 2009 | Lowrance LMS-332C GPS Receiver
How do you get the fish to show up on the screen on a lowrance X96 depth finder? We just got it and there is no manual with it.
Are you looking for the little fish symbols?
Press MENU, down arrow to SONAR FEATURES and press ENT. Arrow to FISH SYMBOLS and press ENT. Press EXIT twice. Any significant return in the water will now show up as a fish symbol.
Are you looking for the fish arches?
You won't get any arches unless the boat is moving and of course there are fish passing within the transducers signal. The shallower the water, the less area you are covering and less likely to get a fish return.
There is an OK guide to understanding what you see on the sonar screen at the link below. It if pretty technical but parts of it may help you out.
http://primus.lowrance.com/support/resultDisplay.do?gotoLink=5&docType=1000&contextId=351%3A5.47%2C11918.11930%2C22.47&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FSonar&contentId=9de88fa2-0b60-4b44-a470-29ee14767b3e&responseId=135ccbe2cfd4f608%3A1fe88d%3A122773df7e0%3A7c2&groupId=4&answerGroup=1&score=981&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FSonar%2FChart+Tutorial.htm&result=0&excerpt=Chart+Tutorial+Deciphering+Sonar+Charts.&question=chart+tutorial&resultType=5000#Goto5
An X96 owners manual can be downloaded from http://www.lowrance.com/en/Downloads/Manuals/
Jul 11, 2009 | Lowrance X96 200khz Fishfinder
Simrad 000-10345-002 - NSE12 Navigation Pack w/ 3G Radar Logo
Top Simrad GPS Experts
Will Halftowaite
Are you a Simrad GPS Expert? Answer questions, earn points and help others
