Question about Pioneer GM-X524 Car Audio Amplifier
How to bridge an amp to one sub
Would like to bridge this 4 channel amp to run one 12" comp kicker. how do i do it?
  • Pioneer Master
  • 637 Answers
Left positive and right Negative will bridge the amp. What ohm is that woofer?
Posted on Jun 18, 2014
zzedly
  • 300 Answers
SOURCE: prsx720
The specs I read on the Pioneer site say the amp is not 1 ohm stable, so keep that in mind.
It partially depends on the impedance of each voice coil on the DVC subs. If they are dual 4 ohm, and you connect the DVCs in parallel ("+"s together, "-"s together), you could run a sub on each channel of the amp(s). This would put about 200W on each sub.
The other option is to still tie the dual 4 ohm voice coils in parallel, tie 2 subs in series (one "+" to the other "-"), and bridge the two channels of the amp (aka put them in parallel). But this, also, would be about 200W on each sub.
Things get different if the subs have dual 2 ohm, 3 ohm, or 8 ohm voice coils.
Posted on Mar 16, 2008
LVT7857
  • 116 Answers
SOURCE: wiring
Usually an 800 watt peak sub would be a 400 watt rms. Hmmmm. Anyway, just bridge the amp (1x 380) nd keep the gain up enough to stay clean. Watch the sub and turn up gain until it starts to distort, then back it down a hair. Do this with the CD players volume up 2/3 to 3/4 volume with the BASS and treble at zero (bass better at minus 4 or so if you are a bass head! Hope thishelps.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
etirbynnor
  • 655 Answers
SOURCE: Ccan it be bridged with a 5 ohm subwoofer?
Hello cameron_cran,
The information I found on the amp is that is a 2-channel and is bridgeable. It is stable in bridged mode to 4 ohms. You should be able to bridge a single 4 ohm sub without damage to the amp.
Hope this helps.
Posted on Apr 22, 2009
  • 22 Answers
SOURCE: amp comes on running 2
This could be the reason. If you look at the specs for this amp you will see that the continuous power out is rated for 380W bridged. The speakers rated at 450W should be able to handle close to 315W continuous. Now if you split these numbers being you have bridged these speakers, you drive each one up to about 190W continuous. The speakers are being driven approximately by 60% of the rated capability. I personally like to keep it right where you got it, not exceeding 80% of the speakers rated capacity.
Here are the specs for the AMP:
  • Specifications
  • Peak Music Power 760 Watts
  • Number of Channels 2
  • Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
  • Continuous Power (4 ohm) 125W x 2
  • Continuous Power (2 ohm) 190W x 2
  • Continuous Power Bridged (4 ohm) 380W x 1
  • Frequency Response 10Hz ~ 50kHz
  • Total Harmonic Distortion 0.008%
  • Signal-to-Noise Ratio 100dB
  • Dimensions 12" x 2-3/8" x 12-3/4"
  • Features
  • Bridgeable
  • Channel # Capability 1/2/3
  • PWM Regulated MOSFET Power Supply
  • Screw-Type Speaker Terminals
  • Balanced Isolator Input Circuit
  • RCA Inputs 2 Channel
  • Input Level Control Hi-Volt (200mV ~ 6.5v)
  • Built-in Crossover Selectable LPF (80Hz, -12dB/Oct.)
  • Posted on Sep 10, 2010
    • 111 Answers
    SOURCE: i wired my dvc sub
    1. Check if your power cable is of adequate Gauge 2. Try turning the volume down from the amplifier gain level 3. You could even check to see if your battery is on it's way out and just cant feed the amplifier with the power it needs. (very rare case) do the car lights dim when the volume is not really that loud? 4. There could be an error on the way the subs are connected, double check that you have absolutely configured them to run @ 4OHM. could be checked with a multimeter before connecting to the amplifier. 5. Another rare case is sometimes the fuse block expands when it heats up on loud volumes and can have contact issues so try tightening the socket that the fuse goes into. 6. It could also be a problem with one of the sub woofer or even the amplifier. more details might help me better understand the problem, but i hope this helps. dreamsystems
    Posted on Feb 06, 2011
    What is the best way to wire two kicker comp r 12' s to a two channel amp for max bass?
    First, you need to know whether you have the 2 ohm DVC subs or 4 ohm DVC subs. Second, you need to know the minimum impedance the amp can handle (most are 2 ohm, some are less). Putting two voice coils in parallel will cut the total impedance in half (e.g. 2x 4 ohm voice coils in parallel = 2 ohms total). Putting subs in parallel will also cut the impedance in half.
    At one end of the spectrum, you could put the 2 ohms DVCs in parallel, then parallel the two subs, and bridge the 2 channels of the amp. That would put 0.5 ohms impedance on the 1 bridge amp channel. If the amp can do 0.5 ohms x 1ch, do it. Otherwise, you may have to run the subs on separate channels.
    Oct 23, 2015 | Kicker Car Audio & Video
    2 kicker cvr 12's in prewired kicker box with 1 wire terminal, kicker cx1200.1 amp. Whats the best way to wire this combo?
    Well you really can't run both speakers on one term. because you will over heat the amp , unless your amp is rated at twice the capability of your subs , Then if so , Try positive to one sub , then neg. to the other sub , then bridge the remaining positive to the remaining negative terminal , But it is really best to get a two channel amp for your subs !!!
    Sep 23, 2013 | Kicker Comp CVR 12 x 12 Car Subwoofer
    I have 2 12
    To be on the safe side without further information I would hook the two subs up in series leaving you with an 8 ohm load.
    Nov 12, 2012 | Kicker Solo-Baric L7 12'' Car Speaker
    I need help hooking my kicker cvr 12 to my direct 600 amp
    Is the sub a single voice coil or dual???? If its a single, just bridge sub to amp....(+ of one channel and the - of the other) amp should show where to bridge with a diagram near speaker outs. If its a dual voice coil, then run one voice coil to the left channel and one voice coil to the right.
    Nov 02, 2010 | Directed 600D Car Audio Amplifier
    I have two 12 rockford fosgates p3 hooked up to and 350.2 kicker amp i just got them so i hooked them up and my amp will keep turning on and off
    How may ohms are the p3's and how are they hooked up? Some amps won't handle less than 4 ohms bridged. Try running one sub to each amp channel.
    Also check power and ground connections.
    Useing too small of wire for power, ground can cause the same problem.
    Apr 17, 2010 | Kicker ZX1500.1 Car Audio Amplifier
    Kicker 8 inch 4 ohm subwoofer 200 watts rms?
    Max 200 W. You could bridge 2 channels of a 4 channel amp (or get a 2 ch amp and bridge it) and connect the sub. Bridging = connect + of sub to + of one channel, and connect - of sub to - of *other* channel. Check amp manual for instructions.
    Don't get a mono - most are 300W or more - might burn the coil during loud passages.
    Jun 22, 2009 | Car Audio & Video
    I have a kicker zx700.5 amp
    Hello aj_vidal22,
    Here's the link to MTX's sub page where you can view or download the information you need to properly wire the subs to your amp.
    http://www.mtx.com/caraudio/products/manualsQuickInstall/subs.cfm
    For maximum power, you'll need to wire the subs so that they present a 2 ohm load to the sub outputs on your amp. That will give you the full 420 watts RMS the amp is rated for. Likewise, you,ll want the run the front 4-channels at 2 ohms. Run separately, they produce 85 Watts times 4 channels, or if bridged, 130 watts times 2-channels. But if you run fronts at 4 ohms, they only produce 70 watts times 4 channels and your sub output at 4 ohms drops to 210 watts.
    Hope this helps.
    Apr 17, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
    2006 12" Kicker L7 4 ohm
    first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
    May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
    Bridging to 12 inch kicker competition subs to my 1000 watt alpine 4 channel amp
    I'm a bit confused. For Alpine amps, the "M" prefix is for monoblock (aka single channel) amps and the "F" prefix is for multichannel amps. The only M550 I find is an MRD-M550, which is a monoblock, not a 4 channel like you say.
    Unfortunately, I can't give you accurate help until we know weather it's truly 1 channel or 4 channel. Then I'll be glad to help!
    Mar 05, 2008 | Kicker 01C8VR4 Car Subwoofer
    How to brige 4ohm 12"sub primire by prioeer double coil
    You can't run TWO subs on the bridge!!!!! You will destroy the amp! Put ONE sub on EACH channel.
    Sep 14, 2007 | Kicker KX400.2 Car Audio Amplifier
    Pioneer GM-X524 Car Audio Amplifier Logo
    119 people viewed this question
    Top Pioneer Car Audio & Video Experts
    Michael Kovalik III
    Michael Kovalik III
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
