Question about Acer Aspire Computers & Internet
Turn off zoom
Turn off automatic zoom
Lens shacking automatically
I have a D200 with a Nikkor AF-S DX 18-200mm ED zoom, and I have a similar issue with the inside of the lens shaking when I turn it on, It turned out to be a problem with the vibration reduction motor inside the lens. I first noticed a problem when zooming that it wasn't smooth, as though the inside lens was catching on something. It turned out that a roller inside the zoom somehow caught the wiring strip inside the lens and damaged it, causing the VR motor to short out.
There are forums that tell you how to repair the problem yourself on that lens, providing that you can get the replacement parts. I elected to send mine in for a repair, and hopefully its going to cost less than $AU200.00
Dec 09, 2013 | Nikon COOLPIX L810
Icon very big how can i make it small
First of all try this: Tap the iPhone with three fingers twice in succession. The home screen icons will be magnified to 200 percent. To adjust the zoom level, touch the screen with three fingers then move them up to increase the zoom, and down to lower it. The next time you tap the screen twice with three fingers, the iPhone will automatically return to your custom zoom level.
If it doesn't help, follow the steps below and repeat the above (step 5.)
  1. Tap the "Settings" menu from the iPhone home screen.
  2. Tap "Accessibility."
  3. Tap the word "Off" next to "Zoom" to turn the Zoom feature on.
  4. Return to the iPhone home screen.
  5. Tap the iPhone with three fingers twice in succession. The home screen icons will be magnified to 200 percent. To adjust the zoom level, touch the screen with three fingers then move them up to increase the zoom, and down to lower it. The next time you tap the screen twice with three fingers, the iPhone will automatically return to your custom zoom level.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 09, 2011 | Apple iPhone 3G
Can i turn off the automatic feature so when i zoom in or out it will stay where i put it?
Yes you can in most of the devices. In the setup menu you untick the 'automatic zoom level'.
Dec 29, 2009 | GPS
Digital zoom do not work well. automatic zoom work 1/10 time and not very good
Unfortunately digital zoom never works well. It's best to turn digital zoom off in the menu and never use it.
This is for any camera!
Oct 27, 2009 | Canon PowerShot TX1 Digital Camera
My zoom is sticky
You can use rubbing alcohol and cotton swab and clean it.
Jun 23, 2009 | Quasar VM-D51 Camcorder
Zoom feature
What is the exact model number of your Sony camcorder? Seems its tele/wide switch is bad and requires replacement.
Jun 06, 2009 | Sony Handycam DCR-TRV20 Mini DV Digital...
Turn off the TomTom One auto zoom feature?
Turn on tt. tap screen, tap preferences, go to automatic zooming and disable it.
Hope this answers your question.
May 03, 2009 | Tomtom ONE GPS Receiver
How to achieve full zoom with a Nikon 55-200mmf/4-5.6G ED lens?!
1) What camera body are you using?
2) I do not understand your assertion that it automatically zoomed in. Zooming is a manual function. The automatic functions of your lens pertain only to focusing on of the subject so that your picture is sharp and ensuring that the correct amount of light is admitted so that you have a correct exposure.
3) Are you sure you were turning the zoom ring and not the f-stop ring? The zoom ring is labeled 200 on one end of the scale and 55 on the other. It is also the widest ring on the lens barrel. When you rotate it, the physical length of the lens will lengthen as you rotate it clockwise (viewed from behind the camera) and shorten as you rotate it counter-clockwise.
4) For reference, at 200mm the angle of view on your lens should be 10 degrees and at 55mm about 40 degrees.
Dec 27, 2008 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Lens stays zoomed out, no error messages
i'm sure it's broken(the camera) take it to a service and get it fixed....
Mar 26, 2008 | Canon PowerShot A460 Digital Camera
Power zoom function
If you have the difuser on the zoom does not work as it assumes you are at close range. Remove the defuser and try again, good luck , Bob.
Jan 05, 2007 | Nikon Speedlight SB-800 TTL Flash
Computers & Internet Logo
13 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
