Question about Sewing Machines
Bernina 200E stops stitching now won't turn on.
My Bernina 200 e would stop stitching in the middle of a seam. I could get it going by turning it off & on again but now it will not start at all. I had it professionally serviced in the USA but now I live in Singapore. I understand it's dual voltage but could never find how to switch the voltage myself even after reading manual every chapter. Any advice? Thanks.
  • 406 Answers
Here is an answer from another fixya helper it may help. Check out this solution to the Bernina artista 200 problem posted on...
Posted on Mar 24, 2014
Testimonial: "Thank you JEM for suggesting this solution I will check out the foot pedal."
  • 84 Answers
SOURCE: Bernina virtuosa 155
G'day.
Firstly, dont flood it with oil - it will end up making a mess for you!
What I'm going to tell you is basic, but work thru it.
1. take out the bobbin case and swing the two latcjes to the side so you can remove the hook. Inspect the point VERY closely. should be sharp and absolutely smooth. ANY burr or nick MUST be removed. (have you broken a needle recently??)
2. Lay the mahine on its back, refit the hook and lock into place. Put in a BRAND NEW needle With the bobbin case still removed and the machine turned ON and in MAXIMUM Zig Zag width, turn the hand wheel in the direction it normally rotates - towards you. When the needle swings to the Left and is on its wasy UP, the hook point must pass behind the needle a little before the eye of the needle reaches the arc that the hook point travels thru. Same on the Right swing. If it does, GOOD.
3. Wind an empty bobbin with GOOD QUALITY THREAD. It should wind on reasonably even and TIGHT. When you push your fingernail into the thread it must NOT be spungy. Insert bobbin into bobbin case (IN THE CORRECT DIRECTION). Hold the tail of the thread and allow bobbin case to dangle, it should not drop down until you give the thread a little jerk. It should drop a little then stop. Insert bobbin case into machine, thread top of machine CORRECTLY. Set top tention to normal, test sew.
Let me know how this goes.
Posted on Feb 07, 2008
SOURCE: Bernina Artista 200E
turn off the machine, push in the ctr or ctl button and hold while machine powers on yellow screen will come on touch the one that has the clock
Posted on May 27, 2008
RickE1
  • 202 Answers
SOURCE: Bernina 830
Pop the top open. (push up on each end with thumbs). With the top off and you watch the mechanism as you move the stitch selector up and down you will notice this moves between a forked shaped part on the right side in back that is supposed to click in place back and forth. Its very common for this to be gummed
up. Oil it and keep moving it back and forth and oil it again. It will
start clicking in and you will be in business.
Posted on Jan 03, 2009
  • 6 Answers
SOURCE: Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
Posted on Apr 11, 2009
bargainbox
  • 1388 Answers
SOURCE: I just bought a cs6000i sewing machine from USA. I live in Singapore. Why is there smoke coming out of my new sewing machine? Is there a problem with the voltage?
Yes 110v in USA not 220v which is what you have put through...it is fried
Posted on Nov 27, 2011
I have a chance to buy a Bernina 200e for $1000. It is very clean and only has 87 hours. Should I go for it?
we do not care what you do . this is a repair site . not a purchase advisory one
Jan 26, 2017 | Bernina Sewing Machines
I'm having trouble starting the stitching on my bernina 765 when sewing a 1/4 inch seam. I am using the patchwork foot and have tried the differential feed option which doesn't seem to help
Guess I'm confused as I thought differential feed was available on a serger but this appears to be a sewing machine. If you are having trouble beginning stitching, try using a piece of scrap fabric as a starter piece. Just begin your stitch in the middle of the scrap of fabric and slip the quilt fabric up to the scrap's edge and continue stitching from the scrap onto the quilt fabric.
Stitch Starter Sewist Running Board
Jan 18, 2017 | Bernina Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
Screen goes blank and then stops sewing. I have a Bernina Aura 440QE 8years old.
You should probably take it to Bernina for repair. Sounds like possibly a board or component.
Nov 08, 2015 | Bernina Sewing Machines
How to Turn Off the Bobbin Sensor in the Bernina Artista 640
make sure you're using the appropriate bernina bobbin, others can confuse the sensor. This video(by Bernina Boys) shows how to clean lint to prevent this problem which is what often causes this error. Or go into settings by pressing the diamond with right hand arrow inside of it. The eye with the speaker next to it should get you where you need to go to turn it off.
The manual on Bernina's website is here:
https://www.bernina.com/en-US/SupportData/BERNINA-Nah-und-Stickmaschinen/artista/Manuals/031508-50-04_0601_a640_EN
page 98 has the information you want.
Jan 22, 2015 | Bernina Sewing Machines
200E freezes up
A 200e that locks up usually need a memory and a firmware upgrade. The original 200's only have 32mb of internal memory. The upgraded mini print board that is used in the 730 has 64mb of memory. This 64mb board was used in the 200 as a upgrade and this stopped the lock up problem. Also over the years Bernina has improved the firmware and this also cures the lock up problem. The latest and probably last firmware version for the 200e is version 5, also called the cutwork version. The easiest thing for you to do would be to take your 200 to a dealer and have them install a 64mb mini print board and also upgrade your machines firmware to the latest version 5. Also if you have loaded embroidery designs in your machine, remove them as they use up the machines memory. When you get too many designs loaded even if you have a 64 MB board in your machine you can still have lockup problems.
May 28, 2014 | Bernina Artista 180
In the middle of sewing a tricot stretch stitch my Nina (model JE1918) stopped sewing all stitches EXCEPT straight stitch.
there could be a part inside that is damaged or worn,, it would be a good idea to have the sewing machine checked also to see if there is a adjustment need also.
Aug 28, 2013 | Bernina Sewing Machines
Needle won' go down
Unless it needs to be oiled, you may need a service call.
Jul 18, 2017 | Bernina Sewing Machines
Bernina 200 e freezing
I took my artista 200e to my local bernina dealer and my machine needed to be upgraded - it hadn't had a software upgrade since new. I got it back today ad it's now working fine
Oct 28, 2007 | Bernina Artista 180
Sewing Machines Logo
74 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
