Penseros Its something about our sense organs, like our eyes, ears, toungue, touch.
What are micro organisms
Micro organisms are members of both the plant and animal kingdoms that are too small to see with the eye. some are harmful and some are helpful to humans while most are necessary to life. some help to digest food while others are parasitic in nature while still others can cause ***** or disease.
Aug 02, 2016 | Miscellaneous
Over the last 1.5 years I have lost my sense of smell and taste. I seem to suffer a lot more with sinus or head colds than i used to. and now my tongue is sore. what if anything can I do
Go to your physician and give him every detail of your symptoms.
Ask him to do a complete blood panel and refer you to and ear , eye and nose specialist. A neurological checkup may also be in order
Feb 12, 2015 | Miscellaneous
Why when washing hands, faucet keeps shutting off.
Motion sensing technology is a great feature but has some limitations. The motion sensing is limited for one main reason if it senses motion to far away from the faucet the faucet would come on when you walk by so the motion sensor is very restrictive in it's distance and angle of sensing. When you first start washing your hands you probably bring them in close to start the faucet but then lower them or bring them further away from the faucet. This in turn takes your movement away from the sensing eye and the sensor stops sensing movement and shuts the faucet off. Try finding out what distances the sensors movement to see where it stops recognizing that there is someone using the faucet. this will give you an idea of where you have to stay when using the faucet to keep it sensing correctly. I know this seems like a loto f work to use something so intelligent but in fact the faucet is very dump and has a limited function pattern.
One thing to also check if the faucet was working fine but then just started to malfunction is that the sensing eye is not dirty, covered in mineral deposits or the lens is not scratch badly. All the above problems can cause the sensor to miss read motion or have trouble sensing motion. Since this is a moen they are usually very good about replacement parts.
Jun 10, 2014 | Moen One Handle High Arc Pulldown Kitchen...
What are the special nouns?
Special nouns are abstract nouns like names of qualities,emotions or ideas which can only be experienced and not physically seen,touched etc
example bravery,honesty,integrity etc
Aug 04, 2011 | Macromedia Computers & Internet
Nokia N8 problem. When making and receiving calls the screen go blank if in sun or when your hand is in front. when it is ringing and you pick it up its goes blank you cant see who is calling, it only...
You don't have to worry about this, actually there is a sensor in Nokia N8 which senses the heat of your body so that when your ear is touched with your phone during a phone call, the screen is automatically locked so that no button is touched or clicked accidently when your phone is touched with your ear; it is just due to the sensitivity of the touchscreen display.
Jul 22, 2011 | Cell Phones
Give me the 10 examples of the organs of the body that works together
each organ of our body helps other organ in some sense.
So you can say that heart provides blood to brain, while brain has a job of keeping heart running.
so there will be countless examples.
Each organ helps each other.
Now common organs helping others are
heart = supplies blood to all organs
Brain = keeps the job of running the organ
so if you want ten example then just bring about combination between the organs
Jul 13, 2011 | Computers & Internet
DVD drive is not reading or writing. It is 3.5 years old.
1st option is to purchase a lens cleaner and let it run through the recommended process. 2nd option is to open it and clean the lens(eye) with a ear bud with surgical spirits, but be careful not to touch the eye to hard with the ear bud, you will damage the eye beyond repair, normally it is dust that actually split the concentrated beam that read the data in several directions. disconnect power supply when working on electrical equipment
Dec 12, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
DVD player seems to have problem starting. The electric eye is travelling back and forth but it says "bad disc" to all my movies now? The movies work in another machine?
Hi there! Seems like a bad laser (eye). It is trying to read the disc but not able to focus properly. Depending on what you paid for the unit, it might be better to buy a new one. The cheapies last maximum 3 years. If you would like to try replacing the white flexible cable first it may save you a bit of money. Remove it carefully without touching the laser(eye) and go to your local repairer who can order it for you. You can try cleaning the laser (eye) with a bit of surgical alcohol and ear bud. Do not apply too much pressure on the eye as this can result in permanent damage. NOTE: The laser emmits invisible radiation which can cause blindness if exposed to for too long. So please do not look into the laser(eye) when operating. Best Wishes and Good Luck. JUS004
Aug 21, 2009 | Televison & Video
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
