Question about Denon Audio Players & Recorders
ATV wont start.
Have replaced plugs and coil. Engine turns but wont fire up.
hotrodtod38
  • 141 Answers
SOURCE: one coil wont fire 1994 ford ranger 2.3 liter
crank sensor or cam sensor
Posted on Feb 15, 2009
  • 3 Answers
SOURCE: wont start. no fire from the coil.
check the pick up in the Distributor
Posted on Mar 01, 2009
redbeard00
  • 957 Answers
SOURCE: no fire or spark
I think you have the VORTEC set-up, look at the CKP & CMP sensor, ECT, TP sensor, IAC, ignition switch, blown fuse/s, timing chain, Bad ground to engine, bad distribtor, bad spark-plug, wires, or distributor cap & rotor. What is the "rotary button"? Well let me know if I can be of anymore help.
Posted on Jun 11, 2009
  • 118 Answers
SOURCE: 03 ford taurus wont fire ,spins over,no fire
What you do is take either and old sparkplug from the car or pull one from the car and connect one of the sparkplug wires to it. Then with an insulated set of pliers hold the sparkplug so the electrode is grounded. Then have someone crank the car over. This is best done at night so you can see if there is a spark. During the day however you should be able to here a spark. If not probably a bad coil.
Posted on Jul 21, 2009
  • 293 Answers
SOURCE: Car will not start.Engine turns over but spark plugs willnot fire
I would say replace ignition coil, that might me the problem, otherwise it can be the ecu, which might have some electrical problems not allowing the car to stay running. Good luck.
Posted on Dec 29, 2009
It mayI have no fire going to the coil or from the coil to the plugs
Have you checked the wiring, the spark @ plug, Power to the coil???
Engine Won't Start No Spark - Auto Diagnosis Repair Help
aa1car.com/library/no_spark.htm
If your engine cranks normally but will not start because it has no spark, or it ... If an engine has a coil-on-plug ignition system with no plug wires, remove one of ...
No-start, No-Spark diagnosing simulated - YouTube
? 5:13
https://www.youtube.com/watch?v=XSWN1M8Hoqo
May 19, 2010 - Uploaded by FrankHurtAuto
Simulation of no start with no spark diagnosing, ... Ignition coiland module test with test light (ScannerDanner Premium lecture) - Duration: ...
getting fire from coil but not to plugs - CarGurus
www.cargurus.com > Questions > Dodge > Ram 1500
CarGurusJun 12, 2013 - 2000 dodge ram 1500 4x4 not getting fire changed distributor cap, coil, pickup ignition, rotor, plugs, plug wires 2 answers. ... 1994 dodge 5.9 just shut off and wont start back up there is no spark or fire from coil or plugs. ... 94 dodge van 318 eng will not start new plugs new crank ...
Ignition Coil Troubleshooting: (No) Fire in the Hole
www.secondchancegarage.com/public/coil-troubleshooting.cfm
Jan 27, 2016 | Cars & Trucks
I have a yamaha moto 4 atv 1985 it wont fire cant get it will turn over but wont run or fire
Hi, Tina and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.ATV Connection
86 Moto 4 No spark Unsure of where to post lol Yamaha Grizzly ATV Forum
https://www.tradebit.com/filesharing.php/search/0/1985+yamaha+yfm200
Yamaha Yfm200n Moto 4 1985 parts lists
http://www.yamahamotorsports.com/assets/service/manuals/2006/LIT-11626-19-08_1141.pdf
Jan 08, 2016 | Yamaha Motorcycles
My cool sport 200cc ATV won't start. I replaced spark plug, checked wiring harness, checked fuel flow, checked coil, and I have a signal going to the coil. Its turning over, but wont start. Any ideas
You have juice to the coil, and you say you checked it, but do you have spark at the plug? Also test compression as these units are bad about valves getting too little valve lash, which can hold them open preventing compression.
May 28, 2015 | Cars & Trucks
My atv turns over but wont start
squirt some starting fluid in it if starts rebuild carb
Aug 28, 2014 | Garden
Cant get fire on plug for a 200 bear tracker 4 wheeler
When checking for spark at the plug make sure the outer metal part of the sparkplug is grounded to the engine, make sure the main ignition switch is on, make sure the emergency switch on the handle bar is set to the start position and make sure the atv is in neutral.
After checking all these things above and it still fails to fire or spark at the plug then check all or any wiring, wiring connections and or connectors that you have intentionally or unintentionally disconnected while woking on the atv and also check all the fuses.
If all these check out as good and the atv still won't fire at the plug you will need to test other things such as the igntion coil, pickup coil but you will need a volt/ohm meter and the specifications for these in order to test them.
In order to get this information go to the Yamaha ATV Forum and you will see a sticky note posted by oxidized_black in regard to Yamaha Service Manuals go through each page until you get to a download LINK for a 1999-2001 Yamaha Bear Tracker YFM 250XL(C) Service manual link. Click on that LINK and download the PDF file to your computer this should provide you with more than enough information to test and find your ATV problem.
Hope This Helps
Sep 16, 2013 | Cars & Trucks
Chrysler town country engine light flashes 10 times
does it have coil packs? you may need to replace one
Jan 26, 2013 | 2004 Chrysler Town & Country
1.8l 4 cylinder wont fire after replacing head cylinder?
rechk plugs firing order. chk soliniod and coil r ok, rechk fuel is getting into engine- choking usually determines that, u can smell the over choked engine. I f engine turning & choked hold throtel to floor while cranking and leave there until it fires. if no firing happends it must be electrical. rechk electrical connections. Cheers
Aug 29, 2012 | Cars & Trucks
Cobra 50 fourwheeler wont start cleaned carb and new plug
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
Kasea 50cc won start engin turns but no firing at all Off Road Forums...
ATV Connection
Aeon Scooter Parts Racing Planet USA https://www.thomasmorecollegebookstore.com/panther-110-atv-manual.pdf
Tips and Tricks for Motorcyclists
Apr 09, 2012 | Cobra Panther 50 Motorcycles
02 durango wont start
Is it getting fuel and or spark? If the fuel pump is working and the the plugs are getting fire then perhaps a clogged fuel pump strainer is to blame.
If the fuel is reaching the engine, then test the coil. If no spark is event replace the coil.
Dec 08, 2011 | 2002 Dodge Durango
Replaced engine. car turns but wont start. power
have you checked that the points in the distributer are set ok and havent closed or burnt,as this is what makes the coil spark the ht lead to the distributer cap to the rotor arm then to the plug leads.
hope this helps
Aug 02, 2009 | Ford Contour Cars & Trucks
15 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
