Question about Neff 24 in. S5456 Built-in Dishwasher
Continuely pumping out
Won't move on
Need to remove the air con pump all bolts are out but won't move
Some mounts have a moveable sleeve in one end that moves in to take up the slack when doing up the bolts. Try using a pry bar or something to lever the compressor out to move this adjuster sleeve.
Apr 06, 2013 | Computers & Internet
2000oldsmobilesilhouette codepo302 codepo410 codepo442
Probably not.
Code 302 is for a miss on cylinder two, code 410 is for a problem with the air pump system, and code 442 is for a small leak in the EVAP system which vents the gas tank.
You may need a shop manual to get the test procedures for these codes.
Mar 11, 2013 | Cars & Trucks
I have a 2005 Gmc Serra and it takes forever to refuel pump clicks off continuely like tank is full
you have a bad evap vent solenoid at fuel tank causing fuel tank not to be vented, need to replaced evap vent solenoid, have to purchase from a gm dealer
Sep 03, 2012 | 2005 GMC Sierra
Driver dash Air Bag light is on continuely. 2007 Sant Fe
The Air Bag sensor is indicating that the air bag cannot be counted on to deploy in case of collision. The only known fix is replacement of the sensor itself. Most states won't allow a vehicle to pass safety inspection with this light on.
Sep 14, 2011 | Hyundai Santa Fe Cars & Trucks
Before the car would **** hard at any speed and it might do it again in 30 min. or aweek later. we replaced the cam shaft censor & crank shaft sensor. now it continuely surges mildly and the tacometer...
My car has and is doing the same thing. I replaced the cam and crank sensor less than 3 months ago, then car started dying, not starting, hard to start..etc...just like before I replaced sensors. NOW, it won't start and I am stranded~!!!
I know this is not a solved issue for you, just wanted you to know you weren't alone with issue and I hope we both can find resolve soon!!
Aug 22, 2011 | 2005 Nissan Altima
Waeco cf 40 portable refrigerator runs continuely
This is not an uncommon problem and you're probably experiencing a voltage drop between the battery
Dec 20, 2009 | Refrigerators
Fuel pump humming
Hi Bill,
I've got a 91 Wrangler. I'm not sure what your problem is though.
I assume you have the 4.0l fuel injected straight six.
Is the fuel pump on all the time?
Does the car run?
Could you comment back with a bit more detail about the problem?
Thanks
Mike
Oct 04, 2009 | 1992 Jeep Wrangler
Loud fan noise near bottom of freezer on my kenmore elite
There is a fan down on the bottom of your unit it sounds to me like the fan is making the noise as the bearings are getting dry. You should be able to move the unit out from the wall and get behind and look at the fan right next to the compressor. let me know how it goes. ken
Dec 26, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Neff 24 in. S5456 Built-in Dishwasher Logo
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
