Question about Singer 5400 Sew Mate 60-Stitch Sewing Machine
Sewing machine needle will not pick up bobbin
The needle broke when I tried to sew elastic waste band to my garment - the last step left of an otherwise smooth operation --- but after replacing the needle - I cannot get the needle to pick up the bobbin & therefore have not been able to sew.
    Champion:
    Habit-Forming:
  • 201 Answers
Hai, You can use (elastic) big size new quality needle. Then last 10 or 5 steps off the machine movie the handle.
Posted on Mar 24, 2014
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
Mongo32
  • 111 Answers
SOURCE: singer sewing machine, needle will not pick up bobbin thread?
needle in backwards?
Posted on Aug 23, 2009
miket756
  • 2702 Answers
SOURCE: NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Posted on Oct 24, 2009
Testimonial: "Thanks! I was hoping to avoid paying for a fix, but it looks like I have to **** it up. So much for being thrifty and restyling my clothes."
  • 1788 Answers
SOURCE: I have an old singer sewing machine 401A. The top
You can download a manual for $10 at www.sewingmanuals.com and it should help you. A couple of suggestions though, is your needle inserted correctly? Flat side facing the rear of the machine, fresh needle? Threaded correctly on top and bobbin area? Is your thread good not too old and the same type in bobbin and top? Did you leave a long enough tail in the bobbin thread? 3-4 inches which you hold with your left hand. Is the thread in the bobbin unwinding the right way? Are you turning the handwheel towards you, not away from you at least two revolutions or until you see the thread loop? Try these suggestions, and I am sure one will work unless your timing is off and it needs professional service.
Posted on Sep 20, 2010
  • 1788 Answers
SOURCE: will not pick up bobbin thread. problem begin
I would try cleaning the area with some alcohal on a cotton swab and change needle. You may have caused a problem with your timing, I hope not because you will need it to be set again by your authorized center. I know there are directions on the internet but I would rather make sure that it is done right,and knock out your warranty. You have a nice machine.
Posted on Sep 26, 2010
Machine just quit picking up bobbin thread and sewing in the material. It is just making holes in the material.
Needs a new needle right way around, most likely. And check the threading on both bobbin and top of the machine. It makes a big difference which way the bobbin turns in the bobbin case.
Needles need to be replaced every 2-8 hours of sewing time, on average, or about 1 needle per garment. A needle that has hit the presser foot or needle plate is "dead", and needs to be replaced to (and eventually, you'll need to buff out the rough spots on the presser foot, and needle plate).
Common causes of skipped stitches (stitching that looks like
_ _______ _ _ _______ _ _____________ instead of _ _ _ _ _ _) or of not picking up the bobbin thread are: dull or damaged needle, needle in backwards, needle not fully up in the needle clamp, needle too small a size for the thickness of fabric, dirty machine, misthreaded machine, and way, way, way down on the list, machine out of time.
Jan 14, 2014 | Singer Sewing Machines
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
How do I sew Elastic waistband with Husqvarna Viking 910 Surger
I am assuming this is a simple stretch waist band with elastic about 2cm wide attached to a skirt or trousers. You need to measure your wist and cut elastic that length plus 2cm. Then join the two ends by overlapping them 2cm and zig zagging the elastic together with regular sewing machine. Now mark the elastic in quarters, ie hold it flat with the join in the middle and mark each edge with chalk or a fabric removable marker. Then put the marks together and mark the edges again so you have 4 marks equally spaced. Now do this for your garment too. It may be bigger in back so mark front and back, then half this to find the side quarters. Put elastic on inside of garment against raw edge and pin the quarter marks on elastic and garment together. Set up overlocker for 4 thread wide seam. Test seam and adjust tensions if necessary. Now you need to serge the edge of the fabric and elastic together, trimming the fabric but not cutting the elastic and stretch the elastic to fit the garment as you stitch. Elastic on top, fabric right side down underneath. Take out pins before you get near them! Start by lifting the front of the presser foot with your finger and placing fabric and elastic under, then start stitching on and straighten up once the seam is onto the elastic. Dont lift the pressure foot, you just stitch, stop, stretch the elastic to the fullness of the fabric, hold it and seam forward a few inches, then stop and repeat the process. Once right round go over your starting point, then turn and serge off the fabric edge and chain off. Cut, pull the chain to pull it flat and tie a hald hitch in it right up close to fabric. Now turn the elastic band to the inside of the garment. You need to secure it. Usually a straight stitch just onto the lower edge of the elastic with sewing machine from outside.
Dec 27, 2011 | Husqvarna Huskylock Computerized 910
Needle broke and i changed with the same number now it is not picking up the thread and does not stitch
you said the needle broke, did you check in the needle plate where the feed dogs are if there was any needle fragments
also check in the bobbin area for needle fragments, take the bobbin case & bobbin out & clean the area
Oct 21, 2010 | Singer 8280 Mechanical Sewing Machine
My Janome needle thread will not pick up the bobbin thread! I have checked threading and needle and bobbin case...nothing works!
Your Machine is out of time, you probably broke a needle or sewed over a pin. take the machine to your locsl deler to be re timed. about 90.00
Jun 13, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
I'm trying to do shirring?
My machines has a shirring foot, so I don;t have the same machine. However, I do not think that elastic thread will work in the bobbin. Have you tried it the other way around? Do you have your manual?
Aug 07, 2008 | Sewing Machines
Needle will not pick up the bobbin thread
www.whitesewing.com try there web site
Feb 18, 2007 | White Sewing White 3032
Singer 5400 Sew Mate 60-Stitch Sewing Machine Logo
71 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
