Question about Food Mixers
Kenwood repair KM400
Will only run at full speed.Have pulled it apart, but how can I tell if the problem is in the speed control board or in the feedback from the motor. And what is available in the way of spares. Thanks.
  • 94 Answers
If your circuit board got a little wet . you might check into that for residue must clean with baking soda solution and toothbrush clean area or brake cleaner might dissolve the residue too ...speed control is just a resister band . and if very old can be worn down like a climate control in a car ...
Posted on Apr 01, 2014
5 Suggested Answers
SOURCE: Blakeslee (Kenwood) A717 mixer speed control
I had the same problem. Had to strip the machine down to get to the motor. On the top is a moving plate with various capacitors etc mounted. On the front side there was a Capacitor (At least I think it was) with the wire broken.
I resoldered it and the machine now works fine.
I hope this helps
Posted on Jul 05, 2008
mirran
  • 515 Answers
SOURCE: Blakeslee A717 speed control
where are you from, i have phone number to agents that still provide support for A700 series.
Posted on Jul 12, 2008
  • 1212 Answers
SOURCE: Kenwood Chef KM400 motor speed is too slow
A failed SCR or triac will not always show visually any sign of failure. Chances are good that is all that is wrong. If mixer had been plugged in when it got wet, that is all it takes. Also check the transient voltage supressors if the chef has them. They would be identified on the circuit board. as TVS or MOV along with a number. Only number to use is the one on the component.
If you can find ratings for the old devices, just matching the basic ratings should do. Just guessing, but the SCRs should be 20 amp and 400 volt, If the old ones are a lower rating than my guess, there is no problem with using the higher ratings, if my guess is low, go with the original's ratings. Manufacturer of device does not matter as long as ratings are at least comparable.
Posted on Jan 19, 2012
SOURCE: hi im looking for Service Manual Schematics for
Hi looking for help aswell with the control knob mines aslo broke
Posted on Oct 12, 2012
Kenwood km020 variable speed on full all the time.
Had the same problem. The module registering the speed setting was broken. Easiest way to fix it is to order part nr KW710359. You can find various shops selling it on google. Bought mine for 35EUR.
Jul 30, 2013 | Kenwood Chef-major White Control Knob...
My kitchenaid mixer run on high at all times
If your mixer only runs on high speed there are 3 things that can cause that. The first thing to check will be the speed control plate, Remove the trim and end cover on the mixer, the first thing you should see is the speed control plate, this has 3 screws on it, try adjusting the top two screws 1/4 turn, this should slow the mixer down, do not over tighten. Also check to see if the control plate spring is unhooked. If the spring is unhooked, attach to bottom of the control plate, and squeeze the spring end.
If this does not fix your mixer, check the wiring of the mixer, you can locate a wiring diagram on the last page of the service manual.
If the speed control plate is adjusted correctly and all the wiring is correct it will be your speed control phase board. You can test the speed control phase board to see if it is shorted. With the line cord disconnected, pull the t-b ar contacts to open, and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, teh phase control board is defective and needs to be replaced.
Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
This will aid you in taking the mixer apart, troubleshooting and putting it back together, remember the wiring diagram is the very last page.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 07, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
Jan 19, 2012 | Kenwood KM400 / KM410 Chef Classic Stand...
How do i lubricate my kenwood chef mixer
can you tell me where the gearbox is situated please?
Feb 19, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
Kenwood Chef - slowest speed
if you have max speed you have to replace the .1uf capacitor the 2 spring loaded screws serve far fine adjustment
Feb 02, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
My kenwood a901 gave up the ghost after 25 years loyal service
I have an A901. The label on the machine says that it is 1/3 Hp (one third horse power).
Nov 24, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Difference Kenwood Chef A701 and Kenwood A901
Hello.
the difference between A701A and A901 is :
high speed outlet
slow speed outlet
planetary hub is similar . A701A, A901 and KM series
A701 Different planetary hub and fit different tools.
is not same A720 and A920 A7 = A701/A
A9 = A901 and KM
In our web site Kenwood Chef Restore in Downloads section.
you can download the compatibility of the models A700, A701 , A900 and KM series .
Regards
Oct 02, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Kenwood Chef Repairs
Kenwood Home Appliances (Pty) Ltd
1295 Clubhouse Street
Maraisburg 1709
South Africa
+27 (11) 4740153
May 14, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Kenwood 500 watts
It may be the motor but it is most likely a burnt out capacitor, these can be replaced for around £30. It is not a DIY job unless you know a qualified electrician as soldering is involved. Best to take it in for repair if you think it is worth it.
Jan 04, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Food Mixers Logo
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
