Question about Soundstream Bx15 Epicenter Sub Amp Bass Enhancer Bx15
Red lights on the epicenter
My lights are red from the tarantula
Hi i trying to figure out how to wire up my rca's i have a pionner deck in on the back of it it has front output,rear output,sub output ,and also a audio output .now im trying to up it to a clarion eq that...
The "Front output" from the Pioneer deck would connect to the "Main In" on the Clarion EQ. I'm assuming that your Clarion EQ can only deal with one input, and will send the adjusted (equalized) signal out both of the outputs.
The "Front output" from the Clarion EQ should go to the "Front Input" on the 4 channel amp.
The "Rear output" from the Clarion EQ should go to the "Rear Input" on the 4 channel amp.
The "Sub output" from the Pioneer deck would connect to the Left/Right Input on the Epicenter. The Left/Right Output on the Epicenter would need a Y-splitter for each side, so that you could connect each amp separately. One suggestion would be to use one sub amp for both subs.
Feb 18, 2011 | Clarion Car Audio & Video
Knob on my epicenter doesn't work
the older epicenter knobs are pull then turn. and push in to turn epic off
May 22, 2010 | AudioControl Epicenter Audio Control...
My media player keys on razer tarantula keyboard
after i checked the preferences in winamp i found out my hotkeys were not enabled so thats why they were not working. So if you have the same problem go to preferences -Global hotkeys and check the 2nd box
Mar 18, 2010 | Razer Tarantula RZ03-00070100-R2U1
Tarantula does not work in POST
Make sure you have the usb keyboard option enabled in your bios
Good luck
Jun 22, 2009 | Razer Tarantula RZ03-00070100-R2U1
Webcam driver Piranha Tarantula Z type 6.0 Mp for xp
http://www.pc210.com/downloadhtml/200596152051.html
ı have downloaded that and extracted files.than ı plugged my webcam which is Piranha Tarantula Z type 6.0 Megapixel (on windows Xp system) , than it has asked to me if I want to setup new hardware driver .I said yes and ı have selected folder by myself.than it installed.
2. way of to do that.
extract the file and run setup.
I hope it will help to u :)
have a nice days. =)
Dec 05, 2008 | Computers & Internet
Soundstream Bx15 Epicenter Sub Amp Bass Enhancer Bx15 Logo
Top Soundstream Car Audio & Video Experts
Matthew Spark
Matthew Spark
Electro Med Services...
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
