Virgin media superhub
Internet working but wan blinking but not blue
  • 3,320 Answers
SO what's the problem?
Posted on Mar 23, 2014
2 Suggested Answers
  • 1632 Answers
SOURCE: Connecting cisco 851 cable to virgin media superhub problems?
Did you follow instructions on the manual , re install the driver .
Posted on Dec 27, 2013
Won"t recognize or authenticate any wifi signal whether home, or free signal
Switch to 2.4ghz you may be using 5ghz which isnt compatible - Virgin media superhubs are notorious for this.
Oct 15, 2015 | LePan Le Pan II Android Tablet with 1GB...
My virgin super hub will not except admin and changeme. as far as i am aware nobody has changed the codes
The reset button is a small pin hole about 2inches on the same side as the power button on the superhub.
The power button is on the opposite side of the virgin led, which should be the left hand side when your looking at the front of the hub.
You will need a pin to reset it, put the pin in the hole and keep it pushed in until all the lights turn blue. Once the lights have turned blue it will then restart itself.
The default username and password is
username = admin
password = changeme
Now if that doesn't reset it to factory default then you need to go into the hub settings click on the "superhub settings" tab and you will see the option to reset to factory settings.
Jan 30, 2015 | Computers & Internet
Superhub virgin
Contact Virgin with your bank and set up details.
Jan 08, 2014 | Computers & Internet
Dec 27, 2013 | Cisco Computers & Internet
Virgin superhub (netgear) router
The purple lit up thing badged Virgin media, it's a button as well as the indicator by colour.
I used to have the same problem and installed a wireless access point that professionals use in schools and factories. You couple to the saucer shaped thing with cable and it does Wi-Fi cable free for miles. I can follow the signal more than 20 houses away.
https://www.amazon.co.uk/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=Unifi+UAP-AC-PRO
Some similar problems:
http://community.virginmedia.com/t5/Networking-and-WiFi/Superhub-2-with-TP-Link-TL-WPA4220/td-p/2096382
Sep 04, 2017 | Computers & Internet
Virgin media superhub has stoped streaming - cant locate Mezzmo server
I had similar problems when I moved to the SuperHub - my TV could stream from my PC via my old Router but couldn't connect when using the SuperHub.
At first I thought (and was incorrectly told on here) that the SuperHub doesn't support DLNA, but what it turned out to be was that when attached via the SuperHub the TV was allocated a different IP address and my Firewall (ZoneAlarm) automatically blocked it (which I only realised from looking at the firewall logs).
For some reason ZoneAlarm had automatically allowed the TV through when I originally connected it to the old Router with no setup needed from me, but it had automatically blocked it when I connected it to the SuperHub. Adding the TV IP address to the ZoneAlarm "Trusted Zone" sorted it out.
Although this may not be your problem, and I was using TVMOBiLi rather than Mezzmo, it might be worth looking at your Firewall etc., because I incorrectly assumed it was down to the SuperHub because that was the only "new" thing in the previously working DLNA system.
Aug 21, 2013 | Computers & Internet
I have a modem supplied by virgin media can i
Well, Virgin Media provides Cable Internet connection and with those connections you can not use this ADSL modem. If you have internet services from Virgin.net then only you will be able to use this modem with them. This modem will not work with Virgin Media connection.
Hope this answers your query.
Regards
Anand
Mar 30, 2010 | NetGear DG834G Router
Connecting to virgin cable modem
Hey, connect a network (straight through cable) from the blue socket on the modem to the WAN socket on your router (This socket will be split away from the other 4 on the router), then turn on your router 1st then modem.
Good Luck.
Nov 13, 2009 | Computers & Internet
No connection
Is your physical connection right???
the WAN port should be connected to your modem, and the LAN1 should be connected to your pc.....
if right, but still doesn't connect....
check if the lights of your router is working
the POWER should have a solid light,
the STATUS, WAN, LAN 0r WLAN should be blinking...
What kind of connection do you have?
is your modem automatically detects your password...?
or you manually type your password to connect to the internet...?
Jan 17, 2008 | D-Link DI-704P Router
Wireless connection
The first step to try is to reboot both the router and the cable/DSL modem. Turn off your computer, and unplug the router and the modem from the mains. Wait one full minute, then plug the modem back in. Wait until the lights stop blinking (until it indicates a steady connection). Once that is complete, plug the router back in, and wait until it also stops blinking. Once the router and modem are both back on, then turn your computer back on and check to see if you have a connection. If that doesn't work, then take the router out of the picture -- plug a computer directly into the ethernet port on the modem. You should definitely have an Internet connection at that point. If it works, the problem is in the router. If it doesn't, you'll need to call Virgin Media's help desk for assistance.
Sep 29, 2007 | Belkin (F5D9230-4) Wireless Router...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
