Question about Sharpro Grips 3 Cat Anti Torsion Black/Red Golf Grip
New Sharpro grips; having trouble getting them over the end of the club to slip on. Any suggestions? Thanks!
I've installed hundreds of grips, but I'm having trouble getting these on. I've used plenty of solvent, but the end of the grip with the hole seems a bit flimsy and I can't get it to slide in. Thank you!
  • Slappy White
    Slappy White Mar 28, 2014
    Thank you Rian. I think the club is .600 and grip .580. I finally got them on! I'm adding this comment in case anyone else needs a helpful tip: I folded the end of the grip (as if rolling up a pant leg) and was able to finally get the grip to go on. When it was fully on the club, I simply unrolled the bottom (open end) of the grip. So happy, patiently waiting for better weather!!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
You want to make sure the shaft your installing on is the same butt diameter as the grips. If the shafts bigger than the grips it is possible to stretch them on there however you risk tearing the grip.
Also you may not have just put it on far enough. Once you start sliding it on don\'t stop! If there is extra play at the end you can use a needle and inject solvent under the grip to loosen it up.
Posted on Mar 23, 2014
    Problem Solver:
  • 58 Answers
Try boiling water and dropping them in for a few seconds to soften them up. Keep checking them for pliability and drop in again if needed.
Posted on Nov 27, 2014
How do i replace grips on 2009 electra glide ultra classic
For twist grip equipped motorcycles to remove the throttle or right side grip remove the upper and lower switch housing screws, loosen the upper screw securing the handlebar clamp to the master cylinder housing. Remove the lower clamp screw with flat washer, separate the upper and lower switch housings and remove the throttle grip from the end of the handlebar. (To remove the throttle grip, a slight tug may be necessary to release index pins in grip from receptacle in seal cap of twist
grip sensor.)
With throttle cables, to remove the throttle or right side grip slide the rubber boot off of each cable adjuster, loosen the jam nut on each adjuster, turn the adjusters in the direction that will shorten the cable housings to their minimum lengths. THEN remove the two screws and separate the upper housing from the lower housing, unhook the ferrules and cables from the throttle control grip and the lower housing, (remove friction spring, throttle friction screw and spring from the lower housing only if necessary), (only if and as necessary mark the position of the master cylinder assembly forward position and split line on the handle bars) (to be safe squeeze the front brake lever and place a 5-32 inch thick cardboard insert between brake lever and lever bracket and then release brake lever to hold the lever in this place to protect the brake switch from damage if the switch housing and the master cylinder get separated) (and only if and as necessary, loosen the two perch screws) move the lower switch housing as necessary and remove the grip.
To install the throttle grip apply a light coating of graphite to the handlebar and the inside surface of the upper and lower housings, (if removed, install the spring, throttle friction screw and friction spring in the lower housing) (and, if removed, attach the cable assemblies to the lower housing), (throttle control cable has a 5-16 inch fitting end and is positioned to the front of the lower housing. and the idle control cable has a 1-4 inch fitting end and is positioned to rear of lower housing. Install the throttle control grip over the end of the right handlebar, position the lower housing onto the right handlebar, engaging the lower housing with the throttle control grip, position the ferrules over the cable ball ends, seat the ferrules (with the cables attached) into their respective notches of the throttle control grip, install the upper housing over the right side handlebar and secure it to the lower housing with the appropriate two screws and hand tighten them, then align the brake master cylinder and perch assembly with the marks made prior to loosening them, and beginning with top screw, tighten the two screws to 108-132 inch lbs using a T27 TORX drive head and then tighten the upper and lower housing screws to 35-45 inch lbs. THEN point the front wheel straight ahead and WITH THE ENGINE OFF, adjust the throttle and idle cables by turning the adjuster in the direction that will lengthen the cables. Gently twist the throttle control grip to the fully open throttle position (fully counterclockwise) and hold it in this position and turn the throttle control cable adjuster counterclockwise until the throttle cam on the induction module (or carb) contacts the throttle cam stop, release the throttle control grip and turn the adjuster counterclockwise an additional 1-2 to 1 turn and tighten the jam nut on the throttle control cable adjuster. THEN turn the handlebars fully to the right and turn the adjuster on the idle control cable counterclockwise to lengthen the sleeve until the end of the cable housing just touches the spring within the cable guide. NOW check the adjustment by, with the throttle friction screw loosened, twisting and releasing the throttle control grip two or three times. The induction module throttle wheel must return to the idle position each time the throttle grip is released. If the throttle does not return to idle, turn the idle adjuster, shortening the cable sleeve until the correct adjustment is obtained, tighten the jam nut and slide the rubber boots over each cable adjuster. NEXT start the engine and with it idling turn the handlebars through their full range of travel and if the engine speed changes at all during this maneuver, adjust the control cables according to the foregoing procedure so that there is no change in the idle speed when the handlebars are rotated through their entire range of travel.
To remove the clutch or left side grip remove the two screws and separate the upper housing from the lower housing. Mark the forward position and clutch perch split line on the handlebars and then as necessary loosen the two clutch perch screws and move it out of the way so that you can access the grip end. If you want to save the grip take a small screwdriver with about an eight inch length and insert it into the grip, wiggling it to loosen the glue somewhat and then spray some brake kleen into the space under the grip where the screwdriver blade is inserted and wiggle and twist the screwdriver around to loosen the rest of the grip glue and pull the grip off. Sand down the handle bar area where the grip will rest and apply grip cement to the area and slip the grip on. If the left hand grip is patterned, align it with the pattern on the right hand grip with the throttle in the fully closed position, immediately push the grip completely onto the end of handlebar using a twisting motion. Do not hesitate when installing the grip or the adhesive may dry before installation is complete. Allow 6 to 8 hours to elapse at 70 degrees F to allow the adhesive to fully cure. If a newer non-glue grip is being installed slip it on with the flats properly oriented to fit with the switch housing halves when they are installed. Install the switch housing halves and lightly tighten the two screws and then orient the clutch perch to the previously made alignment marks and beginning with the top screw, tighten the screws to 108 - 132 inch lbs using a T27 drive head and then tighten the switch housing screws to 35-45 inch lbs.
Sep 20, 2014 | Motorcycles
How do I loosen prongs that are stuck in open position?
The only answer I can suggest is to use either a two grips or hold the end in a vice and use a single pair of grips on the outside ring. This will all depend on what chuck is fitted though.
Jan 28, 2013 | Drills
Installing Harley Davidson Chrome & Rubber Hand Grips Large 56263-96A
Hi David, for more information about your question please visit the websites below. Good luck and have nice day.
Install New Hand Grips on Harley Davidson Motorcycle Biker Podcast
May 20, 2012 | 2005 Harley Davidson FLSTC - FLSTCI...
Sounds like the throttle lock is possibly binding up. Remove the right grip. There should be a little half moon shaped piece of plastic in there at the bottom of the switch housing. This plastic piece will have a small hole in the outside edge. This hole has to be placed over the pointed end of the throttle stop. The throttle stop is the plastic star wheel on the outside of the bottom of the right switch housing. There is a small metal Jesus clip on the inside of the switch housing. This clip is supposed to hold the stop from being turned completely out of the switch housing. It's possible the clip came off and is wedged in there.
Y 2002 dodge grand caravan sport 3.3 ,have problem engaging transmission into drive in cold weather,transmission will slip in&out before engaging.
If your transmission has gone your best option is a factory rebuild. Most modern transmissions are very sensitive to having clean fluid. You may just be having an issue with dirty ATF automatic transmission fluid. Try a fluid change with the correct ATF.
If this does not work and you have around $2000 to $2500 to spare the Chrysler dealer installed factory rebuild with 36.000 mile warranty is your best option for fixing the Caravan. Any small shop offering the same service for a couple hundred less could be more trouble than it is worth. If you go with the salvage yard transmission there is no warranty on the installation and you could end up paying to install 2 or 3 before you get a good one.
Dec 30, 2010 | Dodge Grand Caravan Cars & Trucks
Brakes engaging without pressing the pedal
this is a simple job of adjusting the rod on the end of the servo that pushes the master cylinder .remove master cylinder and with help push the brake pedal down and then screw the end of the shaft in a mm or so .This will cure your problem.
Sep 01, 2009 | 2005 Ford Five Hundred
I have an rm125 and wen at full revs the bike begins 2 slip but if i use half revs its fine what could be the problem
If you mean the clutch begins to slip after half revs then chances are that the fiber clutch plates are worn. I suggest you get a set of fiber plates and install. Pull the right engine cover and remove the clutch end cap. Note the sequence of plates as you remove them. You will have fiber plates and steel plates. Is the first plate removed fiber or steel? If the first plate removed is fiber then the next is steel, then fiber, then steel, and so on. Install the new plates in the same fashion. So if you started with a fiber plate you need to end up with a fiber plate when the install is done.
Pleas rate this solution. Thanks!
Mar 26, 2009 | 2003 Suzuki VL 800 Volusia
Bogen head slips
I"ve owned four pistol grip heads, and eventually they all do this. They simple wear out.
You can send it to Bogen, and for about $35, they'll ship you a reconditioned replacement.
Check the Bogen website for details
Dec 18, 2008 | Cameras
Recharging problem
just wrap the aluminium foil (kithchen foil for food wrap) around the pin and it should be tight enough to make contact and grip, as its aluminium metal it will allow the electricity to pass on... and your device gets charged.. only point is if you keep on removing the plug and re connections... if just keep it always connected , this trick should solve your issue.. other wise try to glue the alumininum foil to it self by gluing at overlapping one end on the other end.
make sure the foil doesnt go in front( ahead of the charging pin tip, other wise if it may enter inside the tip and both + ve and -ve poles get connected , which may spoil the devices).. hope it solves your problem
Feb 28, 2008 | Magellan RoadMate 800 GPS Receiver
Sharpro Grips 3 Cat Anti Torsion Black/Red Golf Grip Logo
449 people viewed this question
Top Sharpro Grips Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Sharpro Grips Golf Expert? Answer questions, earn points and help others
