Lg wp-9031 wash timer knob is not working properly,even drain knob is also not working......:(
2 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: water gets drain cannot remain
The drain is pull the knob which will pull up the drain valve. So if this is not working then the connecting bowden is broken and is not connecting the link to the bottom drain valve.
Look at the bottom and connect. Clean the drain valve, if choked.
Posted on Sep 14, 2010
LG Semi Automatic WP 9220 washing machine water is not draining out what to do
Enter your model number into the self help section of repairclinic.com, you will receive specific trouble shooting info for you appliance.
May 11, 2015 | LG Washing Machines
How do I fix water not staying in the wash tub of Twin tub, LG WP 750R?
If your drain is not high enough the water will siphon out while filling. Check your owner's manual for correct height, usually about 39 inches from ground
Jun 20, 2014 | LG Washing Machines
How to take off the drain pump?
Firstly, without knowing the Model or make of your specific washing machine, I will need to give you a solution blindly...
Follow these directions:
http://fixitnow.com/wp/2011/02/11/accessing-and-removing-the-drain-pump-in-an-lg-front-load-washer/
It is a good starting point, even if the name suggests L.G, it is still the basic way of taking out about 70% of washing machine drain pumps.
Hope it helps :-)
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Apr 03, 2011 | Washing Machines
Water gets drain cannot remain in the tub for wash ...type of my washing machine is LG WP 9031 top loading semi automatic..
Sep 14, 2010 | Washing Machines
Frigidaire top loader washer won't drain
The timer has went bad in your front load washer.Thats the reason why the unit is not draining properly. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure. You should go for a replacement.
Thank you !!
May 31, 2010 | Frigidaire ATF6000ES Front Load Washer
GE washer won't complete cycle
there are contacts inside timer which may not be working properly. in any case they are not repairable.
Oct 28, 2009 | GE Washing Machines
Washing machine will was but will not remove water
Replacement cost will probably run you the same or more. Unless you can do it yourself. Sounds like the same thing we ran into before. All comes in one expensive part. timer and control knob
Jun 18, 2009 | Frigidaire Washing Machines
Washer won't advance from cycle to cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 16, 2008 | Danby DDW1805W Designer Series...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
