Question about Hisense TL1700 17 in. LCD Television
My volume just went out. It made a popping sound and then there was no volume. It works as far a changing channels, just no volume.
    Genius:
  • 1,139 Answers
Hello mckone,This may denote a situation with the audio output IC (may have cracked due to high current), however more likely is an exploded capacitor in the audio section of the TV, or even the power supply to the audio section. All of the possibilities should be checked by a qualified TV technician due to the nature of the possible problem. I hope this helps,Thank you,Shuttle83http://www.electron-age-technologies-llc.com
Posted on Jun 14, 2009
Why does my sound system pop when I switch channels with my tv remote?
you have a volume control on your source(ie. satellite or cable) & a volume control on the TV. If you have both too high you may get a pop when you change channels. You will need to lower the volume on both until you come to a satisfactory compromise between the two systems.
May 08, 2015 | Televison & Video
The tv was giving as a gift in 2012. So I believe that I put the right model in. I was watching the tv and went to change the channel, when I noticed that the box with the channel number looked differ
Your symptoms point to the main board [the board with all the input connections], no simple fix, you must replace the board. Less likely the keypad is bad, just unplug the keypad and see if channel display stops popping up.
Oct 21, 2014 | LG 32LD450 32 In. LCD HDTV
No sound on t.v. but popping and crackling from speaker
Sanyo sets have a horrible track record, if the set is still under warranty return it. The problem could be in either the power supply or main board. It will have to be diagnosed properly to be sure.
Oct 22, 2012 | Sanyo DP32746 32 in. LCD Television
My Fender Hot Rod deluxe makes a popping noise when switching back to the clean channel.
This is because your clean channel only runs through the pre-amp section, requiring an increased volume level to match that of the volume of the drive section which is overdriven by the pre-amp circuit. my suggestion is to use lower volume level on the clean channel of the amp. To get any volume boost you may need to match the two channels you could use a signal/volume booster or overdrive pedal between your guitar and amp input, switching it off and back on when you switch back and forth between channels.
Jul 15, 2012 | Fender Hot Rod Deluxe Guitar Combo...
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
Samsung 46 '' HDTV 1080P --------no sound
what is the complete model number of your tv?
does the volume control display pop up with a headphone or speaker sound on tv mode?
Mar 20, 2009 | Samsung 46 in. Flat-Panel LCD HDTV
No sound in sound bar and subwoofer
It could be that the unit is bad, it could also be that the device providing the input is bad. I doubt the cables are bad, but that could be also. Could it be possible that your television has a menu setting that turns the outputs off and on?
Even without the sub, you still get sound through the Bar.
Only way to test it is, different cables, alternate device to provide input for sound.
Dec 14, 2008 | Boston Acoustics TVee Model Two TV...
Popping in left speaker only...
just go master volume control and check whether the left and right speaker sound is in balance that is balance must be in middle... i think this audio property may have be changed
Jan 05, 2008 | Logitech Z-2300 Computer Speakers
Menu, volume and channel emblems will not show up
take your set to a tech the tv system control circuit might have damage, that circuit controls OSD,channel memory. it is an ic that controls that circuit along with other components.good luck.
Mar 26, 2007 | Toshiba 43H70 43" Rear Projection...
Hisense TL1700 17 in. LCD Television Logo
305 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
