Sony Smartwatch Bluetooth Smart Android Watch Mn2sw Logo
Rafael Duran Posted on Mar 23, 2014
Sony smartwatch2 drivers
Need usb drivers files
My brother's spiderman watch can't upload songs. Whenever I connect the USB to my MacOS Catalina, the music files don't show up and the watches start charging instead.
Before you transfer music onto the watch you first have to check if the device has any in built music player such as Spotify, Apple Music, or Amazon Music, if you do have, check your cable for any problems
Mar 11, 2024 • The Watches
Repair broken screen
Sony eSupport Electronics Service Repair This may help. The cost of repairs can be found by contacting Sony at the phone numbers provided
I want device drivers for itel inote so that i can use usb on my computer
Preferably download your manufacturer's specific consumer drivers from the respective websiter; otherwise you might be able to use Intel's SDK driver pack from here: https://software.intel.com/en-us/android/articles/intel-usb-driver-for-android-devices
Good Luck !
Jun 27, 2014 • Watches
Why cannot i not upload
Check the connections for dirt and corrosion.
Also see if the drivers are installed.
My PC (or friends) doesn't recognise my Databank usb2.0 64GB flash
Try the stick in another device and report back if you can read and write to the stick on that device.
Plug other USB things into that port to see if the port is good.
Although rare, some USB things allow themselves to be inserted backwards.
Oct 19, 2012 • Watches
14helpful
I have a full memory need to delete files and forgot how
Here are some steps to delete a file in your Polar watch.
Deleting a file
1. In the Time of day display scroll up or down until FILE is displayed.
2. Press OK to enter the File mode.
3. Scroll up or down until desired exercise file is displayed. Press and hold
the signal/light button. DELETE FILE and file number are displayed.
4. Press OK. The wrist unit confirms if you want to delete a file
(Are you sure).
5. Press OK to delete the selected file.
6. Press stop to exit the file. Wait appears. The wrist unit rearranges your
file, which takes few seconds.
7. Repress stop to return to the Time of day display
Deleting all files
2. Press and hold the signal/light button. DELETE FILES is displayed.
3. Press OK. The wrist unit confirms if you want to delete all files
(Are you sure).
4. Press OK to delete all exercise files.
5. Press stop to return to the Time of day display
For more information, refer to manual of the watch.
I hope this will be able to help you.
Thank you for choosing Fixya.
9helpful
2answers
Can I run Nike Triax Elite software in Windows 7. I have a USB driver problem.
I had to take the following steps to get it to work in Windows 7 after running the setup executable under the Comments in the Windows row from http://www.ftdichip.com/Drivers/VCP.htm
  1. Open up Device Manager, right click on the Triax Elite and select Update Driver Software.
  2. Select "Browse my computer for driver software" in the window that pops up.
  3. Click "Let me pick from a list of device drivers on my computer."
  4. Scroll all the way down the list of "common hardware types" to USB controller.
  5. Choose FTDI from the list of manufacturers and choose the "USB Serial Converter"
  6. Confirm that you know what you're doing and want to install this driver.
Windows then finds another Unknown Device which is the serial port. Repeat as above but choose Ports for the common hardware types and then FTDI and "USB Serial Port".
Afterwards, run the latest Nike Triax Elite software (that you can download from http://www.nike.com/timing/extranet/elite_software/ and it should work.
Top Sony Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sony Watch Expert? Answer questions, earn points and help others
