Question about Bose® CORPORATION Bose - SoundTouch 30 Wi-Fi Music System
Cant connect - no Wland problem!
Works fine for 3 mintues but then shows me the wait circle and cant connect either to internet radio or my music library...the internet works fine so I have no idea where the problem lies. one window once popped up saying please try again later 1046
Vizio tv E3D420VX: internet problem
Amy, check your wireless connection by clicking the 5bars. Now it may show connected but may not have internet connection. Check that. Check cable connections if correct. GL
Jan 05, 2014 | Computers & Internet
Music video plays then stops with a small circle of dots appearing in the center of the screen wait a few minutes music re-starts then stops again
your internet speed is not enough to play online using idm download video from youtube then play it any time.don't forget to turn on advance downloading option from option menu.then you will able download.
May 11, 2011 | YouTube Videos
Were to find fm radio and does it rely on internet for said service. Thanks Nigel
FM radio in the Defy comes bundled in the music player. Firstly, connect the wired headset, because it will act both for listening to the FM radio, and as as the FM antenna itself. Ok, either go to its icon, (in the 6th home screen), or go to 'Start (the circle in all the home screens) > Music'. Then, if the last music you played comes up, press 'Menu > Music Home'.
Before you click on 'Radio', on the home screen, if you are worried about data usage, be warned that it will occur if you want lyrics to be shown as music is being played. If you want that feature, but don't want to use your carrier's data plan, you can turn your phone's Wi-Fi on, and connect to either your home network or a plublic access point. If you need further informations on how to do it, please, let me know. To turn this feature off, go to 'Menu > Settings > Display lyrics' and make sure that 'Show lyrics in player' is unchecked. Press the back button, then 'Data Usage', where you'll find checkboxes for 'Download song data' and 'WiFi only purchasing'. Set them accordingly. Press the back button twice, then 'Radio'. You are now listening to the FM tuner. After finishing, press the back button until you reach any of the home screens.
You'll notice that the embedded FM player is able to play sound on the wired headset only. It this is if fine for you, we're done here. Neverteless, this standalone application (many thanks to yipyipyip) doesn't even require that the wired headset be plugged in, at all. If you are not subscribed to xda-devs, do it. Download link in the first post. Download it and copy it to anywhere on your phone (e.g. sdcard). Then, go to 'Menu > Settings Applications', and make sure that 'Unknown sources' is checked. Press the back button twice to finish. Now, go to 'Start > File Manager > Memory card', and navigate to the apk file you have downloaded. Click over it, and you will be prompted to install it. Then, go to 'Start > FM radio' and have fun!
Regards, Carlos
Feb 27, 2011 | Motorola Mobility Defy Cell Phone
The alarm sounds daily. how can i stop it?
There are two alarms, and the steps are the same. Make sure both are off.
For Wake 1 alarm.
1.Look on the face. One the left are two symbols, a 'bell' and a 'music note'. 2. Press the 'Wake 1' button on top, several times. Notice how the green circle on the left of the face switches back and forth between bell to music note. 3. HOLD DOWN WAKE 1 BUTTON, until both lights are off. The Wake 1 alarm is now off.
Wake 2 alarm: Look at green circles on the right side of the face. HOLD DOWN WAKE 2 BUTTON until both circles are unlit. The Wake 2 alarm is now off.
Get a piece of paper, write "HOLD DOWN WAKE BUTTON to stop repeating alarm" and tape it to the back of the clock.
Aug 21, 2010 | GE 7-4853 Clock Radio
I switched my internet service to AT&T modem on my home computer that works fine, but now my Linksys wireless-G 2.4 broadband wont connect to my labtop. it says " cant find server" It worked when I had my...
Shut down lap top, power down your router and then modem.
Wait 3 minutes. Power up modem wait 3 minutes and then power up router, make sure all lights are on
and then power up laptop.
Also make sure you've got DHCP enabled in the router.
Apr 04, 2009 | Computers & Internet
Router doesnt connect to internet
This sounds like a problem with your DSL modem, not the router. Try unplugging both devices and wait about 10 seconds. Plug in the modem first and wait about 30 seconds (at this point the Internet light should be on). Now plug in the router and wait another 30 seconds. This problem is normally due to the modem not getting sync. I would try plugging your laptop directly into modem if this doesn't work to see if you then have Internet. If not call your ISP.
Feb 14, 2009 | Linksys Wireless-G WRT54G Router
Only showing as a network device on 2 of the 3 pcs on the network
Did u added the new network devices, or did u wait till thy popped up?
If u didn't added them manually, then go to networklocations, add network location, press next, and again next, then type in \\mybookworld\"here the name of the folder of your mybook, ex. Movies or music,.." (without " ")
Do it for every folder.
Oct 07, 2008 | Western Digital 500GB My Book World...
Bose® CORPORATION Bose - SoundTouch 30 Wi-Fi Music System Logo
27 people viewed this question
Top Bose® CORPORATION Audio Players & Recorders Experts
Mike Chamberlin
Are you a Bose® CORPORATION Audio Player and Recorder Expert? Answer questions, earn points and help others
