Replacement for defect parts for a proxxon drill
On motor control of my proxxon mircromot 40/E the thyristor becomes defect. Motor control number is: 285103, thyristor is labeled with T F8B. Which type of thyristor can be used for replacement? Furthermore, the varistor between motor power supply contacts becomes defect. It is labeled with LO4Z M55. Which type of varistor can be used for replacement? Many thanks for any help.
    Top Expert:
  • Office Equip... Master
  • 35,784 Answers
Refer this problem directly to Proxxon for resolution.
Posted on Mar 23, 2014
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
Maytag washer repair
The washing machine timer can be considered the brain that controls the washing machine's systems. Although timers are ruggedly constructed, they contain a variety of tiny parts, like springs and movable contacts, that can develop problems that keep the machine from operating properly. The movable contacts can become burned and fuse together or they can become stuck in the open position, thus disrupting the wash cycles. The timer's motor can also become defective, thus preventing the timer from advancing through its cycles.
a defective timer motor, the motor's control contacts stuck in the open position or defective drive gears. Unplug the timer's wiring harness, then, with the timer set to any position other than off, check for continuity through the motor contacts. Continuity will be indicated by a "0.000" on the meter's display. A pictorial diagram on the back of the machine will tell you which numbers on the timer socket corresponds to which set of contacts in the timer. Likewise, a functional timer motor will display a resistance reading greater than 0.000, but less than 5 ohms. Open contacts or a defective motor winding will be indicated by an "O.L." on the meter's display.
IF A defective timer will only work in some cycles and not others. Then check for a broken wire in the wiring harness, check for continuity through those contacts using your meter. Wires in the wiring harness can break, but it's not a common occurrence unless they get pinched during the assembly of the machine.
If the same part of each cycle setting, such as the spin cycle does not operate properly, the problem probably is not the timer but some other component such as the transmission shifting mechanism. If the problem occurs when using only one cycle setting, the problem is a bad timer.
Jan 27, 2016 | Maytag Washing Machines
I have a dewalt DW505 electric hammer drill that makes noise when in use, forward and reverse. It sounds like one or more worn out gears. Could this be caused by some other defective part or am I on the...
Make sure it's UNPLUGGED! (RALOL)
Seriously though, go to this website, http://www.ereplacementparts.com/dewalt-dw505-type-hammer-drill-parts-c-1009_9661_2280.html
they have an exploded view of your drill that you can download; it's in a pdf format; the parts are numbered so you can easily identify them. They even have the manufacturer's part number listed in case you need to order a replacement part.
The illustration will also come in handy once you take the drill apart and you have to put it back together; especially if you have to walk away from the project for several days- waiting for the replacement part(s).
I would suggest having a large- private work space to take the drill motor apart on; where you can neatly separate the pieces and cover them, should the need arise to leave them as is, in a disassembled state; free from the kids or wife (not on the dining room table where you know someone will tamper and move things around- saves on arguments, too!
Best wishes on your project- be well.
Mar 11, 2014 | Dewalt DW505 Electric hammer drills
New to buy collets for Proxxon TBM 115,
You can get the collets from Proxxon 920-757-1718
Oct 12, 2012 | Proxxon MICRO Drill Press TBM115
Can you replace bushes on a Ryobi P200 18V drill motor? If not, can you get a replacement motor and at what price?
Hi dboppre,
Welcome to fixya!
I can't find brushes for it anywhere, however, you can get a replacement motor at this website: http://www.ereplacementparts.com/motor-assembly-p-154175.html
Copy and paste this entire address into your browser and the motor assembly page will open for you. Should you need any other parts for it use this address: http://www.ereplacementparts.com/ryobi-p206-18v-2speed-drilldriver-parts-c-7931_8051_8064.html
Good luck.
When you accept this solution, please place a vote.
Thanks,
Handie Andie
Aug 14, 2011 | Ryobi 18v Cordless Drill - P206 18 Volt V
What machine oil should for my Proxxon Drill press?
You want something a little heavy..put one drop on your finger and pull your fingers apart... if the oil is stringy or tacky like then you've found what you want. Call MSC or Enco and ask for machine "way" lube. Hope this helps.
Jun 26, 2011 | Proxxon Compound Micro Table for Drill...
I am looking for Motor part number 48973018 And a 13mm keyless chuck For a Makita 8444DWFE Drill
go to Makitatools.com and you can type in your model number and find and buy replacement parts online from the direct.
Dec 11, 2009 | Makita Drills
The motor on my mt300 died can I get a replacement?
Have you checked the brushes and the switch. How do you know it's the motor?
Sep 03, 2009 | Proxxon Saws
Unable to get to brushes on DeWalt DW959 drill type 1.
the brushes are made to slide into the side of the motor. gently pull up on them. Also I would recommend that you go to Dewaltservicenet.com and type in your model number for a parts explosion and part number for replacement brushes. Let me know
Jan 11, 2009 | Dewalt heavy - duty 1/2" 18v cordless...
54 people viewed this question
jasbo
jasbo
