Question about Sharp Mx-M753u
Hello guys, I got sharp MX_M753, it print out only in color but not black and white mode, anybody know any solution please share or Email me at, Mickealwz@hotmail.com, thank you very much.
Sharp MXM753 Doesn't print out in black and white. NOTE!..it does print out in color
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
Mx m753 print only in black and white
Posted on Jun 27, 2014
Bubbabear64
  • 2794 Answers
SOURCE: my Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Posted on Jul 20, 2008
  • 47 Answers
SOURCE: SHARP MX-2300N
Someone has sent a print job from a computer to the copier with an odd paper size specified. Go to Job status, under "print" highlight the first job in the que and delete it. (if the job was sent more than once you will have to repeat. ) Check the document and print settings of the offending document.
Posted on Dec 07, 2008
SOURCE: Hi, New to Mac and trying to find sharp driver
Thanks for posting the obvious weatlandsvc. If i were to just point people to the vendors driver page, and pass that off as the answer, I would be fired. Thanks for the obvious.
I'm working on solving the real problem!!!!!
Posted on Dec 01, 2009
  • 120 Answers
SOURCE: Our Sharp mx-3501n copier
Your copier is not accepting your black toner cartridge (F2-71 Cyan, F2-72 Magenta, F2-73 Yellow). It either is not inserted properly, the packing tab is not removed from the back, or a faulty cartridge. Often 3rd party cartridges that the manunfacturer "guarantees" will work will bring this code. In short, the copier is rejecting your black toner cartridge and you should replace it.
Posted on Feb 24, 2011
SOURCE: network printing from a mac computer to sharp mx 2300n printer
Here's a new solution that works. When adding the printer, choose "Generic PCL Printer". This will allow you to print from your Mac to the Sharp Printer without buying the PostScript chip/kit for the printer.
Posted on Nov 17, 2011
How do i improve the print quality of my machine
Run a gradation test, might require a tech to access service mode,
Aug 12, 2015 | Sharp MX-2700N Color Copier
Black image streaks on sharp 2700n
You only have to make single color copies with each color CMYK
and check all the copies if only the black and white copies is smeary
then replace only the black the drum unit.
Mar 21, 2014 | Sharp MX-2700N Color Copier
Sharp mx-350n will not print in color from the network
Which model is it? The MX-350N is black and white, the MX-3501N is a color model. I'll assume it's the MX-3501N.
Either it's defaulted to print B&W in which case you just go to your printing preferences of the print driver in the printers menu in the control panel, and uncheck the "black and white print" box, or you have account/user codes that you need to enter in your print driver in order for it to print color. Instructions for adding a user code to the printer driver are found here.
Setup and Manage User Codes Account Control on Sharp Copier
Feb 03, 2014 | Sharp Mx-3501n Color Copier Printer...
Sharp MX 2300n - When I print or copy color, the whole page has a pink hue to it. Not there when printing or copying black/white. I have cleaned the laser holes and pulled the corona knobs several times,...
PRESS #*c* in your control console respectively then you will get a service mode,Check to confirm that there is A3 paper in the paper feed tray. If paper is insufficient, supply it, will ask for main code press 67 then press Start and machine will ask for a sub code press 24, then machine will give you another display press execute on that one, you will get a pattern print out. After completion of self-printing, the display is shifted to the output patch scan start standby screen. Make sure toplace the printed test pattern on the glass pointing the light side of the pattern towards the left hand side that is to place the light side coinsiding with the arrow marking on the glass table, place some white A3 sheet above this to correct the white value, press service and then press execute then machine will give you another print out then on that you press ok on that one and wait for the below display message.
PRINTER ENGINE HALFTONE AUTO ADJUSTMENT MODE
COMPLETED THIS PROCEDURE.
PLEASE QUIT THIS MODE.
After this press CA button on your console and check the copy, repeat the same procedure for 4 or 5 times if the copy quality needs to be get improved. Rate this and vote for this
May 13, 2011 | Sharp MX-2300N Color Copier
We have a Sharp M550N copier. I know we can scan documents to email. Can we scan color documents from this machine?
It is a monochrome(black and white) copier. Generally, any monochrome machine only copies,scans, faxes, or prints in black and white only.
May 02, 2011 | Sharp AR-M550N Copier
I am connected to the sharp mx-3501n via a network and i have been printing in color for some time now, however, recently it only allows me to print in black and white while other people on the network are...
In the properties menu of the printer. Click on the tab of job handling. Make sure your user information and password for the copier has been entered. Without this you can only print black and white.
Jul 28, 2010 | Sharp MX-3501N All-In-One Printer
Wondering if you can help set up a sharp
go into printer properties and see if there is an option for color...
Dec 16, 2009 | Sharp MX-2300N Color Copier
OurSharp MX 2300N printer is used as a share printer, wont print
Chances are when you changed ISP's that network IP's changed and your IT will need to put one into your copier that's compatible with your present network setup.
You'll also need to make sure all work PC's have their printer drivers changed to reflect the new IP address for the copier, or it won't print.
Jun 17, 2009 | Sharp MX-2300N Color Copier
The regular color is pink
ur CCD is going BAD u shud contact Kodak for the problem they might do it free i had same problem in my Fuji S5000 all pink shades in pictures , in sepia and black and white there are no multiple colors so u cant see the full performance of CCD becoz they are one or two colors only , pls contact Kodak they will do it free ask them about bad ccd see link and PLS RATE ME WELL !
http://www.imaging-resource.com/badccds.html
May 20, 2009 | Kodak Easyshare M753 Digital Camera
Sharp Mx-M753u Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
