Screen becomes full of lines and picture dissappear but sound noot affected
    Top Expert:
  • Televison & ... Master
  • 74,118 Answers
These lines are called vertical retrace lines. The fault is related to its video amplifier section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Mar 24, 2014
I have a toshiba 46h84 the picture is very light and lines all across the screen what could this be?
Possible screen controls in the set are up too high---if you turn picture and brightness to zero does the screen get full black?
screens set too high would give diagonal faint trace lines in the picture.
These sets also should get a annual cleaning of the lens and sometimes the mirror inside= if this is the case the picture will usually look darker and dull ----this will not affect lines in picture.
the lens are easy to clean but other actions depend on what your response is to the above information.
Dec 11, 2012 | Toshiba 46H84 46" Rear Projection...
Picture dissappeared suddenly. Power Fuse ok but
Faulty component in power supply or line drive circuits. Take to repair shop or find a second hand one, CRT monitors can be had for free or very cheap now.
Jan 02, 2011 | Dell M992 19" CRT Monitor
Black screen on my Fujitsu Siemens Computers Myrica television
sound no picture does it flash when first powered on ? its the invertor board it controls all the lamps
that light the screen/shine torch into screen you
will see picture/needs repaired google{ohm supplies uk}
Apr 18, 2010 | Televison & Video
TV FADES TO BLUE AND THEN PICTURE DISSAPPEARS- AND SOMETIMES TV SHUTS OFF AFTER GOING BLACK WITH CONCENTRIC GREEN LINES
Turn your screen drive down to green and blue tube.
You have a focus/screen drive control block that you can adjust each tube R/G/B
Mar 17, 2010 | Sony KP-65WV600 65" Rear Projection...
Diagonals lines appears on screen and becomes more brighter
With HV variation the color will not be good. Sometimes I have heard that the screen resistor causes this.
Dec 29, 2009 | Konka K2568U 25" TV
Picture appears only as a thin, horizontal line...
chk vertical amp /vertical drive i/p from oscillator/power to it/power to vertical amp/chk dry joints-hot area/look at vertcal amp capacitors-swelling etc
Jul 04, 2009 | Akai Televison & Video
Vertical lines through the right side of the screen
Sorry sounds like you have a bad panel Try changing picture format if the lines don't dissappear or change bad panel
Apr 17, 2008 | Philips 42PF7220A 42 in. Plasma Television
33 inch Panasonic gaoo bought in 95 picture trble
Check for leaky capacitors in the vertical section of the TV or cold solder joints.
I would also check in the power supply.
Good Luck.
Jan 16, 2008 | Televison & Video
Samsung TV
Hi.
Just read your list of problems The first fault (Diagonal lines & picture collapse from left & right) Sounded like either A poor connection or dry solder joint either on scan coils or scan coil plug / socket on main pcb.
If this were the case the engineer that called out should have spotted this & sorted it very easily. But you say it is still the same so what did he do ?
Did he give you a reciept with break down of what he did ? If yes please post it here for me to go over.
The sound problem you describe has thrown me a little so could you please post your tv model number on this page so I can see if this is a stock fault.
The static shocks you are getting is relatively normal & not a problem unless you are getting them off of speaker grilles or even tv casing if it is silver in colour.
I am UK based & have access to samsung technical but I will need your tv model number.
http://dysonmanuals.inc.io/
Chris.
Oct 30, 2007 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
