Question about Brookstone Mobile Mini Speaker
Blue light flashing
You can't hear anything
Samsung HM700 Bluetooth Headset's light keeps flashing red and blue and can't hear anything, the person on the other end can't hear anything either. Tried re-pairing, but it doesn't work.
Pairing is not the same thing as connecting. The LED will go solid when you complete the next step which is connecting. With headsets that is usually done via the audio source device.
Mar 07, 2014 | Google Samsung HM7000 Bluetooth Headset
Headlight blue light is flashing and won't do anything else
If you hold down the power button (and keep holding!) while wearing the headphones, you will hear three beeps (keep holding! If you lift your finger, you have wait a moment to start over) followed after a moment by two beeps. If you do this while the headset is NOT on, it will enter the "discoverable" mode and the lights should flash red/blue red/blue. If you do this while the headset is on, the second set of beeps sounds a little different, and those tones mean the headset is turning off.
The "manual" (a single sheet of paper) for this device is a joke, and website technical support is nonexistent.
When I first purchased mine, despite the poor instructions, I was satisfied, due to the low price. But I've only had the device for less than a month, and I've only used it three times, and suddenly I can't get it to pair with my laptop or my phone, though it had worked find a couple of weeks ago, last time I used it.
Sometimes you get what you pay for, I guess. Disappointing.
Dec 08, 2012 | Inland ProHT Bluetooth Headset Red
Bush IDLCD26TV16HD blue flashing light?
It is on protection mode due to some defects on the board. Switch off the TV manually, remove the plug and cool it off for 48 hours and retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
I turn it on it works but i cant see the menu or select anything
Try reseting your display, to do this make sure the ps3 is off, then turn it back on and continue to hold the power button until you hear the beeps. Then your display will be reset. This should do the trick.
Aug 04, 2009 | Sony PlayStation® 3 (60 GB) Console
Sony blue tooth hbh-pv703
you need to press and hold the buton until the light stays on to get into pairing mode, when on, go to your phones bluetooth settings, search for bluetooth devices, then when it finds the headset a code will be requested, this is 0000, enter this and the light will flash intermittently telling you its paired with your phone.
Sep 03, 2008 | Sony Ericsson HBH-PV702 Wireless Headset
CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Apr 19, 2008 | Radio Communications
Brookstone Mobile Mini Speaker Logo
87 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
