Question about HP LaserJet 4050 Printer
Hp laserjet printer cleaning and maintenance
Acquired HP Model# C32982A LaserJet (c. Sept 1997). works ok, but pages are 'dirty', with much shading.. looks streaky and rhythmic, like dirty rollers, etc....would like instructions for proper cleaning and maintenance, any help would be greatly appreciated, thanks.
    President:
  • 3,085 Answers
Take the toner cartridge out and turn it upside down and look at the drum. It should be clean if the cartridge is not leaking.
Posted on Jun 14, 2009
I recently acquired an HP 1300n Laserjet Printer for gratis, installed with drivers and HP Toolbox. My issue is print quality, very dark grey background down the middle 70% Have adjusted all the settings...
one possible cause would be the nozzle of your cartridge maybe their is already a clog that blocks the continuous flow of your ink, try to clean the head by using the maintenance software. Go to control panel>printers>properties>printing preference>locate the maintenance then try to access the cleaning of your cartridge, I'm not sure which location of the cleaning of head better to check all the menus. Hope it helps thanks.
Sep 27, 2011 | HP LaserJet 1300 Printer
Hp color laserjet black print fades to the bottom of the page.
dirty scanner.open the printer back cover.remove the scanner assembly clean it ,do the color calibration.u should be fine.
Amuna1
Jun 30, 2010 | HP Color LaserJet 2600n Printer
Print outs have black shading. No replace cartridge or other message.
Based on your limited description, it sounds like a dirty drum is leaving ink on the paper.
HP sells cleaning kits. I recommend that you contact HP for further assistance.
If this helps please vote for my solution.
Dec 18, 2009 | HP LaserJet 2420 Printer
HP LJ 2600 "dirty" printing
If the toner cartridges are "refills" that might explain some of your print quality issues. Unfortunately, HP only has 2 replacement parts for that model, the fuser and the ETB (Transfer belt) both would require a technician to replace. Check the transfer belt of any tears or punctures. Careful not to touch it, oils from your skin can cause quality issues as well. If at all possible replace all the toners with ones that were working fine.
Jul 31, 2009 | HP Color LaserJet 2600n Printer
Old LaserJet 4L working perfectly. Just bought new generic toner cartridge and now getting shading over entire page, turning paper an almost-even gray, darkest at left edge. I'm suspecting cheap cartridge...
You're right about the cartridge and I suppose cleaning it means all the toner that the generic cartridge dumped. Turn off the machine, take out the cartridge and use a vacuum cleaner and a soft brush to get that extra toner out. After that use a soft cloth (not terry) to wipe down the inside.
Apr 06, 2009 | HP LaserJet 4L Printer
Prints dark page
Try to change toner cartridge, I had this happen with my old laserjet 5, and it was a faulty cartridge on mine.
Aug 16, 2008 | HP LaserJet 2550L Printer
Hp Laserjet printer
a vertical stripe that is consistent top to bottom could be a laser issue, it has prisms and lenses that could be dirty or even a bit of paper stuck covering the laser light window. Dig into it and look for any debris and clean the lenses.
Hogdoctor
May 22, 2008 | HP LaserJet 4 plus Printer
HP LaserJet 1010 Printer problem
Hello, 1) Turn off and disconnect the working HP1010 2) Use a new USB connector for the non-working printer, I mean, plug into a differert USB port
Aug 04, 2007 | HP LaserJet 1010 Printer
HP LaserJet 4050 Printer Logo
260 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
