Question about Brookstone Mobile Mini Speaker
It doesn't hear anything
The Blue light flashes.and iit doesn't hear anything,
Samsung HM700 Bluetooth Headset's light keeps flashing red and blue and can't hear anything, the person on the other end can't hear anything either. Tried re-pairing, but it doesn't work.
Pairing is not the same thing as connecting. The LED will go solid when you complete the next step which is connecting. With headsets that is usually done via the audio source device.
Mar 07, 2014 | Google Samsung HM7000 Bluetooth Headset
Laptop won't boot - Compaq
Do you see anything on the screen? Does the HDD LED blink? You can start by removing the HDD and testing it or have it tested.
Jun 06, 2013 | Compaq Computers & Internet
Remote starter doesn't work when pressed
I think that you answered it yourself. Give you 1 point. The continual is the processor searching but not finding its mate. Replace the battery and repair them.
May 11, 2017 | 5101 LE 1 Way Car Remote Starter System
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Jan 14, 2013 | Harman Kardon JBL Flip black
Headlight blue light is flashing and won't do anything else
If you hold down the power button (and keep holding!) while wearing the headphones, you will hear three beeps (keep holding! If you lift your finger, you have wait a moment to start over) followed after a moment by two beeps. If you do this while the headset is NOT on, it will enter the "discoverable" mode and the lights should flash red/blue red/blue. If you do this while the headset is on, the second set of beeps sounds a little different, and those tones mean the headset is turning off.
The "manual" (a single sheet of paper) for this device is a joke, and website technical support is nonexistent.
When I first purchased mine, despite the poor instructions, I was satisfied, due to the low price. But I've only had the device for less than a month, and I've only used it three times, and suddenly I can't get it to pair with my laptop or my phone, though it had worked find a couple of weeks ago, last time I used it.
Sometimes you get what you pay for, I guess. Disappointing.
Dec 08, 2012 | Inland ProHT Bluetooth Headset Red
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I am trying to hear my gameplay through my plantronics gamecom p90 headset i got the headset to work but i cant hear my gameplay through it
If your headset is the P90, turn the headset on. The light on the headset should start flashing red/blue. If it doesn't, start with the headset turned on, press and hold the call control button on the headset until the light on the headset starts flashing red/blue, red/blue. Follow the on screen instructions and let the PS3 scan for the headset. It will appear as "P90Plantronics" in the list of devices. If prompted for a passkey, enter 0000 (4 zeroes). Now go back to the Accessory Settings menu and then select Audio Device Settings. Select "P90Plantronics" as the audio input and the audio output device. You should be all set. If not, you can contact the Technical Assistance Group at 800-544-4660 x5538.
Good luck from Headsets Direct - 800-914-7996.
Aug 10, 2011 | Plantronics GameCom X10 Headset
Sony blue tooth hbh-pv703
you need to press and hold the buton until the light stays on to get into pairing mode, when on, go to your phones bluetooth settings, search for bluetooth devices, then when it finds the headset a code will be requested, this is 0000, enter this and the light will flash intermittently telling you its paired with your phone.
Sep 03, 2008 | Sony Ericsson HBH-PV702 Wireless Headset
Brookstone Mobile Mini Speaker Logo
80 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
