Question about Nespresso Aeroccino Automatic Milk Frother
How to demagnetise aeroccino
It is not rotate
Frother overflows even though I add correct amount of milk, or even less than called for
There are two milk amount markings in the Aeroccino - one (less) for use with the wire whisk attached, and one (more) for use when the wire whisk is detached. I had the same problem when I first used the Aeroccino, but with the correct amount of milk you shouldn't have the problem.
I hope this helps, Carole.
May 20, 2015 | Nespresso Aeroccino Automatic Milk Frother
Where can I read the user manual for a Realistic Model 231x tape head demagnetizer?
The manuals don't have many things to tell. Just move the magnetiser to the head you want to demagnetise. Touch it once and then slowly move the demagnetiser away from the head. If it is far enough (more than 30 centimetre or one foot away, you can switch the demagnetiser of. that is all. Some demagnetisers work on AC, others do have a battery and make the changing magnetic field inside. I could not find the 231X, but to check if it makes a changing magnetic field you could hold it to something made of steel or iron when switching it on. You should feel some vibration. Could be 50 Hz or the ones with batteries have a higher frequency, but could be noticed.
Don't expect wonders from the demagnetiser. With the older tape heads, sound could improve after demagnetising the head, but the later models never kept remnant magnetism.
Success.
Nov 19, 2014 | Audio Players & Recorders
Nespresso Aeroccino 3 does not heat and froth
I got mine today exact same thing happens... only blue does not warm AT ALL
Aug 26, 2012 | Coffee Makers & Espresso Machines
How do i demagnetise tv screen.colours all over the place
hi i hope i can help you with this problem ? to demagnetise you need a magnet for tvs, and all you need to do is run the magnet all over the screen while the tv is on a couple off times. take the colour back to b/w and retune
May 04, 2009 | Toshiba Televison & Video
Nepresso aeroccino doesn't spin fast enough to froth the milk
The company will tell you to turn upside down for 24 hours to reset. I did this but it did not work. Try turning upside for aeroccino upside down for 24 hr. You do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck. I am on my third one. you may be covered under warranty- call Nepresso soon..they cover them for about 1 year. Good luck
Nov 30, 2008 | Nespresso Aeroccino Automatic Milk Frother
Nespresso aeroccino
It would seem that I was not putting sufficient milk into the aeroccino. I amm putting more in now and monitoring the situation. So far ,so good!
Oct 02, 2008 | Nespresso Aeroccino Automatic Milk Frother
I have an Nespresso Aeroccino that will not make froth
Sorry, but it looks as though you have the classic Aeroccino-problem. Nespresso states that leaving the Aeroccino on its base while it is plugged-in to the wall, will cause it to short-circuit (because there is no off-switch on the base, it is continually feeding full power to the frother), and the result is that it makes only warm milk. Replacement is the only solution...I hope you are still under warranty.
Jul 28, 2008 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino part for warming milk
you should contact nespresso to buy a new one.
www.nespresso.com
May 10, 2008 | Nespresso Aeroccino Automatic Milk Frother
Nespresso Aeroccino Automatic Milk Frother Logo
61 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
