Question about GE Kitchen Ranges
Hotpoint range clock humming constantly
I have a Hotpoint model # RS74200505 and the clock located on the front of the oven panel starting making a humming noise, not the buzzing noise when you set the minute timer buts continues to hum constantly, the oven and the stove both work, it is just this annoying humming from the clock. How can we stop it?
SOURCE: Clock on a GE electric range is buzzing - how to disconnect it
Turn off power to range first!!!
You'll have to remove the back of the panel in which the clock is installed to access the back of the clock. There will be two wires attached to the clock. Just pulling one of these wires off will stop the clock.
I would suggest, however, that you pull both wires off, put electrical tape on the ends of the connectors, and tuck them out of the way somewhere around the clock.
Posted on May 03, 2009
yalmer
  • 552 Answers
SOURCE: buzzing noise
The buzzing you are experiencing is most likely the electric valve solenoid coil.
That is the valve that lets gas in when the stove is turned on.
Another source of buzzing/humming can be a mechanical clock, if hter is one.
If it is digital, then it woul not make noise.
Posted on May 20, 2008
SOURCE: Gas range makes buzzing sound which goes away when disconnected from electrical outlet.
Call the manufacturer. Chances are it's a common problem and they already know about it.
Ben C.
BensDiscountSupply
Posted on Nov 04, 2008
SOURCE: GE Spectra range
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
Posted on May 24, 2009
  • 439 Answers
SOURCE: Buzzing Noise coming from GE Stovetop.
It could be a loose transformer that needs to be remounted. Pull the stove out, remove all of the screws at the top and visually inspect the transformers and wiring. This should be an easy fix, but if you leave it too long then your stove will malfunction. I hope this helps at least get you to the next step.
Posted on Jun 21, 2009
Humming noise
As far as I can tell this oven has an analogue clock on the front.
The noise is probably the motor that turns the clock hands. It would benefit from a tiny, tiny amount of oil on the motor. But it will get warm and all oil will burn off.
Dec 20, 2013 | Thermador C302U Electric Double Oven
The instrument panel flickers constantly both for the clock and for the oven settings
The Display is shorting out, bad news is it is part of the ERC (Electronic Range Control) Pricy to replace, go to marcone.com with your model Number and you can order the part, not hard to replace
Jun 12, 2012 | Frigidaire PLGF390DC Stainless Steel Gas...
All elements including oven isnt working but the clock is on
Have you checked the fuse/fuses? they should be located under a flip cover at the top of the control panel.
Sep 02, 2010 | Hotpoint RB787 Electric Kitchen Range
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
The oven starts beeping and flashing F-2
First shut off breaker for 5minutes and see if it resets if not,
F2 indicates a high temp was reached. Remove the temp sensor it is located inside the oven near the top back. 2 screws hold it in.Carefully pull it out there will be 2 wires attached. Check with an ohmeter should have a reading of about 1100 ohms +- 10% if not within that range replace the oven temp sensor. If it checks out good you will need to replace the ERC electronic range control /clock. Both are easy to replace. If you need diagrams or illustrations of your specific model enter your model # at www.appliancehelponline.com. All parts come with installation instructions.
Apr 14, 2010 | Hotpoint RGB745 Gas Kitchen Range
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Range indicator light doesn't shut off
the poles for the light are reversed or miswired
at the selector switch
make sure the light goes back to p1 or p depending on your switch
Oct 09, 2009 | Kitchen Ranges
Oven clock replacement
If you are sure you have the correct clock for your model have followed instructions completely, tape up loose wire ends individually and give it a try.
Sep 07, 2017 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
156 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
