Question about Eureka Pet Expert Bagless Upright 3276BVZ
I have a missing part
I loaned my vacuum to a friend and they lost the filter and the filter cover(the round gray piece that goes over the filter). . .is there any way to get a replacement filter and cover?
Where is riccar radiance filter reset button
Remove the bag door, you will see a little round rubber piece about 1/4 in diameter on the motor cover. Remove the rubber piece and very gently push the button while the brush roll motor is running
May 15, 2014 | Riccar Vacuums
I removed the bottom medal plate, covering the brush, and there were 3 additional pieces that fell out - 2 clear and 1 darker gray (aprox 2" H and 1.5" W). I can not figure out where this last piece goes...
I've never seen a Dyson with a "medal". For that matter, I've never seen a Dyson with any metal parts either, except the screws.
You should take it to a qualified vacuum repair shop to make sure the parts aren't necessary before running it again, just in case.
Oct 16, 2013 | Dyson DC15 Animal Bagless Upright Cyclonic...
A piece fell out when I was emptying the bin and I can't figure out where it goes. Gray, about 4 inches long, strait with small pegs down one side.
It sounds as if this is the piece desinged to scrape lint from the screen on the filter cartridge holder. There should be two slots near the top of the dirt cup, about in the middle, that this piece snaps into, with the pegs facing the filter.
Mar 19, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Please advise the type of bags used for the Shark Euro-ProX vacuum cleaner as it does not say anywhere on the unit. Kindly advise. Email diannes@live.ca. Thank you.
That is a bagless vacuum. It does not require any bags, but you do have to clean the filters every so often. There are three filters in the top canister, and one in the base by the motor. Press the black button on the front of the canister and pull out to release it. Pressing the lever on the back will release the bottom black piece, emptying the contents. Do this over the garbage, or outside. It can be messy. Twist the top gray piece (the part with the first button and handle) counter-clockwise to open the filter area. This will reveal a black lid. Remove it, and the three filters underneath. One is a round black and gray conventional style filter, one is a foam disk, and one is a screen area on a tube. Shake them out (outside), tapping them on something hard like a railing or the ground, and rinse them under running water. Shake the water out of them, and reinstall them.
The last filter is behind the gray slotted panel in the bottom of the main body. Press the tabs on either side and pull the panel outwards. Shake this filter outside, but don't wash it. This is the intake filter. If you get it wet, water may get on the electric motor. Keep it dry.
Hope this helps!
Nov 20, 2009 | Euro-Pro UV209 Upright Vacuum
When I took the base cover off the vacuum to clean the roller, a metal piece that is bent in half, as well as a white plastic stick piece came flying out. I think it might have to do with holding the...
They go in the slot beside the right wheel. Metal spring first, (the open ends facing away from front of vacuum base. The white nylon piece lays parallel and directly on top of the metal spring, round edge up, and aligned with the open ends of the metal springs.
Aug 09, 2009 | Eureka 411A Upright Vacuum
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
Round filter clogs often
The Flange in question is about one inch tall and and approx 4 inches circular ..... When you pull the canister (container to empty) off and empty the contents in the trash .... some of us tap it to get the excess out or off the sides ..... That Flange is the rubber piece attached to the bottom of the darker gray cylinder inside the canister you are emptying. When you tap the canister or after dumping it numerous times that flange can work itself (slide) up the darker gray cylinder ...... it needs to be slid downward and overlap the bottom when you close the canister from dumping it. You can remove the flange and see the grooves .... replace it back on with it hanging off a little to allow for overlap. That should decrease the amount of excess being trapped in the filter. Hope this helps.
Jul 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Shampo system
here is a site that has detailed instructions for using your kirby shampooer.
the screen that goes in the hose is different from the filter (round flat sponge) that goes between the exhaust side of the kirby and the shampooer tank. The screen is what makes the suds...if its not seated properly or missing (or damaged) then it won't make suds.
http://www.greatvacs.com/shampoo.shtml
this site shows a picture of the piece I'm describing...its the 3rd picture down, called the gauze filter...still its different from the sponge filter....
also...make sure you go slowly with the kirby (and lower it to its lowest setting) if your carpet is heavily soiled....the enzymes in the shampoo are what clean the carpet (oils, grime, etc) and if its heavily soiled the suds disappear almost immediately.
Hope this helps!!!
Feb 03, 2008 | Kirby Ultimate G Bagged Upright Vacuum
HOOVER STEAM CLEANER PROBLEM
The soap dispenser is supposed to be attched to the water tank. That grey piece, if it is round with 2 small ears on it is the metering plate, it controls the flow of water. It sits on the table that the tank sits on, insert it into the hole and turn to lock it in place.
Jan 14, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Kirby shampooer
You may be missing the small round suds screen. It should cover the hole where the shampoo goes from the tank into the hose. It may be wedged sideways in the hose end.
Marci
Sep 13, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Eureka Pet Expert Bagless Upright 3276BVZ Logo
23 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
