My philips led tv made a pop noise then turned off
My philips led tv made a pop noise then turned off Now it dont turn on at all Its not dusty still clean What can b the problem ?please help
    Top Expert:
  • Televison & ... Master
  • 75,591 Answers
Please contact the authorized service centre for Philips in this case. It is its main power supply regulator board fault.
Gopakumar Gopalan Google
Posted on Mar 23, 2014
  • 8 Answers
SOURCE: tv will not turn on--- flashing red led
You will need to take the TV in for repair. The red light is the TV's way of telling you the protection circuitry has been tripped. There is most likely a problem with the power supply inside the TV.
Posted on Jul 13, 2007
marketex
  • 371 Answers
SOURCE: Philips Tv won't power on.......
Try plugging in the USB drive and HOPE that the P.O.S.T. during that 2 second period grabs the upgrade, but I must tell you that this is a hail-mary pass.
After that, it's DOAville!!
Posted on Mar 29, 2009
ginko
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
SOURCE: Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Posted on Dec 14, 2009
SOURCE: 42PFL5332D/37 does not turn on red light flashes 6 times.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Posted on Jan 24, 2010
Testimonial: "Thank you for your help, I will give it a shot!"
2003 philips 50" plasma tv with picture fading. How do I fix this?
Hi,my philips plasma 50FD9934 dont turn on just led flasing red and green contniusly.Please help!!!!This is a power suply problem?thanks
Nov 14, 2009 | Philips 50FD9934 50 in. Plasma Television
Tv turns off after watching an hour - then proceeds to turn off every 15 to 20 minutes there after
Hi if your tv is a DLP or LCD and you hear clicking or like wanting to turn on ,most likely its an issue with the ballast which is the board that powers the lamp.(Discard if tv is )If you hear buzzing or spinning noises it could be you color wheel.Also check if fans are running ok or if they are dusty, clean them with an air pressure can if they are dirty.It could also be time to replace the lamp.they normally last 6000-8000 hrs if it's a Philips brand if it's na Osram lamp they will last 4000-5000 hrs 1-2 yrs.God bless you!
Oct 05, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I need the code for a phillips universal remote model CL034 to go with a durabrand tv?
Probably not going to find a specific code since durabrand is a walmart branded tv, your best bet is to try the automatic mode of your remote, or try different brands of tv, starting with sharp/sanyo/sony as those brands are ones that walmart sells most.
Sep 23, 2009 | Philips Universal PH301S Remote Control
My W3201C 32" LCD TV made a loud popping noise when I turned it off. Now it will not turn on. No power. No LED light.
That would be your transformer popping and dieing. Usually the popping is followed by a burning smell which is a good indicator that the part is unrecoverable. The cost of the part is variable based on the make and model TV and is usually not too labor intensive to replace. If not under warranty, let the repair gut know that you know what the problem is. Then, ask them to quote the cost of the replacement part and part number. Then ask them to quote you their hourly rate and get a time estimate. Then, google the part number and see if the cost is reasonable.
May 02, 2009 | Televison & Video
TV randomely turns off
it may just be a static buildup from the dust.
open the tv and blow it out with a air compressor.
if that doest not work then the circuit may be overloading.
remember it stores a charge for days.
Feb 17, 2008 | Philips 30PW9817 30" TV
Sparks
Thats the CBA board heres a link where you can get one but its expensive.
http://www.partstore.com/Part/Royal+Philips+Electronics/Philips/313926720561/New.aspx
Oct 17, 2007 | Philips 60PP9200D Television
Tv will not turn on--- flashing red led
I'm sorry, I don't have a solution, but I seem to be having a similar problem. When I turn my TV on, the green light comes on like it's powered up, but then the TV turns itself back off and the red LED light flashes. I can't do anything to turn it on or anything.
Jul 11, 2007 | Philips 37FD9954 37 in. HD-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
