Question about Symantec WinFax Pro 10.0 for PC
When I make an entry in number rings before answering, Winfx shuts down.
  • 143 Answers
How to manual for WinFx video converter
I try to use W9inFX Video Converter , but it seems not easy to use. I search for the internet to find an all-in-one and easy-to-use Xinfire Video Converter. Maybe you can try to use this one.
If you are mac user, try to use Xinfire Video Converter for Mac .
May 30, 2013 | Geeky Dads Software WinFX Free Video...
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
Change number of rings before answering
Change the ring count on the fax when the receive mode is set to Fax/Tel or FaxOnly modes. Change the ring count on your answering machine when it is connected to the fax and the receive mode is set [Ans mc connect] (Answering Machine Mode).
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button.
  3. Press the left or right arrow button to select [Maintenance/settings], then press <OK>.
  4. Press the left or right arrow to select [Device settings], then press <OK>.
  5. Press the up or down arrow to select [FAX settings] (item <1>), then press <OK>.
6. Press the up or down arrow to select [RX settings] (item <3>),
then press <OK>.
7. Press the up or down arrow to select [Incoming ring], then press
<OK>.
8. Press the up or down arrow to select [ON], then press <OK>.
Note: The default setting is [OFF]
    1. A window will appear displaying the number of rings before the machine will answer. Press the up or down arrow to select the number of rings (from 1 to 30 rings).
    2. Press <OK> to set the number of rings.
9. Press the <Stop/Reset> repeatedly to return to Fax standby
mode.
I hope this helps.
Apr 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
How do you change the number of rings before it answers? Please
- Press MENU
- Scroll to "Initial Setting" by pressing the up or down arrow
- Press SELECT
- Press SELECT at "Set Answering"
- Press SELECT at "Number of Rings"
- Select the number of rings using the up or down arrow, or press any number 2 thru 7 or 0
- Press SAVE
- Press OFF
Need the full manual for your phone? You can download/print it here:
http://support.radioshack.com/support_phones/doc73/73355.pdf
Dec 14, 2009 | Panasonic KX-TG2357 Cordless Phone
IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
Every time when the phone rings and I answer it the fax kicks in with that really annoying sound. I have to shut down the fax and plug it back in after I am done my call. what is the normal setting for...
The fax is on what you call a Distinctive Ring tone. You need to go in to the settings on the fax machine, and look for Ring type, or Distinctive Ring, And set it to 2 or 3, Dependent on how the phone rings on the fax number.
Nov 25, 2008 | Samsung Office Equipment & Supplies
Changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Feb 14, 2008 | Uniden Cordless Phone
Panasonic 816 phone system
What you need to do is set the number of rings before answer on the phone to a number greater than the number of rings it takes before AT&T answers (for example, set AT&T to answer after 4 rings and the phone to answer after 5). Some phones have switches on them that allow you set the number of rings. Some make you set the number through their software. Look on the body of the phone, particularly the sides, for that switch and set it to the biggest number it offers.
Nov 16, 2007 | Toshiba DKT-2020 Corded Phone
Symantec WinFax Pro 10.0 for PC Logo
91 people viewed this question
Top Symantec Computers & Internet Experts
Lisa
Lisa
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
