Question about RCA DRC8300N DVD Recorder/VCR
RCA DVD Recorder + Video Combo does not even turn on.
I don't know where the fuse is so I can first check that. Otherwise, I haven't a clue. I have watched two DVDs on this machine and have watched no VCRs because of its complication. It has never made a DVD from a Video. Obviously, it has been useless to me. I called while it was under a 2-year warranty (up in May of this year) and received no help. Now they won't even answer where the fuse is without a $65 up front fee. Would I recommend the unit? No, NO, No! If anyone can help me, please do. Thank you so much.
  • 3,230 Answers
This unit have a great value.
The fuse is located inside the recorder,
before checking the fuse you need to check the power board, power plug, power cable, than fuse.
Good Luck!!
Thanks
Posted on Jun 14, 2009
My 2 yr old rca tv/dvd combo will not turn back on all the time
You do know that those have a fuse in them don't you? I would check that.
Oct 27, 2014 | RCA 20F510TD 20 in. TV/DVD Combo
DVD and VCR recorder with this product?
As long as you have Composite/SVHS Video Input, Usually a Yellow RCA Socket or a 4 pin Mini-DIN & red & White, AV (Audio Visual) RCA sockets on the machine, AND you can select an "External" input, then YES anything that can connect with this way will work.
Feb 10, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Diagram to set up the Panasonic DMR EZ47V DVD/Video recorder
Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the LCD . Connect the AV output of the Sky box to the AV input of the Panasonic combo.
Hope it will cover the matter
good luck
Jan 29, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
How record tv chanels using the DTV converter box? The converter box determines the chanel of interes while the DVD recorder must remain on chanel 3 in my area. My DVD recorder is a combo with a VCR...
Can you connect directly from the DTV converter to the DVD recorder input using RCA phono connector cables? You'll have to select the input on the recorder menu as well.
Oct 21, 2009 | GoVideo Go Video DVD/VCR Combo
Where is the fuse on the RCA DVD+VCR Combo (DRC8320N Model)? Please do not be too technical.
UNPLUG the unit... put it in front of you,, unscrew the 2 screws on the side and 4-6 that hold the COVER only... take cover off.. the fuse is on the top left side.. check it if no good replace it. Thats it.. oh put the cover back on .
Jun 07, 2009 | RCA DRC8320 DVD Recorder/VCR
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
RCA controller not working
I have a similar problem with my universal remote and DVD player/recorder. there are some remotes that will not work with a different brand of unit, that is the best I can tell you.
Nov 13, 2008 | RCA 3-Device Universal Remote with...
Rca dvd/video combo
No activaste sin querer la funcion progresive scan,si lo hiciste trata de desactivarla.
Jan 20, 2008 | RCA DRC8300N DVD Recorder/VCR
RCA DRC8300N DVD Recorder/VCR Logo
64 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
