Question about Sony Handycam DCR-IP1 Micro MV Digital Camcorder
Black screen black screeen, when i switch my camcorder on it all works but my lcd screen is blank,,
  • 1 more comment
  • hypermetric Dec 07, 2007
    yes i have the same problem. for a while it worked when you completely flip the screen and then close it with the screen facing outside, but now that's not working either. it seems a lot of users and cams on ebay have the same issue... sounds like bad engineering to me.
  • flenginr Dec 08, 2007
    I have the same problem. The lcd screen works if I turn it around and close it facing out, otherwise it's black. It looks like Sony will repair for $311.00. I'm thinking of taking it apart myself to see if I can fix. Seems like it just has a bad contact. I found a repair manual on-line for $16.00; may be worth it. I'll let you know if I get the solution.
  • Anonymous Jun 10, 2008
    I have a problem with my DCR following comments by other users yes I turn the the screen round and I no longer have a blank screen? HELP !!!!!!!!
    Problem Solver:
  • 6 Answers
The LCD screen on my Sony gradually lost the image. It is caused by the flexi/ribbon cable that runs from the camera body to the inside of the LCD screen breaking down. The copper tracks have broken. They may sometimes touch to give you a connection , but it will get worse. A replacement flexi is the only answer.
For my DCR-IP1E it cost me £31 (thats uk money....not dollars)
Sony Part Number A-7111-611-A (FP733 Mount) Taking the old one out was slightly tricky, putting the new one in is very tricky! I work in electronics, so I could achieve it but if you are not happy with electronic stuff, find someone who is.Straight forward for a repair shop expert. Tools needed? Just a small cross head screwdriver. Keep all bits with a note as you go along. Good luck.
Posted on Apr 02, 2009
  • thiswilldo Nov 08, 2016
    Bit of a late update to my answer about replacing a flexi.
    If you search YouTube for Flexi replacement for a Sony DCR there is someone actually doing this type of repair although it might not be for the camera you have. But it does prove that it is possible to change it yourself with just a couple of small cross head drivers.
    Maybe also take some photos as you dismantle the item so you can see how it all goes back together again, that's the tricky bit!
When I look to the viewfinder I have a blank screen
Viewfinder, screen and pictures are blank / black - Nikon ...,+screen+and+pictures+are+bla...
iFixitMay 4, 2015 - When I look through the viewfinder or at the lcd it is blank / black. Also when I take a picture and view it on my computer, the picture is blank ...
SONY ' eSupport - There is no picture or a black screen ...
Dec 8, 2015 - There is no picture or a black screen appears in the viewfinder or LCDwhen attempting to ... Look to see if an image can be seen in the viewfinder or LCD. IMPORTANT: Some camcorders have both a viewfinder and LCD.
There is no picture or a black screen appears in the ...
Jan 11, 2016 | Cameras
Black screen
hello, the camera works?..only the screeen does not work?..i can give you a link from where to get the service manual maybe it will help, check below link:
good luck
Aug 28, 2013 | Sony HVR-Z1 Mini DV Digital Camcorder
My handycam screen is blank and doesn't show anything
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
* It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed.
2. Ensure a fully-charged battery is inserted in the camcorder.
3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
4. Turn on the camcorder and set it to the CAMERA mode.
5. Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
6. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Dec 23, 2010 | Sony Handycam DCR-HC40E Mini DV Digital...
My Sony Hc42 camera LCD, view finder gone blank
cheak ur lcd srip and there is a samll switch that chaing over switch cheak it
Jul 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Inside the door hinge area is a small switch that normally would turn off the viewfinder and turn on the LCD panel. THat switch could be defective or mechanically not being switched. WIthout opening up the unit, I can not tell specifically. This shouldbe a simple repair for any shop that repairs cameras.
Oct 06, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
LN-T3253H issue with camcorder
Samsungs will not switch to an input that has no signal going into it. Try putting the cables into the TV, then hit play, then switch to the correct camcorder input.
Dec 24, 2007 | Samsung LN-T3253H 32 in. LCD Television
Black lcd screeen on my sony handycam
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....go to a sony service center for replacing that...i know it is free for replacing that sensor cause that is the recall product not only on sony but in other brand because the manufacturer of their sensor is only one company....
Oct 19, 2007 | Sony Handycam CCD-TRV328 Camcorder
Sony Handycam DCR-IP1 Micro MV Digital Camcorder Logo
367 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
