Xerox Phaser 6500 Printer is having problem in firmware as it is giving Fault Code 116-364 & Clock Error. Also it is
Xerox Phaser 6500 Printer is having problem in firmware as it is giving Fault Code 116-364 & Clock Error. Also it is having problem while detecting Black Toner as it always shows Replace Black Cartridge even after installing new toner.
  • 37 Answers
SOURCE: Xerox Phaser 6110 claims new toner cartridge is empty
Could be many things...depends on the exact nature of the problem. Where the machine states "Invalid Toner" either the machine itself or the toner cartridge may be the wrong "region". i.e. has been sold in the wrong country..the initial toners will work but as soon as you put new ones in they will give this message. If the machine is still displaying "out of toner" then either the toner cart itself is faulty (assuming they are original Xerox carts) or the Image Unit could be faulty (the bit they plug into). Failing that, it will be a faulty Main PCB. The Toners on these have a crum chip, so they cannot be just re-filled and some that may seem "compatable" will not work either.....
Posted on Jun 30, 2008
SOURCE: 3100CN keeps asking to replace black toner tried 2 new catridges!
We have several 3100cn were I work. One has the above symptoms: very long calibrating cycle followed by the replace black toner message. I thought I could fix this by exchanging cartridges between the two printers to find the culprit. No success.
I then started looking for mechanical differences between the two printers -- and noticed that the roller BEHIND the black cartridge (take the cartridge out, look into the printer, and you'll see a partially hidden horizontal roller, perhaps part # C5396 2nd Bias Transfer Roller Assembly) was much more wobbly on the bad printer. I've yet to replace it (does not look easy), but I think this is the culprit.
Posted on Jan 03, 2009
SOURCE: Xerox Phaser 6125 Color Printer
I called Xerox and it seems that it's because the imaging unit is defective. They are seeding me one free of charge. Hope you can do the same...
Posted on Mar 03, 2009
  • 49 Answers
SOURCE: Color Printer Xerox Phaser 6180 Black Background Print out
Try the link below. If the toner is leaking from the cartridge return it to shop were you got it if it is damaged.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=466,E=0000000001344030351,K=1906,Sxi=11,Case=obj(1307)
Niallbt
Posted on Mar 30, 2009
  • 49 Answers
SOURCE: xerox phaser 7300 toner cartridge problems
Sometimes on this machine as there is a lot of loose toner around it can cover over the sensors in the machine, what I would advise is to remove all the toner cartridges and check for the copper contacts on both the machine and under the imagining unit (which the toner is placed in). Once you have cleaned that away slowly close the lid and reboot the machine and it should return to normal. Its just toner getting caught up in the sensors. Follow the instructions below, when you remove the unit, lift it over your head to find the copper contacts and clean them, be careful not to spill toner everywhere. Good luck!
Reseating the imaging unit
    Remove the toner cartridge:
  1. Open the top cover.
    caution_image88x30.gif The imaging units are sensitive to light. Do not expose the imaging units to light any longer than necessary to remove it and cover it. Failure to follow these instructions may damage the imaging units.
  2. Identify the color of the toner cartridge to be replaced (Cyan, Magenta, Yellow or Black).
  3. Move the orange lever on the toner cartridge to the right so that it unlocks.
  4. Lift on the back side of the toner cartridge first, then guide the cartridge out of the printer.
  5. Set the toner cartridge on paper to avoid any toner spilling.
    Reseat the imaging unit:
  6. Lift the imaging unit straight up out of the printer.
  7. Line up the guide pins with the printer's frame and lower the imaging unit back into the printer.
    Reinstall the toner cartridge:
  8. Install the toner cartridge by guiding the front onto the new imaging unit first then lowering the back.
  9. Move the orange lever on the toner cartridge to the left so it locks.
  10. Clean the LEDs with the supplied wipe.
  11. Close the top cover.
Posted on Mar 31, 2009
Is there a service mode on the xerox phaser 6500 ?
To enter Service Diagnostics on Xerox Phaser 6500:
1.turn the printer off ;
2.press and hold both the Up and Down arrows and turn the printer on ;
3.when Service Mode and ESS Diag appear on the display, release the buttons. You will need a Service Menu Map to navigate through the menus, they are quite complicated.
Jul 03, 2013 | Xerox 6500/N Phaser Laser Printer
Xerox Phaser 8860 error code 04, 025,.46:0?
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Jul 02, 2012 | Xerox 8860dn Phaser All-In-One Thermal...
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
Error code 117-363 printer starts machine is awake
only see error code 117-363 and not permited other option
Nov 26, 2009 | Xerox 6180MFP/N Printer
Phaser 8200 error code
I think I had this error once. Could be your bulbs (one or both) are out or are on their way out. I had to replace mine. They are 150 watt halogen bulbs. When you open it up, do you see lights on the side peering in?
Jul 02, 2009 | Xerox Phaser 8200 Laser Printer
Fault code
arrwup.gifDescription An error has occurred related to the Electronics Module 50 V Power Supply. The clutches operate at 50 V. The Head Maintenance, Deskew, and Pick clutches are drawing too much power indicating a short in the supply or one of the components connected to it.
Mar 13, 2008 | Xerox Phaser 8500/DN Printer
Error code 11,009,46:1444 on Xerox Phaser 8500
A fault code search on Xerox's website says this is an electronics module interface fault--just doesn't say how to fix it!!
Oct 03, 2007 | Xerox Phaser 8500/DN Printer
134 people viewed this question
k24674
