Question about Home
How do i fix a PO5 error message on a thermos can 4020
The thermometer is only 2 years old
I can not change the old voice message recording or name on my alcatel 4020
I have had this trouble too, and the answer is remarkably simple - with the handset DOWN, press the [i] button to access the menu. It sounds like the error you had was from doing it with the handset off the hook. Hope this helps.
Mar 15, 2013 | Alcatel Premium 4020 Graphite Lcd Display...
We have the Braun 6022 thermometer. It is reading in C so temps are coming up (ex. 37.1 C) how do we get it back to F
If you whish to switch from Celsius to Fahrenheit, proceed as follows:
(1) Make sure the thermometer is turned off.
(2) Press and hold down the Start button (IRT 4020)
or the «I/O» button (IRT 4520). After about
3 seconds the display will show this sequence:
«°F» / «SET» / «°C» / «SET» ...
(3) Release the Start button / «I/O» button when the
desired temperature scale is shown. There will be
a short beep to confirm the new setting, then the
thermometer is turned off automatically.
Mar 04, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
Need to convert C to F
Changing the temperature scale Your Braun ThermoScan is shipped with the Fahrenheit (°F) temperature scale activated. If you whish to switch to Celsius (°C) and/or back from Celsius to Fahrenheit, proceed as follows: (1) Make sure the thermometer is turned off. (2) Press and hold down the Start button (IRT 4020) or the «I/O» button (IRT 4520). After about 3 seconds the display will show this sequence: «°F» / «SET» / «°C» / «SET» ... (3) Release the Start button / «I/O» button when the desired temperature scale is shown. There will be a short beep to confirm the new setting, then the thermometer is turned off automatically.
Feb 16, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How fo I change the degrees from C to F degree ?
Feb 10, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
I have a Braun thermoscan type 6022, but code po5 always comes up. What does that mean?
It's not po5, its pos... you're not positioning it properly in the ear canal.
Jan 26, 2011 | Braun Health & Beauty
Kenmore side-by-side with thermo switch problem?
Acting like a bad thermostat, One thing to check is make sure compressor isnt overheating. If really hot you could have a relay problem on compressor.
Jan 05, 2008 | Refrigerators
Home Logo
60 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
