Need to download an update for my modem soniq cwr150ns
Having issues with my internet speed after talking with isp they say my modem is the problem with my speed can i download some sort of update for it to fix the problem or do i have to go buy another one the modem i have is only just on 12 months old it is a soniq cwr150ns
  • 21 Answers
Go to your modem web page i.e. "192.168.1.1" with username : admin and password: admin(default) and Check the version of firmware installed and then check if update is available on internet. If yes you can download the update else switch to new modem.
Before switching to new modem ask you ISP to provide configaration so that you can have max speed with your modem.
Posted on Mar 23, 2014
mastersaintx
  • 928 Answers
SOURCE: slow modem
An option that you can take is to possibly update the firmware of your modem. If that does not work contact your internet provider for a replacement depending on the arrangement you have. (Whether or not the modem is in rental or purchase plan) if its under warranty have it replaced.
Posted on Oct 23, 2008
SOURCE: I have high speed internet thru Comcast and have
Push the reset button after you connect it to a new source. Its located on the back next to the Ethernet cable.
Posted on May 14, 2009
  • 87 Answers
SOURCE: Toshiba Cable Modem PCX1100u
OK. First of all you do not need a special or seperate driver for the Ethernet port. Its factory loaded with your OS.
All you need to do is plug the Ethernet cable into the LAN port on your HP Desktop and then into the LAN port (not the WAN port) of your cable modem.
The second thing is if its only a cable modem, then I suggest you proceed with caution as there is NO built-in firewall on a cable modem. Yes you will get on the net, but you are likely to be attacked with virus the moment you connect. I suggest you check very carefully whether the cable modem (if that's what it is) does/does not have a firewall as you would be very unwise connecting up like that.
Next, forget USB connection to the router/cable modem. That technolgy we've moved on from.. Your Vista shodul be 'plug n play' adn should configure the router for you. obviously that bit isn't so slick on yours.
Let me know how you get on..
Posted on May 27, 2009
  • 10 Answers
SOURCE: Agere Win Modem Driver Version 8.30.0.0 vs V.92
you have a v.92 modem even if it lists as v 90 just run a windows update,, look for hardware updates, , if none comes up for the modem you should be good .
the last update was to 8.30 for v92. .. v90 etc. . it wont make that much of a difference in speed. .. however
A phone line filter WILL make an amazing difference, having worked for a dial up isp before , trust me , they help alot. .. its worth 12-22 dollars from any radio shack or maybe even walmart.. . i've seen them in home depot as well but don't spend more than 25 dollars. .
"phone line filter" look for it on radio shacks website
http://www.radioshack.com/product/index.jsp?productId=2103593&numProdsPerPage=60&retainProdsInSession=1
the picture is accurate.. not sure of the description, that thing is not for two lines.. its a a single male end --- to --- female end filter no bigger than a permanent marker. .
good luck. . oh.. it should increase performance from say 34k to 48/56k orn your modem. .
good luck. . its the next best thing to having new lines put in... to your house.
or usb broadband from cricket.
Posted on Nov 17, 2009
  • 19 Answers
SOURCE: slow download speed on motorola SB4200
open the internet explorer2_bing.gif on the addresss bar put 192.168.100.1 then go to hack add on file adress file d11_m_speedtierextreme2_c01.cm
then on ip server file put 68.87.68.35 the press change id then unplug the modem then plug it back the speed should be back
Posted on May 06, 2010
Slow internet download speed
Run a virus and malware scan if not infected your ISP is the problem
Oct 26, 2013 | Computers & Internet
Wondering why my internet is so slow..?
It may connection problem or may problem in your modem or router.
To increase your Internet speed use following tips given below:
1.Contact your ISP. and get a latest speed plan from them. It's better way to increase your speed
2. clear your cookies from your browser
3. Delete unwanted files using CCleaner software.
4. If we are using a DSL connection over our landline, make sure that we have high-quality filters in place to get optimum signal speed.
5. Tweak your router settings
6. Reduce your bandwidth overhead
7. Reset your network
After, completing this steps, you can check our internet speed from this site ScanMySpeed.com
Sep 19, 2013 | Thomson Genuine Unbranded Tg585 V8...
My modem is tooo slow even i cannot see any videos, it is taking so much time also it`s downloading speed is also very slow. Often my modem get disconnected automatically --- please help me out.
Is this the problem with the modem or the router..? If its with the modem then contact your internet service provider(as the line might have some issues) and if its your router then please follow the following steps..
1) Disconnect the power from router for a minute and reconnect and check. 2) Try changing the wireless channel and Network name and try re-connecting. 3) Check if there is an firmware update for your product and update if any update is available. 4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Feb 16, 2011 | Computers & Internet
CAN YOU SPEED UP A SPEED STREAM 5100 OR UP DATE IT
1: all you can do in a modem that really works is reset.
2: Another option if you upgraded your computer to vista or windows 7 from xp.. you might need to get a firmware update done by your internet service provider.
3: get a frimware update from ISP an will set up your internet speed unless its a problem from backend.
Oct 29, 2009 | Efficient Networks SpeedStream 5100 Modem
My modem keeps losing internet connection
Update your drivers and then do a speed test. Most isp send updates to the subscribers when they update, yours may not. Don't forget to check all of your connections before wasting time calling your isp. I trust this test the most. Rember you don't always get what you pay for.
http://www.speedtest.net/
Aug 17, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Upload Speeds Slow, Ping High
s it is ur problem of ur LAN card..check the speed of ur LAN card..
Aug 16, 2009 | Acer 91.AB370.001 Network Adapter
My net disconnects alot
make sure your modem driver is updated, which you can download from the computer's maker's website's support center.
example: hp.com->support&driver
if your modem driver is already updated, then the problem is with your isp (internet service provider). Try calling them about this issue to get an idea of why their bandwidth is having issues.
Jun 25, 2009 | Computers & Internet
My download speed for both torrent and direct is very slow
To find out youre internet speed;
www.speedtest.net
(make sure you dont have any applications that use youre internet. this is to get the correct speed)
You can set a limit for what the torrent can download for.
Right click it and find out how
(i dont know what client you use)
May 27, 2009 | Siemens SpeedStream 5260 ADSL LAN Modem...
Slow downloading
the porblem seems to be at your ISP.
you need to check with your ISP and verify wha is your upload and downlaod speed. most of the time you should have 5Mb upload and 10Mb download as min.
the speed you are seeing is more like a dialup 133Kb.
Feb 08, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
My solution was to go to Staples and they were able to help me.
Thanks.
Feb 05, 2009 | Agere FM56 / 56k -V. 92 (Lucent) PCI Soft...
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
