Question about Toys
Rc manuals need a instruction manual for a b6ac 80w dual power professional balance charger/discharger. Please help
It's black with white letters that read B6AC80W
2 Suggested Answers
SOURCE: I need the instruction manual
I have one for you, but i need to scan it....
Shamiel
Posted on Nov 05, 2010
Testimonial: "Thank you that would be great."
I have a Schumacher 6/2 amp dual charger, SE-82-6. I took off the clamps. Now don't know which wire is positive. One has a white line on it.
Get a volt meter and hook up the test probes to the cable ends and turn the meter on, the meter will say 12 or -12 if it says 12 then you have the red and black from the meter connected to the red and black on the charger in the right manner, if it says -12 then you have them reversed. Take the cable clamps and put them back on.
Mar 01, 2016 | Schumacher SE82-6 Manual Charger...
How to replace power fuse
You have to unscrew and open the charger. Inside you will see the main board and the Power Suply Unit (black box). If the problem is in PSU have to open it and change the fuse inside. May need some soldering skills there. The position of the fuse and the type depends on the manufacturer. There are many fake imax models and never have the same PSU . Even the original has different psu.
Now if the problem is on the board you need more experience in electronics and soldering. In this case better buy another one from ebay.
Aug 11, 2014 | Generic New Digital Lcd Imax B6-ac B6ac...
Wiring honeywell th8320u1008
Be sure you are looking at the letters set up for heat pump. Orange should be "O". Remove jumper between w2 and e. Then be sure you have the settings correct in the tstat for a heat pump with back up heat. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 28, 2017 | Heating & Cooling
Need help wiring this theromostat. I ahve the following color wires.....Green Red Black Blue White Yellow and Orange. Need to match them to the following connections: G RC RH Y/O W/B Y1
G= Green Wire (Fan) RC= Red Wire (Power Cooling) Y1= Yellow Wire (Cooling Contactor) RH= Black Wire (Power Heating) WB= White Wire (Heating Control) YO= Orange Wire (Damper Control)
Blue Wire is usually to C= Common
Nov 28, 2010 | Heating & Cooling
Need wire diagram 4 kenwood kdc-122
Red wire is switched power (only has power when key is turned), yellow is constant power, black is ground, blue is accessories (e.q. or amp switched power), dual grey, dual blue, dual white and dual other is for speakers, (usually the one with the marking is the positive speaker side). This should help..
Jan 31, 2010 | Kenwood KDC-122 CD Player
Wire conection problem-no manual
Black is obviously ground. red is for switched power (only has power when vehicle is on) single yellow or orange is constant power Dual grey and dual white (solid grey/grey with black) and dual etc. are for speakers. the blue is for accessory power for amps and eq's. on the speaker wires the one with markings is for + and the soild is for -.
May 16, 2009 | Jensen MCD-9424RC CD Player
Zivan NG3 battery charger diagrams
your NG3 should have been preprogrammed for the type of batteries you are charging. The NG3 has the 3 wires from the power cord. Here is what I have done:
Brown from charger goes to black wire
Blue goes to white wire
yellow green goes to green ground.
Mar 11, 2009 | Ryobi Multi-Volt Battery Charger
Toys Logo
41 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
