Question about Waring JEX 328 Health Juicer
Motor may be burned out; juicer does not turn on
There was smoke...
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
If you saw smoke, likely the motor may be burnt. A bit late!
Mar 23, 2014 | Waring JEX 328 Health Juicer
The motor stopped while juicing hard veggies and doesn't work any more even after the engine cooled down. again. How to fix it?
There may be an overload switch somewhere on the unit, it will just be a small button projecting from the underside most probably or in a small hole. If there is, just depress it. If the unit actually burned out yu would have seen smoke and smelled it.
Jan 21, 2011 | Breville BJE510 900 Watts Juicer
Motor stops, electric burning odor, starts after cooling period
1-973-287-5150. VERY SHORT WARRANTY. IF OUT
OF WARRANTY GO FOR SOMETHING BETTER.
GOOGLE FERNS NUTRITION, THEY SELL JUICERS
AND GIVE GOOD ADVICE. I HAVE AN ACME SINCE
1990 AND RUNS LIKE THE DAY I GOT IT. TAKE A
LOOK AT THE LEXEN GP62. THE HUROM SLOW
JUICER IS GREAT, BUT BIG BUCKS.
Apr 01, 2010 | Jack Lalanne Power Juicer 250 Watts
The engine started to make a horrible noise and practically jumped off the counter while it smelled like something burned.
these juicers have a tiny little motor. once they smell bad, they are shot. not worth repairing. Joe
Mar 04, 2010 | Jack Lalanne Power Juicer 250 Watts
Breville Juicer motor burned out & Customer Service won't help
if you happen to live in North America...Then you got Wal Mart..Tell those People to F!@#$%^Off and go buy a new one
Dec 20, 2009 | Breville JE95XL Juicer
My breville juicer won't turn on after working only minutes earlier. Did the motor burn out?
yep, you pressed to hard while juicing something not ripe or very leafy
Aug 20, 2009 | Breville 800JEXL Juicer
It want turn on in smells burned
Assuming the motor is not totally burned yet, Make sure the blade is fiitted in its place right. Take the blade out again and fit it right along with the strainer. If it is not seated and fitted well, it will touch the upper cover and will not turn and will smell burnt.
Jun 04, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack LaLane Power Juicer CL003AP Tri Star Products
The Jack Lalane website claims it has a lifetime engine warranty. Visit to find out.
Aug 09, 2008 | Jack Lalanne Power Juicer 250 Watts
Waring JEX 328 Health Juicer Logo
26 people viewed this question
Top Waring Juicers Experts
Henry  Thomas
Henry Thomas
Are you a Waring Juicer Expert? Answer questions, earn points and help others
