Question about Epson LQ 300+ Matrix Printer
Continous paper not stop
Printer is worked , but paper is not stoped
Paper gap sensor
Ok, this is easily solved in 3 different ways
1) Driver: Download the greatest driver I know, the one developed by the NiceLabel guys: www.nicedrivers.com
you need to go on right click in te driver(Start/Control panel/TEC Toshiba...) choose properties. In options you will have the chance to verify the gap mode(continous/black mark/ etc). You can also calbrate your printer from there.
2) If your printer needed to calibrate, turn-it off, then, by holding the feed button, turn-it on and let go after 3 seconds, or after you see a light. It will calibrate automatically with your label size at that moment, it may also print the printer settings, so be prepared for stoping the baby.
3) If you have a barcode software(did i say I reccomend NiceLabel?), you can set the instructions on 1) directly from printer settings.
Good luck, peace.
Aug 14, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Epson lq-2180 printer paper out & pause Indicator continously on
I have epson lq-2180 printer with the following problem: Paper out & pause indicator is continously on when I try to print. The paper is rolling when I push pause button.
Jan 22, 2013 | Epson LQ-2180 Dot Matrix Printer
Paper not accept, station1 light blinking continously
paper not accept, ready and station2 light blinking continously
Oct 28, 2012 | Olivetti PR2E Matrix Printer
When removing the document that prints, how do I remove it from the continous paper without wasting a sheet every time?
Press the view button tear off the paper then press view button again and the printer will bring the paper back down, I think anyway
Mar 23, 2012 | IBM 6400 Matrix Printer
Started out with paper, would start to load paper them as soon as paper stared in would stop. After several tries it would work. Then it stoped taking paper at all. Each time you try to print it stops and...
First I would remove the paper tray and check the rollers and print path for any scraps of paper that may be tripping up a sensor. If all seems well, ...
Try this next: It will reset the printer's configuration info.
To factory reset your Dell 1700 series printer follow these steps.
  1. Turn off your printer
  2. Open the front cover (push the button on the left side)
  3. Hold down the "Continue" and "Cancel" buttons and turn the power back on.
  4. When the "Error LED" light on the control panel is solid, close the cover and release the "Continue" and "Cancel" buttons.
Tip: To print a configuration sheet push the "Continue" button twice. This will give your printers IP Address.
Dec 31, 2010 | Dell 1700n Laser Printer
I have a continous red light (paper jam) on a kyocera Mita fs 1000+ not obvious paper jam,..... what's wrong?
If you are not seeing any paper there you most likely have a bad paper detect sensor. The paper detect sensor is what looks for the proper timing of the paper moving through the machine and indicates a jam when the paper stops.
Dec 24, 2010 | Kyocera Mita FS-1020D Laser Printer
Manual paper handling
Should be able to. Change the default paper tray in printer to the manual tray.
Rgd
S88
Mar 18, 2008 | Lexmark T632 Laser Printer
Paper Jam Error
check the paper feed section of the printer. it may be item stuck in the paper path. causing the paper jam senor to stay on. also it know for these printer to have a waste in full. this will stop all workings of the printer. as these printer only have small waste ink pad in them. Need to know if the printer is flashing just green or if it flashing green led then a orange one.
Sep 23, 2007 | Canon PIXMA iP90 InkJet Printer
Epson LQ 300+ Matrix Printer Logo
27 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
