Question about Philips Magnavox PA0132C 32" TV
How do you turn off close caption on magnavox 32crt tv w/o orginial remote, I have a univerisal remote doesn't have the cc on it nor on the menu on the tv screen please let me know
You don't need the remote. I just did this today.
First Press, menu, then use the channel up button to scroll up.
Once you scroll up about 5 items the CC options are there. A few clicks of vol + button will get that off your screen for good.
Posted on Jun 06, 2010
How do I shut off the captioned dialogue on the screen for my magnavox smart series tv. there seems to be no such choice on the menu
hi,
For closing the Closed Caption option do the following.
1. Press the MENU button on the remote to see the menu.
2.Press the up arrow or down arrow until the CC (Close Caption) is highlighted.
3. Press the right arrow repeatedly until CC OFF appears.
4 .Press the menu button to exit.
Or, you also can set Closed Captions by pressing the CC button on the remote. Press CC repeatedly to select: CC-OFF,
ok
Feb 07, 2011 | Philips Magnavox 20MS233S 20" TV
I can't get the closed captioning to go off. please help. i have the remote, but it is not an option from the menu.
U have a CC button on the remote.Use that CC button turn all CC1,CC2,CC3 off.U will have no more captioning.Or go to the menu turn all caption CC off and all TXT off too.
Mar 15, 2010 | Philips Magnavox 20MS233S 20" TV
Turning off Closed Caption
Are you using a cable/satellite box or just basic cable service?
When you go to the menu what options become available to you?
If the following options are present-
smartlock
setup
cc
If not try to press both the volume buttons on the front of the TV at the same time and see if the above options become available.
If so use the channel down button on the front of the tv to scroll to "cc"
Once CC is highlighted use the volume + button until it says CC off.
If these menu options don't become available please reply what options are shown.
Good Luck.
Jan 05, 2010 | Philips Magnavox 20MS233S 20" TV
Close Captioning will not turn off
I don't know your TV, but closed captioning normally operates from the remote and/or the menu. There should be a CC button on the remote that will run through the three or four choices, including off. Also, when you go to your setup menu (on-screen) you should be able to find closed captioning on one of the sub-menus and turn it off there.
I hope this helps.
Oct 11, 2009 | SNK Magnavox 42MF438B/27 42 in. LCD TV
I need help with removing captions
This information was found on the Magnavox website http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=TV_CONVENTIONAL_CA&sct=TV_LARGE_25_29_SU&grp=TV_GR&session=20090602222010_68.190.209.25&ctn=27MS343S&mid=Link_UserManuals&hlt=Link_UserManuals in the owners manual on page 20. If this information does not solve your problem. Try calling Magnavox customer support at this telephone number 1-800-705-2000. Give them the model number of your television and tell them about the problem you are having with not being able to turn of the closed caption feature. I hope this helps you solve your problem. 1Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- until SET is highlighted.
3 Press CH+ or CH- repeatedly to
highlight CLOSED CAPTION.
4 Press VOL+ or VOL- to display the
CLOSED CAPTION menu.
5 Press CH+ or CH- to select the
closed caption you want (OFF, CC-1,
CC-2, or CC-MUTE). CC-MUTE sets
the TV to show closed captions when
you press MUTE. The TV volume will be
disabled until you press MUTE again to
restore the sound.
6 Press VOL+ or VOL- to confirm your
selection.
7 Press TV/AV/EXIT to remove the
menu.
Apr 23, 2009 | Philips Magnavox 27MS343S 27" TV
Philips 50" flat screen - Closed captioning won't turn off
on my magnavox it was the verizon fios remote that enabled it by accident (it is tuned to control the tv) however it was a cc button represented by the * on the remote that i had to select to change the cc. this didn't make it go away so i just pressed buttons i used the "Aspect" button represented by the # it changed the ratio and the message went away. I usually only use the fios remote to turn the tv on and off but this must be some whacky override that comes from the fios remote.
Jan 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No remote how to turn off cc
You might try a Magnavox brand universal remote. Get one with a "menu" button. Often they give nearly complete control on a Magnavox brand TV. Otherwise, the only real solution is to purchase the exact original remote. There are many vendors on the Internet selling replacements, but often the costs are ridiculous.
Jan 23, 2009 | Televison & Video
Close caption turns on and off by itself problem
Check the cable box to make sure the captions aren't truned on in the cable box.
If not -if it really is the Magnavox caption service- then -
This is assuming you have the original remote:
1 Press MENU to show the on-screen
menu.
to display the
CC-2, or CC-MUTE).
CC-MUTE sets
restore the sound.
to confirm your
selection.
menu.
Feb 25, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox PA0132C 32" TV Logo
173 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
