Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
My dishwasher fisher pykel twin dish washer model # DD 605 , SHOWS AN ERROR CODE f7 first then shows error code f9
The top drawer is very hard to open or close sounds like scraping somewhere , bottom drawer is working fine
  • Fisher and P... Master
  • 3,247 Answers
The top dishdrawer is hard to open or close as the lid seal actuator motors are most likely faulty or lost power. The scraping is the lid seal touching the drawer lid. The F7 and F9 error are a result of this fault with the actuator motors.
At the base of the dishwasher housing under the bottom drawer is the power board. From there the power is supplied to the controller and the motors. These motors move the lid seal into position. First turn the mains power to dishwasher off and then back on. See if this resets the motor position. If not you will have to call the technician to fix the problem. But if you are technical savy you could go to the base of the dishwasher and take the connectors of drawer 1 out from the power board and swap with drawer 2 which is working.
If power board connection is not making any difference, then motors are the likely problem. Needs a lot of expertise to replace and adjust the motors.
Posted on Mar 23, 2014
  • 5 Answers
SOURCE: fisher and paykel DD-603 dish drawer
Hi there, If you have had an F1 you need to dry out the product in order to reset the flood switch. This is a simple process as follows: 1. Ensure product is disconnect from wall so that it has no power. 2. Open the bottom drawer and put your hand in through the gap where the bottom of the bottom drawer comes out and feel the base of the cabinet that houses the drawers for water. 3. If there is water present dry it out as much as you can with paper towels or old rags. This machine is designed to drain all water to the front of the base of the cabinet away from the flood switch that sits at the back left corner of the cabinet base that the drawers are fitted into. 4. When you have base of the cabinet dry you need to ensure that the switch has not moisture on it in order for it to reset and allow you to start using the product. This can be done 2 ways: 1. leave bottom drawer open for 24-48 hours to allow natural air circulation to dry out the connection. or 2. position a hair dryer to blow air into the back left corner of the base of the cabinet and dry it out quicker. This still make take up to 6 hours as the flood switch had a protective cover over it to try to prevent F1's for small spills. 5. When the product had been dried out, important that you make sure it has, when you switch on the machine the F1 should be gone and ready to use. Please run each drawer seperately on a rinse cycle to confirm to yourself that it flooding was possibly caused by something blocking the sprayarm, or something stacked too high or something got stuck in the pump temporarily stopping it from draining effectively or the product suddsing too much from spilt rinse aide in one of the drawers. If each drawer runs successfully you should be in the all clear to start using it again. Please note though: if something blocks the spray arm that is directly linked to the pump your drawer will flood as a result. If you have something stuck in the pump peventing it from draining effectively ie a toothpick or piece of broken crockery this will cause your product to flood, but you will hear an louder than normal sound when the pump is running. And finally if you spill rinse aide in your drawer when filling it clean all spilt rinse aide to prevent unit from over sudsing when running. Regards KAR-Ltd
Posted on Aug 09, 2007
Master_Tech
  • 770 Answers
SOURCE: Fisher & Pykel dishwasher dual drawer
I have the manual for your model here what are you asking ?? is there a fault you want to reset?? if so what is it on the display?/ I dont know what you mean by>> " he reset it" reset what the drawer ? [please be as clear as possiable..If you are mech incline i can email you the manual
Posted on Jan 27, 2008
SOURCE: bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Posted on Nov 25, 2008
vitg55
  • 78 Answers
SOURCE: Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Dec 01, 2008
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
Top half of my dish washer beeps when i push the power button
you will find this diagnostic service document useful.
http://applianceassistant.com/ServiceManuals/dishwasher-fisher-paykel-dish-drawer-dd603-ds603-service.pdf#zoom=100#scrollbar=1
The likely reason for top drawer not starting wash program when you press start button is the drawer home sensor is either faulty or the drawer is misaligned. This means controller thinks the drawer is open and does not start the cycle.
Apr 28, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel Dish Drawer: I flooded it by using wrong soap. It was flashing F1 but I solved this by drying it out after removing the bottom drawer. That problem is solved but now the top drawer is...
Most likely the lid seal is dislodged and is obstructing the bottom drawer. Need to manually operate the lid seal actuator yoke and motor to bring the seal back to normal position. Can be messy.
Will need to get the bottom drawer out from housing and work on lid seal assembly located in the main housing.
http://spares.bigwarehouse.com.au/images/files/6145_5635c632f6805f5644d3f35b6feea5bc.pdf
Sep 25, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
We have a 23" Fisher&Paykel dishwasher and got
The F1 error coming on top drawer when operating bottom drawer is due to the thermal fuse blowing up on the bottom drawer and shutting controller power.
The thermal fuse could have blown either as a normal component failure or heater over heated due to thermostat failure. In any case this can be repaired by replacing the whole heater assembly as all the parts are integrated.
This is at the underside of the drawer and will need a technician to replace unless you are very familiar with repairing electronic dishwashers. The part look like this.
The way you have described the onset of the F1 error is not due to flood switch. You can confirm that the lights on the bottom drawer are out even though the top drawer is showing F1 and beeping.
If problem was flood switch then both drawers would show F1.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Is there a reset button on the dishwasher for the Fisher Paykel DD 605. I washed a top and bottom load, nothing unusual about the loads. The dishwasher just stoped and there is no power on either of the...
If there is no power on both the drawers then 2 things
1. the circuit breaker on the mains power supply feeding the dishwasher has tripped
2. the power board that feeds the drawers is faulty. This is located at the base under the bottom drawer.
The drawers won't open because the power has failed mid cycle and the drawer seal actuator motors are locked in down position.
You can force open the drawers but this could require some mechanical adjustments to the actuator yokes if the two sides are out of alignment when power is restored. In any case you will have to force open the bottom drawer to get access to the power board. The part looks like this but may not be the one specific to your model. You will have to contact a parts dealer local to your area.
The only reset function available is to turn the mains power off and back on.
Hope this helps. Please rate the solution if useful otherwise post a comment.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Drawer won't open and get beep code 2 short 1 long
The drawer door seal is locked in. This could be either because the controller has lost power or the seal actuator motor is faulty.
You will have to force open the drawer before you can do anything. (Turn off the mains power when you work on the dishwasher)
Let me know if you can handle electric/ mechanical repairs so that I can guide you further. Otherwise you should call a technician. If you are getting beeps then most likely the door seal system is the problem.
Are you able to use the top drawer?
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Th dish washer that we have is the 2draw dd-603m
A lot depends on how it happened. Is this a new installation or everything was working well until now? F1 error implies the float switch in the drawers is activated as the inlet water soneloid could not turn off. This prevents the units from being flooded.
Are you using the correct pressure setting for the water supply. Check the user manual for details. IF you don't have one, download from the fisher & paykel website.
Nov 08, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher pykel original dish drawer
if you pull out the lower drawer, there s aside release pin on either side of bottom corner of hte drawers when extended. a small maybe quarter sized hole( no need to mess with that only removes the face panel) but under it is a release that you can push in and back a little, this will unlock from the drawer hinges(slides) just nee to lift up and over to the left slightly, on the back wall behind hte drawer youll find a pretty good trouble shooter for this model, itll tell you what hte code is and will try to walk you through as to what might of happened as well as recommended repair
Mar 26, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
323 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
