Question about Toshiba E-Studio 356 Copier
How we describe in toshiba copier model: e-studio-356SE, this copier is 3line ccd or 4line ccd.? please define, i have some problum, in this copier model: e-studio-356SE.
How we describe in toshiba copier model: e-studio-356SE, this copier is 3line ccd or 4line ccd.? please define, i have some problum, in this copier model: e-studio-356SE for updating fimrware, but unfortunatly display was showing error message "Invalid Signature" but i dont understnad, 3line ccd or 4line ccd.
  • 31 Answers
SOURCE: Toshiba e-Studio 350 FAX Communication error
Are you still receiving faxes although you are unable to send? Or is it no send & no receive? When you hook a phone up are you able to connect with a # dialed from that phone. It's possible that the problem is the copiers NCU board- but it's rare that they fail & even more rare that it loses just the send portion. You'll want to be absolutly sure that it's not the phone line. If you are positive that the problem is not the phone line - try turning the machine off & unplugging the power cord for 30 minutes. Occasionally the NCU card will lock up & not function properly. Unplugging the machine for 30 minutes has worked for me in the past.
Posted on Mar 29, 2007
  • 990 Answers
SOURCE: error code c440
Hello sir; C440in this machine,it means fuser unit problem, but it can be reset the procedure as follow;
1, hold down "0" and "8" keys while turn on the power.
2, enter 400 press start.
3, enter 0 press set or enter.
Posted on Jan 07, 2009
  • 990 Answers
SOURCE: Error F120
Hello sir; The error code you display F-120 it means "data base" problem it can not be reset you have to replace either memory chip or hard drive.
Posted on Jun 02, 2009
  • 643 Answers
SOURCE: Toshiba e-Studio 232 is showing error message CF60
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Posted on Jun 10, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Hi, My Toshiba E-Studio 3511
I am assuming you have emptied the old waste toner "box" and not replaced it with a new box. This is not a problem, just clarifying. If this is the case then you have toner packed into the sensor block which is telling the machine that the waste toner box is still full. Just look behind the waste toner box and look for a little set of wires. They lead to a small black sensor. Now look at the waste toner box where it mates up with the sensor. You will see a small square box area on the waste toner bottle. The sensor looks thru this block and if it is blocked with toner it will tell the machine the box is full. Just tap on the little block and make sure there is no toner in it and re-install the waste toner box and the indicator should go away.
Good Luck and Thank You for using Fixya.
Posted on Aug 11, 2010
Toshiba e studio 356se error code f121
user management database is corrupted.
Delete the log in the following procedure:[5] + [C] +
[POWER] ? 4. Initialize database ? 1. LDAP database
(to delete user database) (Note that all user, role, group
and accounting data will be deleted.)
If the error is not recovered, reinstall the system software.
([4] + [9] + [POWER] -> 4. System Software(HD data))
Jul 14, 2016 | Toshiba Office Equipment & Supplies
Toshiba e-studio 356SE error code f 121 Database abnormality user information management database
Jul 14, 2016 | Toshiba E-Studio 356 Multifunction Copier
USER MANAGEMENT DB CORRUPTION. F121 e studio 356se
Database abnormality (user information management database)
Feb 26, 2015 | Toshiba e-Studio 350 Copier
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
Toshiba E-Studio 356 Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
