Question about Bose Acoustimass 15 System
Subwoofer stopped working
Subwoofer
Loud buzz in sub woofer, soundbar sounds fine
How to Stop a Subwoofer Hum - HowStuffWorks
electronics.howstuffworks.com/how-to-stop-subwoofer-hum.htm
Would you like to learn how to stop your subwoofer from making a consistent low-frequent hum or buzz? Read this article to learn how to stop a subwoofer hum.
Aug 03, 2015 | Audio Players & Recorders
Philips DC912/37 will not pair with the subwoofer. I have had the device for 2 years, and the subwoofer stopped working recently, and now it will not pair with the tuner.
This worked for me. Try it and it should work for you all as well..;-)
Frequently asked questions See all FAQs Question How do I get the main unit to recognize the subwoofer? Answer Wireless connection will set up automatically when you switch on both the main unit and subwoofer.
Sometimes you may encounter the problem that the main unit does not recognize the subwoofer. Try the following process to solve the problem:
  • They are heavily interfered by other wireless home appliance such wireless network, TV etc. Move the subwoofer to another place, the main unit will auto detect & recognize it.
  • Switch off the main unit and the subwoofer and then switch on them again. The main unit should recognize the subwoofer automatically.
If neither of the above works, try to pair with them manually.
  1. In standby mode, press and hold the 090518075138_27245.gif button on the main unit (PAIR flashes on the display screen.) to activate signal transmitting.
  2. Press and hold the PAIR button on the rear of the subwoofer (You will find the LED indicator on the subwoofer flashes in blue and green alternatively) to activate signal receiving.
The wireless connection will set up automatically and the main unit should recognize the subwoofer now.
Dec 21, 2010 | Philips DC912/37 iPod Docking Shelf Bar...
Subwoofer stops working at times and will not work.have had it about 4 or 5 days just started doing it today
many pple have the same problem.... that subwoofer stops working sometimes when playing music or something else... I also faced the same problem .... I did the following things..
open your subwoofer. checked all connections for any loose contacts... and then check the wire of the main speaker.....
IF YOU FIND DIFFICULTIES IN OPENING OR IF YOU DONT KNOW MORE ABOUT THE INTERNAL PARTS OF SUBWOOFERS.. THEN DONT TRY TO OPEN IT.. YOU MAY CAUSE DAMAGE TO IT...IN THIS CASE :
GIVE YOUR SUBWOOFERS TO THE SERVICE CENTRE FOR REPAIRING...
Dec 15, 2010 | Onkyo SKW-200 Subwoofer
Subwoofer stopped
the subwoofer only works when deep bass signals are sent to it.you may not have had any in the music/movie you were watching..check yr on screen menu for settings
Jul 08, 2010 | Sony BRAVIA® DAV-HDX576WF Theater System...
One subwoofer has stopped working
the voice coils could be damaged, check for burns on the connections
Dec 03, 2009 | Rockford Fosgate Punch® P2D412 Car...
After time they may collect dust. clean them a bit.Do u have an extended warranty. may your should use it . if that does work maybe time for an upgrade..
Sep 06, 2009 | Logitech R-20 Computer Speakers
You have a bad connection to the subwoofer.
Mar 07, 2009 | Monitor Audio Radius R360 Subwoofer
Subwoofer dont work at all
That sounds like defective internal wiring or a loose connection on the amplifier PCB. If you just purchased this audio system. It should still be under warranty for a defect.
Feb 06, 2009 | Panasonic SC-PT1050 System
My subwoofer stops when volume is increased
have u check the radio out do u have an eq
May 19, 2008 | Kicker CVR12 Car Subwoofer
Subwoofer stop working no sound at all.any help would be appreciated
check all fuses and wireing connection on your system maybe a wire has come loose
Mar 09, 2008 | Earthquake Sound SZ-12 Car Subwoofer
Bose Acoustimass 15 System Logo
85 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
