Question about Electric Bicycle Motor, Bike,electric Bicycles ,kits
Electric bicycle How do you change the back tire on a Cozybike LE Electric bicycle? I need a manual for the Cozybike LE
  • Michelle Reiss
    Michelle Reiss Jul 25, 2014
    Joy have copy of manual if you still need one.
  • 23 Answers
Contact the seller for a manual http://www.omegastores.com/cozybikele.htm
First remove the battery then find someway to support the bike as removing the rear wheel also removes the stand...
Remove the 2 Philips head screws securing the rear mudguard and the 2 on the LHS rear axle cable protection cover & slide the cover off. Disconnect the rear brake. undo the rear axle nuts. Loosen the chain adjusters and slip the chain off. You may also have to deflate the tyre to get it past the mudguard.
Posted on May 30, 2014
Tip
How to Change a Flat Bicycle Tire
1) Begin by looking at your old bicycle tire, and find the dimesions of the tire on its side. Write down these dimesions, becuase you must then go buy a new innertube for the tire that is the same (or about the same) size. I suggest going to a bicycle store; at the one near me tires run about 5-10 dollars.
2) With this new innertube in hand, you can begin changing your bike tire. You must start by taking off the entire bike wheel. To do this you need a hexagonal-shaped wrench thingy that looks like this:
See the hexagonal wrenches on the left side? You're ging to need something like that to remove the wheel. If you don't already have one, you can get this one from here (Walmart.com), or you can look up 'bike tool' on Amazon or Ebay.
3) You then use this tool to remove two hexagonal bolts, one on either side of the wheel; shown here:
Then use a flathead screwdriver or another falt object/tool to pop the outer tire off to expose the old innertube inside, like this:
4) Remove this old innertub, and put the new one around the wheel. It might seem a little big, but that's okay. Proceed by slipping the outer tire back on over the new innertube, using the same tool you got it off with.
5) Put the wheel back on the bike, screw the bolts back in, and inflate the tire to whatever PSI (Pounds per Square Inch) it says on the side of the tire.
6) You're bike is ready to ride again!
on Feb 16, 2010 | Cycling
Back tire won't move
Check to make sure the wheel is in the frame correctly and not rubbing anywhere. If it still doesn't move, check to see if the brakes are making contact. If it still not moving, your hub may need replaced or overhauled.
May 26, 2014 | Fuji 2013 Absolute 3.0 LE Road Bike -
Why does my tire wooble after changing tire and tube?
This could be a bad tire or it could be that the bead did not seat in the rim.
May 14, 2014 | X-Treme XB-610 Elite Electric Bicycle 600...
I have a lighting cruiser electric bike i need an operators manual. I changed a tire and reassembled the rearend. when tested no go... all indicator lights lit and would not turn off by switch only when...
It sounds like you have either not re-connected the wiring correctly or have damaged a cable. Sometimes a pin in a connector can be unseated and may need to be pushed back in to seat fully. Double check that the connectors are correctly/fully mated and that there is no damage to the wiring.
Aug 15, 2013 | Electric Cycling
Manual for cozy electric bike
who to put together a Cozy Electric Bike?
Jan 12, 2013 | Little Tikes Cozy Cruiser Trailer
How do I program my bicycle computer? My battery died, I changed it and now need to reprogram. Can you help? Bicycle tire size is 700 x 23C.
Just get the manual and keep it for the next time you need it...
A simple web search for "Vetta RT288L manual" finds it.
Sep 14, 2011 | Vetta RT288L
Crankarm fell off electric bicycle.
Crank bolts are rarely ckecked when building a bike, they are usually tight from the factory and don't need to be looked at.
Sometimes they are not, but you can fix it at home if you have metric socket tools and a ratchet handle.
Grab a small flat blade screwdriver and pry off the grey plastic cap, you should find the nut in there, you'll need that!
Rotate the arm that is still attatched so the pedal is at the bottom,  Move to the other side of the bike and slide the other arm onto the axle with the pedal at the top and facing away from the frame. Thread the nut on by hand. Grab the ratchet and tighten it tight (same weight as doing a push-up or lifting a 50lb bag of something), go to the other side, take the grey cap off tighten that arm as well. Then put both caps back on and ride in peace.
Feb 17, 2009 | Omega Cycling
Electric Bicycle Motor, Bike,electric Bicycles ,kits Logo
189 people viewed this question
Top Electric Cycling Experts
ebike
Level 1 Expert
Eric Hidle
Level 1 Expert
Are you an Electric Cycling Expert? Answer questions, earn points and help others
